Why did Dirac want a first-order equation?
  • Level: Undergrad
  • Thread starter carllacan
    Dirac
3 replies · 4K views · last reply
carllacan
If I understand it correctly Dirac developed his equation because he was looking for a relativistic first order wave equation for the electron, rather than a second-order one like the Klein-Gordon equation.
Why did he wanted a first-order equation? Is it because the probability current is not positive-definite for higher than second order equations?
The wikipedia article gets into why Dirac chose first order instead of second order here:
Dirac's coup
Dirac thus thought to try an equation that was first order in both space and time. One could, for example, formally take the relativistic expression for the energy replace p by its operator equivalent, expand the square root in an infinite series of derivative operators, set up an eigenvalue problem, then solve the equation formally by iterations. Most physicists had little faith in such a process, even if it were technically possible.
As the story goes, Dirac was staring into the fireplace at Cambridge, pondering this problem, when he hit upon the idea of taking the square root of the wave operator...
https://en.wikipedia.org/wiki/Dirac_equation
There's also some discussion on physics stackexchange about it here having to do with the 1/2 spin of fermions which implies a first order equation:
http://physics.stackexchange.com/qu...-dirac-equation-and-bosons-a-second-order-one
Ok, so to sum up in case someone googles his way to this post:
If the equation for the wavefunction is of second order the boundary conditions must include the initial value of its first time derivative, which can be negative. The expression for the current density involves the time derivative of the wavefunction, so if the value of that derivative was negative at some point (which as we have said cold happen) then you would have a non positive definite probability current, which is nonsensical.
Dirac's first motivation is invalidated already by himself. There is no working interpretation of relativistic QT in terms of "wave mechanics" a la Schrödinger's non-relativistic equation. The reason is that you necessarily are lead to a many-body theory with non-conserved particle numbers and thus also the existence of antiparticles. The most convincing argument for the Dirac equation we know today is the representation theory of the Poincare group together with the assumption of local interactions and the existence of a stable ground state, leading to the CPT and spin-statstics theorem and are the basis for the very successful Standard Model of elementary particle physics.
