Why can you separate variables in differential equations?
Bashyboy
I have read that, if you given a differential equation [itex]\frac{dy}{dx} = f(x,y)[/itex], and can write it in the form [itex]\frac{dy}{dx} = h(x)g(y)[/itex], then you can proceed with the following steps:
[itex]\frac{dy}{g(y)} = h(x)dx[/itex]
integrating
[itex]G(y) = H(x) + c[/itex]
Why are these steps vaild? I thought that one was not supposed to regard [itex]\frac{dy}{dx}[/itex]. I have heard that you can regard it as a fraction, because, before taking the limit, you can manipulate the fraction [itex]\frac{\Delta y}{\Delta x}[/itex].
Could someone please help?
The justification is that dividing by g(y) results in
[tex]\frac{\mathrm{d}y}{\mathrm{d}x}=h(x)g(y)\implies h(x)=\frac{1}{g(y)}\frac{ \mathrm{d} y}{\mathrm{d}x}[/tex]
which then, supposing (chain rule) that for some function G(y)
[tex]\frac{\mathrm{d}}{\mathrm{d}y}G(y)=\frac{1}{g(y)}\implies\frac{\mathrm{d}}{\mathrm{d}x}G(y)=\frac{1}{g(y)}\frac{\mathrm{d}y}{\mathrm{d}x},[/tex]
can be integrated to
[tex]\int h(x) \mathrm{d} x = \int \frac{1}{g(y)}\frac{\mathrm{d}y}{\mathrm{d}x}\mathrm{d}x = \int (\frac{\mathrm{d}}{\mathrm{d}x}G(y)) \mathrm{d}x= G(y) = \int (\frac{\mathrm{d}}{\mathrm{d}y}G(y))\mathrm{d}y=\int \frac{1}{g(y)} \mathrm{d}y,[/tex]
the result you get if you "divide by dy". The steps you made are commonly used as they are often considered more intuitive.
You can think of the steps that seem incorrect as mnemonics to obtain a correct result. The justification is the one given above.
