Why do parallel lines create equal line segments between parallel lines?
  • Level: Undergrad
  • Thread starter Thread starter limitkiller
    Line Logic
33 replies · 7K views · last reply
limitkiller
I am confused ,whats wrong with the reasoning below ?
assume that the black lines are parallel and red Line segments are defined between the black lines.
for any point on one of the red line segments there exist only one point on the other one (the points that are touched by the lines between the black lines and parallel to them).
so the Line segments have equal lengths.
Are you saying that the two red lines are equal? That is not true. They are only equal if they both make the same angle with the black lines.
An easy way (besides actually measuring them) is to use the pythagorean theorem on some simple triangles.
of course i am sure that they are not equal,but i proved(didnt I?) they have same count of points...
doesnt that mean they are equal?
please tell your reasons...:biggrin:
No. That proves nothing.
There are an infinite number of points on each line. But you cannot apply real number arithmetic to infinities (such as infinity = infinity).
What's wrong is that you don't understand what "infinte" means.
Google for the "Hilbert Hotel paradox" for some simple examples of why you idea doesn't work.
Note, the Hilbert "paradox" is only about a countable but infinite number of objects, but your line segments have an uncountable number of points, so it isn't the whole story - but it will get you started thinking the right way about "infinity".
Every interval on the Real number line has the same "number" of points. This has nothing to do with the length of the interval. For that you need to pick a metric, under the taxi cab metric then I believe you are correct the lines are the same length.
i don't get you...
if its true :
the Cavalieri's principle would be also wrong...
and lim (x/x) ,x→infinity =1 and lim (2x/x) ,x→infinity =2 would be wrong for the same reason.
I am not saying such thing as :infinity=infinity ,I just say: be cause for every point on one of the lines there exists only one point on the other so they have equal length...
also "Hilbert Hotel paradox" was pretty interesting but i don't thin its the same thing.
limitkiller,
Yours isn't a stupid question. It's actually very interesting. As others in this thread have pointed out, infinite sets behave in ways very different from finite sets. If you have two finite sets and you can find a one-to-one mapping between the two, the sets are equal in size. For example A = {1, 2, 3} and B = {one, two, three}. There's an obvious mapping between these two sets, and the cardinality of each set is 3.
Infinite sets are different, and counting their members seems counterintuitive. For example, it would seem that the set of positive integers (N = {1, 2, 3, ... }) is larger than the set of positive even integers (E = {2, 4, 6, ...}) since the first set contains all of the numbers in the second set. However, there is a one-to-one map between the two sets, so the cardinality of both sets is the same.
The mapping is
1 --> 2
2 --> 4
3 --> 6
and so on.
Using this mapping, any number in the first set can be seen to have a counterpart in the second set; conversely, given any number in the second set, its counterpart in the first set can be found.
limitkiller said:
i don't get you...
if its true :
No, this is different. What these limits are saying is that no matter how large an x you pick, the fractions x/x and 2x/x evaluate to 1 and 2, respectively.
No, what this says is that both lines have the same number of points. This is NOT the same thing as saying that both lines have the same length.
By your reasoning, every triangle would have to be isosceles (two equal sides). Consider a right triangle ABC, with AB perpendicular to AC, and with altitude AB and base AC. If you construct a line that is parallel to the base running from AB (altitude) to BC (hypotenuse), each point on the altitude corresponds to a point on the hypotenuse, so by your reasoning, the altitude has the same number of points as the hypotenuse (true), and hence, has the same length. Obviously this conclusion can't be true, which means there is a flaw in your reasoning about sets with an equal number of points implying that the sets have equal length.
yeah you are right,the limit thing is a little different but what about cavalieri's principle ??
I know my reasoning is wrong(actually I don't know how do I know:biggrin:) if it was true all the lines segments were equal...
but seriously it (my reasoning) is the same thing with Cavalieri's principle isn't it?
Yes, limitkiller, you are absolutely correct. A similar problem WILL arise in Cavalieri's principle. But the point is that Cavalieri was not correct, he himself realized this.
Cavalieri stated his principle around 1630, this is a time where mathematics is not rigourous and often wrong. Many of the papers of his time would be considered seriously flawed these days. So saying that a problem will arise in Cavalieri's principle is nothing new, this is already known.
Luckily, Cavalieri's method can be saved (in a lot of cases). It was Fubini and Tonelli who made the method rigourous and correct.
