Why cross product has a direction but dot product doesn't?
The discussion clarifies that the cross product and dot product are fundamentally different operations with distinct definitions, resulting in different outputs: the cross product yields a vector while the dot product results in a scalar. The cross product is anti-symmetric, meaning it has a direction, whereas the dot product is symmetric and does not have directionality. Participants emphasize the importance of understanding the implications and applications of each product, such as how they relate to vector interactions and physical concepts like work done and electromagnetic effects. The relevance of angles between vectors is also highlighted, as they significantly influence the results of these operations. Understanding these differences is crucial for applying vector mathematics effectively.
Pronoy Roy
Can anyone tell me why?
Mathematics news on Phys.org
Because they are different things with different definitions. Why would you expect them to be similar? Do you also find it strange that one is symmetric and the other anti-symmetric?
Cross product is a vector, dot product is a number.
Here is an attempt. Look up the definition of each one. Now apply each one to two 3 dimensional vectors. It will be clear. This is just how each one is defined.
I think it might be more important for you to establish the implications and relevance of the two definitions - rather than to ask "why?" (there is no answer to that question, aamof). They are both very important and useful vector operations and both produce very meaningful and useful results. Can you think , from some example that you already know about, what the vector result of a dot product tells you, and similarly, where the cross product gives a useful result? Can you think of a quantity that isn't a vector but which is the result of the interaction of two vectors? How does the 'angle between' those two vectors affect the result? (Hint: consider Work Done)
Can you think of a vector quantity that is the result of the interaction of two other vectors and how the angle is relevant to the answer? (Hint: consider an electromagnetic effect)
rcgldr said:
a scalar projection has a direction
Scalar projection is a scalar just like the dot product itself.
Likes bhillyard
I meant a vector projection, not a scalar projection (fixed the previous post).
$$ ((A \cdot B) \ / \ |B|) \ (B \ / \ |B|) $$
