poor mystic
- 128
- 1
Possibly, the fact that the Earth is rotating away from the rocket's launch point makes it seem to turn to the horizontal, when it's actually moving in a straight line.
Except for the fact that this effect makes it tip upward relative to the local surface, not downward. That would be at a rate of only one rotation per approximately 90 minutes. Less until orbital velocity is achieved.poor mystic said:Possibly, the fact that the Earth is rotating away from the rocket's launch point makes it seem to turn to the horizontal, when it's actually moving in a straight line.
The Earth is rotating west to east; in the direction of flight, not away from it.poor mystic said:Possibly, the fact that the Earth is rotating away from the rocket's launch point makes it seem to turn to the horizontal, when it's actually moving in a straight line.
True, though in order to fully utilize the pre-existing velocity, one needs to thrust parallel to it rather than perpendicular.A.T. said:They have that benefit already on the platform.
Steelwolf said:Rockets tip shortly after launch so as to gain the benefit of Earth's rotation added to final orbital speed.
Vector addition of velocities. You get the biggest increase if the added delta v is parallel to the existing v.CWatters said:Perhaps I missunderstand your answer but rockets get that benefit just standing on the pad. It's and advantage of launching nearer the equator than the poles.
I don't see how turning horizontally increases that.
Why does the order of applying velocities affect the final velocity? Is this a rocket / reaction engine thing to do with efficiency?jbriggs444 said:Vector addition of velocities. You get the biggest increase if the added delta v is parallel to the existing v.
The comparison is between applying a delta v parallel to velocity versus applying a delta v perpendicular to velocity. Nothing specific to rockets. Nothing to do with sequencing. Purely a geometrical effect.sophiecentaur said:Why does the order of applying velocities affect the final velocity? Is this a rocket / reaction engine thing to do with efficiency?
Velocity is a vector. You use vector addition rules. The direction that you apply the delta v matters. This is not a complicated idea.sophiecentaur said:Of course the azimuth setting should be Eastwards. My issue is that you already have your Original horizontal velocity at take off. That is the same when you are in orbit and the engines provide the rest. If the Earth were a bit less massive and not spinning at all, would the answer to the OP be the same? Would they still go horizontal 'soon after lunch'? (Spelling in purpose)
Your response seemed to imply that they should never turn horizontal at all, that the eastward velocity of the launch pad was an advantage that would apply regardless. Unfortunately, that is incorrect. The advantage of the eastward velocity of the launch pad is squandered if the [much larger] delta v is applied vertically rather than parallel to the existing velocity.CWatters said:but sequencing was at the heart of the OP... why do they turn horizontal almost immediately and not after they clear the atmosphere?
jbriggs444 said:Your response seemed to imply that they should never turn horizontal at all, that the eastward velocity of the launch pad was an advantage that would apply regardless. Unfortunately, that is incorrect. The advantage of the eastward velocity of the launch pad is squandered if the [much larger] delta v is applied vertically rather than parallel to the existing velocity.
How could you have come to that conclusion? They, of course, need to turn eastwards to bring their tangential velocity to what's required. The eastwards component from the Earth is there all the time. Apart from the fact that it always gives you an advantage, you have given no reason why it affects the best time at which the rocket drops its nose.jbriggs444 said:Your response seemed to imply that they should never turn horizontal at all, that the eastward velocity of the launch pad was an advantage that would apply regardless.
It actually is a complicated idea, in detail, which is why we are trying to think out the precise reason for using the available tangential deltaV so early. ~The reason must be to do with efficiency and the notion of Gravity Drag is at the bottom of it. Near the start of a vertical trajectory, the engines are doing very little work - only providing some GPE. Allowing the rocket to accelerate (in any direction) is good value and improved efficiency by having the engines working at low speeds for as short a time as possible.jbriggs444 said:The direction that you apply the delta v matters. This is not a complicated idea.
You are defending a claim that is different from the one that was made: that the launch pad's eastward speed is a free bonus that applies regardless. It is not.sophiecentaur said:How could you have come to that conclusion? They, of course, need to turn eastwards to bring their tangential velocity to what's required. The eastwards component from the Earth is there all the time. Apart from the fact that it always gives you an advantage, you have given no reason why it affects the best time at which the rocket drops its nose.
Why not?jbriggs444 said:You are defending a claim that is different from the one that was made: that the launch pad's eastward speed is a free bonus that applies regardless. It is not.
Because it can be squandered. E.g. if the launch is purely vertical.sophiecentaur said:Why not?
It seems to me, there is an issue of defining "vertical". To-wit: is that relative to Earth FoR or a remote FoR?jbriggs444 said:Because it can be squandered. E.g. if the launch is purely vertical.
I guess I'm not following either. Perhaps the cases are getting mixed-up. I'll try to be more descriptive in defining them...jbriggs444 said:Because it can be squandered. E.g. if the launch is purely vertical.
I guess it is possible, but I would hope not, since we kind of already discussed this. If the rocket thrusts perpendicular to the Earth's surface, the tangential velocity is preserved forever and you eventually reach an altitude where the tangential velocity is above orbital velocity (albeit not at the right inclination). As far as I can tell, the portion of the tangential velocity that helps you is never lost regardless of how you get to orbit (unless you purposely angle your thrust against it).DaveC426913 said:It seems to me, there is an issue of defining "vertical". To-wit: is that relative to Earth FoR or a remote FoR?
"Squandered" means it doesn't follow Newton's First Law then? We all know that throwing a ball vertical will result in it landing back in the hand. It's horizontal momentum has not been "squandered". Amazingly, it has been conserved, as will the momentum of the rocket.jbriggs444 said:Because it can be squandered. E.g. if the launch is purely vertical.
Yes, for a purely vertical thrust, the tangential velocity would be there, certainly. But as an increment to the resulting speed it would be small.russ_watters said:If the rocket thrusts perpendicular to the Earth's surface, the tangential velocity is preserved forever and you eventually reach an altitude where the tangential velocity is above orbital velocity (albeit not at the right inclination). As far as I can tell, the portion of the tangential velocity that helps you is never lost regardless of how you get to orbit (unless you purposely angle your thrust against it).
The relevant metric is not momentum. It is energy.sophiecentaur said:"Squandered" means it doesn't follow Newton's First Law then? We all know that throwing a ball vertical will result in it landing back in the hand. It's horizontal momentum has not been "squandered". Amazingly, it has been conserved, as will the momentum of the rocket.
We must be talking at cross purposes. I am sure you know your Newtonian Mechanics. Are you actually saying that the horizontal momentum it started with is not there, once it reaches an orbital position? (The Earth's curvature could be a second order issue) The only thing that could change it would be the difference in the g vector angle.jbriggs444 said:The relevant metric is not momentum. It is energy.
What resulting speed? Could you please be more specific because it feels to me like this lack of specificity is the entire problem here.jbriggs444 said:Yes, for a purely vertical thrust, the tangential velocity would be there, certainly. But as an increment to the resulting speed it would be small.
I agree that we must be talking at cross purposes.sophiecentaur said:We must be talking at cross purposes. I am sure you know your Newtonian Mechanics. Are you actually saying that the horizontal momentum it started with is not there, once it reaches an orbital position? (The Earth's curvature could be a second order issue) The only thing that could change it would be the difference in the g vector angle.
I agree.russ_watters said:My interpretation is that if you thrust vertically [perpendicular to Earth's surface], your tangential speed will start at and forever be about 900 mph and is totally decoupled from your vertical speed. Do you agree/disagree?