Mark44 said:
limitkiller,
The mapping is
1 --> 2
2 --> 4
3 --> 6
and so on.
than you
wow, two sets have one to one relation and in the same time they have one to two :biggrin: relation
1,2 --> 2
3,4 --> 4
5,6 --> 6
though I am not able to understand it...
this means i should study more than i do now...
and now i understand what does Hilbert Hotel paradox have to do with this.
I think the Hilbert Hotel was simply brought up to show that infinity is a very strange thing! You shouldn't reason with infinity as you reason with ordinary numbers, you need to be very, very, very careful with infinity!
Your OP also shows this. The question posed in the OP is only a paradox if you reason with infinity like you do with normal numbers. So you can't really do this!
Also limitkiller I would have a look at micromass' blog which contains a description of the Banach-Tarski paradox. This has the same kind of behavior which you are describing and might be informative for you.
okay,thank you
one last thing, in Hilbert Hotel paradox did we really accommodate every one in the hotel?
i mean there was always someone who didnt have a room an we just changed that someone.
That's the beauty of it, everybody will have a room! On the other hand, you are correct: we are just changing the person without a room. It's weird because it's a paradox :biggrin:
then if we have a room and two people we are able give each a different room(by giving ones room to the other and repeating it infinitely) ??
micromass said:
Yes! Even if you have a room and infinitely many people, you can give them all different rooms!
heeeeey everybody will have a room!:biggrin:
so why the hotel had infinitely many rooms? when finite number of rooms would do?
limitkiller said:
i don't get you...
if its true :
Cavalieri's principle talks about lengths, areas, and volumes. It says nothing about the "number of points" on a line, area, or region and has no connection with this problem.
There are at least a couple of parts to this problem. All of the rooms in the Infinite Hotel are assumed to be occupied by an infinite number of guests. In one part of the problem, a traveler comes to the front desk, asking for a room. The desk clerk tells the traveler that there are no empty rooms, but the clerk arrives at a solution by realizing that if he can get each of the current guests to move to the next room (the room with a number that is 1 more than the current room), then room 1 will be empty, and the traveler can take that room. If there are only a finite number of rooms in the hotel, this won't be a solution.
In another part of the problem, a bus with an infinite number of passengers pulls up to the hotel, and each passenger wants a room. After some time, the desk clerk realizes that if he can get each of the current guests to move to a room whose number is twice the number of his/her current room, then all of the odd-numbered rooms will be empty, and the bus passengers can take those rooms. This scheme also wouldn't work if the hotel had only a finite number of rooms.
I want to say something here that's relevant to the title of the thread. I would help with the question, but that's out of my depth right now. However, I just wanted to say...
This is not a stupid question. There are no stupid questions. If you feel you do not understand something, than going for help is quite simply the best thing you can do. Not stupid at all.
As long as you come with a willingness to learn, that is.
thank you!
Char. Limit, I make lots of mistakes and my questions are risen from those mistakes . so they are not really questions ,just mistakes...
HallsofIvy,as far as I know a principle is a fundamental truth that can be followed, how do you else follow it?
The only mistakes that you can be blamed for are the ones you refuse to learn from.
Depends what size of infinity :P
With the analogy of 1 -> 2
2 -> 4 etc.
there is one a bit closer to your problem.
Think about the line segment of all points (inclusive) from 0 up to 1. Now apply the x2 map to it (i.e. send 1 to 2, 0 to 0, pi/4 to pi/2, etc.) Now the number of points must be the same: to every point in the new line segment, there is precisely 1 point from the old line segment and every point from the old line segment goes somewhere, the x2 map "pairs up" all of the points! But after the x2 map, the new line has twice the length.
Intuitively, we think "where do these new points come from?" because we seem to have more, but the truth is that we don't!
2 -> 4 etc.
if there are same number of points ,then why 2/1=2 it should be 1 !
I think what HallsofIvy said might be true,after all its a principle... what do you think?
You are still conflating the ideas about length and number of points, even though there is no direct connection between them. The interval [0 , 2] has length 2, and the interval [0, 10] has length 10. Even though these two intervals have different lengths, each one has exactly the same number of points as the other. All that's needed is a one-to-one mapping from one set to the other. Here's that mapping f(x) = 5x, where x is a number in the first interval.
