Why could we see a laser hologram?
  • Context: High School
  • Thread starter Thread starter Stanley514
    Hologram Laser
The discussion clarifies that laser holograms are not visible as direct laser beams but rather through scattered light, which is significantly less powerful. It emphasizes that while a laser beam can be safe if sufficiently spread out, focused light can be equally dangerous. The conversation also highlights that true holograms require a medium, such as a screen or mist, for projection, debunking the myth that they can be displayed in thin air. The participants agree that understanding the power-to-area ratio is crucial for perceiving holograms effectively.
  • Understanding of laser physics and light scattering
  • Knowledge of holography principles
  • Familiarity with the concept of power-to-area ratio in optics
  • Awareness of 3D display technologies
  • Research the principles of laser light scattering
  • Explore the fundamentals of holography and its applications
  • Investigate the technology behind 3D displays using focused laser pulses
  • Learn about the use of mediums like smoke or mist in visual displays
Optics enthusiasts, laser technology researchers, holography students, and professionals in 3D display technology will benefit from this discussion.
Stanley514
How could we see a hologram created by lasers if laser beams do not get in our eyes (it could be dangerous)?
Science news on Phys.org
A laser beam isn't worse to the eyes than regular light if it's SUFFICIENTLY spread out.
And regular light that is focused can be just as dangerous as a raw laser beam.
That's correct.However you are missing sth.The laser beam area is about 0.2 cm^2.
In order to see the hologram,you need to splay the beam.In this case the ratio Power/Area is far less than before(The hologram's area could be 4 cm^2 in case of a coin or even bigger).Hope I helped a bit!
you see the scattered light which has much lower power.
I thought that laser hologram is created by pure laser beam in pure air.
Light could be scattered only from some material object?
Holograms can't be projected onto thin air...that's purely sci-fi. You need a screen of some kind, the image then appears in front or behind the screen, but can't go past the edge.
There are a couple 3D displays that either project an image into the air using focused laser pulses to make the air itself glow, or give the effect of projecting onto the air with a spinning screen or mirror, and there's tricks that rely on a smoke or mist as a screen, but these are not holograms.
  • · Replies 17 ·
