Why can light go through some matter but not other matter?
  • Thread starter Thread starter k9b4
    Light Matter
This discussion focuses on the behavior of light as an electromagnetic wave when interacting with different materials, specifically addressing transparency and reflection. It establishes that an object is transparent if light causes electrons within it to oscillate and emit light of the same frequency, allowing it to pass through. The conversation also clarifies that while light can reflect off surfaces, air is not visible under normal conditions, but can be seen when bubbles are created underwater, demonstrating the principles of light refraction and reflection.
  • Understanding of electromagnetic waves
  • Knowledge of electron behavior in materials
  • Familiarity with the concepts of transparency and refraction
  • Basic principles of light reflection
  • Research the properties of electromagnetic waves in different media
  • Explore the concept of light refraction in various materials
  • Study the interaction of light with gases and how it relates to visibility
  • Investigate the physics of bubbles and their optical properties underwater
Students of physics, educators explaining optics, and anyone interested in the behavior of light in different materials.
k9b4
If possible, I would like an explanation that uses light as an electromagnetic wave, rather than a massless particle, because I don't understand photons. Thank you.
Science news on Phys.org
davenn said:
Thanks, so an object is transparent if light causes electrons in the object to oscillate, all the way through, until the same frequency light is emitted out the other side?
If this is the case, consider the electrons right on the surface of the object on the side of the incoming light. The light is causing them to oscillate; why is light not also reflected back to my eyes, enabling me to see air or other transparent materials?
Bump
Still don't understand
It is. That, and refraction, are how you can see glass or water or diamonds or other transparent materials.
But I can't see air. I understand how I can see diamonds and glass, but I don't understand how I can see air?
Sure you can. Go underwater and blow bubbles. You will definitely be able to see air in the same way that you can see other transparent materials.
Good point. Thanks.
17K
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 18 ·
