Why do some books use dQ/dV for capacitance?
The discussion clarifies the use of the formula C = dQ/dV for calculating capacitance in non-linear devices such as pn junction diodes and transistors, contrasting it with the traditional formula C = Q/V. This differentiation arises because, in small signal circuits, the response of the capacitor to small voltage changes is critical. The differential capacitance dQ/dV is conventionally used for non-linear devices, particularly when analyzing C-V diagrams. Understanding this distinction is essential for accurate capacitance calculations in advanced electronic applications.
  • Understanding of capacitance and its basic formulas (C = Q/V and C = dQ/dV).
  • Familiarity with pn junction diodes and their characteristics.
  • Knowledge of small signal analysis in electronic circuits.
  • Ability to interpret C-V diagrams for non-linear devices.
  • Research the concept of differential capacitance in semiconductor devices.
  • Study the characteristics and applications of pn junction diodes.
  • Learn about small signal models in electronic circuit analysis.
  • Examine C-V diagrams and their significance in device characterization.
Electronics engineers, students studying semiconductor physics, and professionals involved in the design and analysis of non-linear electronic devices will benefit from this discussion.
Rib5
Hi guys,
Today was the second time in a textbook that they calculated capacitance using C = \frac{dQ}{dV}. In my electromagnetics book and any sources I find online they use C = \frac{Q}{V}.
Can anyone help me understand why they can do it like this? This type of calculation was done to calculate the zero bias junction capacitance of a pn junction diode.
For a linear capacitor, it doesn't make any difference, but for devices like diodes and transistors where Q is not a linear function of V, then it matters. For these non-linear devices, the differential capacitance dQ/dV is typically referred to as the "capacitance". This confused me also when I first started studying devices, but it is just a matter of convention. I think it arose because people were using these devices in small signal circuits where what mattered was the response of the capacitor to a small change in voltage. In any case, if you look up a "C-V diagram" for a diode, MOS capacitor, or some other non-linear device, what is actually being plotted is dQ/dV vs V.
Thanks for the reply, that explains a lot. It seems like in a lot of books they leave out a lot of the conclusions or assumptions that they make.
So basically it can be treated the same as a regular capacitance as long as the change in differential capacitance over the voltage range used isn't very big and mostly linear.
