Why can’t entanglement be explained by a signal?
  • Context: Undergrad
  • Thread starter Thread starter sahashmi
The discussion centers on the nature of quantum entanglement and whether it can be explained by a signal being transmitted between entangled particles during measurement. Participants explore theoretical implications, experimental observations, and the limitations of current understanding in quantum mechanics.
  • Some participants propose that entangled particles send information to each other at speeds potentially faster than light, influencing each other's states upon measurement.
  • Others argue against the notion of particles sending signals, questioning how particles would "know" to send messages or be part of an entangled system.
  • A participant highlights that quantum mechanical formalism provides explanations for measurement outcomes without requiring a signaling mechanism between particles.
  • There is a suggestion that a non-local physical wave function could collapse upon measurement, affecting the outcome of the other particle's measurement, though the specifics of this process remain unclear.
  • Concerns are raised about the implications of signaling, including questions about simultaneity of measurements and the nature of communication between particles.
Participants generally disagree on whether entanglement can be explained by signaling. Multiple competing views remain, with no consensus reached on the nature of the relationship between entangled particles during measurement.
Limitations include unresolved questions about the timing of measurements, the nature of entanglement, and the implications of the no-signaling theorem. The discussion reflects ongoing uncertainties in interpreting quantum mechanics.
sahashmi
TL;DR
Signals in entanglement
Why can’t entanglement be explained by a signal being sent from one measurement to the other?
When one particle is measured, it sends this information out to the other particle through some physical means (likely at crazy high speeds faster than light), and this determines the other particle’s state.
To my mind, I can’t see any evidence of this being ruled out by anywhere in physics. There is the “no signalling” theorem but that just means we can’t find a way to send information using entanglement yet, and that is only because we don’t know the measurement of one particle (whether it’ll be spin up or down) before it happens. This doesn’t mean that the particles cannot physically influence each other.
This seems to be the most simple, plausible explanation for this phenomenon. What other explanation could there be anyways?
  • Skeptical
Study the Stern-Gerlach experiment in detail and tell me when the electron knows its spin had been measured.
Or, the delayed choice quantum eraser.
How does the electron know it's part of an entangled system, where its partner is and what message to send?
The idea of elementary particles being sufficiently sentient to message each other is not an option.
I don’t necessarily mean the particles being sentient or the human concept of messaging.
I just mean the physical process of something, whatever it is, travelling between one area of measurement to the other, causing correlated results
If you took the time to study these experiments you'd see that there is no clear point at which a measurement of a certain quantity has taken place. Usually a quantity like spin is inferred from a final detection at some point. If that detection does not take place then the inferred measurement never happened in the first balance.
Quantum mechanical formalism explains all this. Particles messaging each other cannot.
The point is there is some final measurement outcome on one end and another on the other, even if we don’t know “when” exactly the measurement happens.
For example, there could be a non local physical wave function that collapses as soon as one is measured, which in a very fast way affects the measurement outcome of the other end (if the measurement occurs).
sahashmi said:
TL;DR Summary: Signals in entanglement
How would you explain the fact that we don't observe this signal?
What if the two particles are measured simultaniously? Which signals, or do they both signal each other? Is the speed then infinite? Do they signal all particles in the universe or just each other? How do they know who to signal?....
How is this even an explanation! It raises many questions and answers none.
@sahashmi You have already made this argument a half-dozen times in the past month. You don’t have to listen to or agree with the responses, but they aren’t going to be different when you do it yet again.
This thread is closed.
  • · Replies 32 ·
  • · Replies 27 ·
  • · Replies 57 ·
  • · Replies 20 ·
  • · Replies 48 ·
  • · Replies 31 ·
  • · Replies 54 ·
  • · Replies 87 ·
  • · Replies 96 ·
