Why do some physicists claim quantum theory has severe problems?
  • Context: Graduate
  • Thread starter Thread starter reilly
    Qm
209 replies · 32K views
Andrew Mason said:
There are only two postulates of Special Relativity and those two are essentially one: The speed of light is the same in all intertial frames. SR follows mathematically from that postulate. What is the essential postulate from which one can derive all of QM? I must have missed that class.
You are welcome to google those - even the mathpages link that you have used to refer others to might have them.
It is still besides the point. There are postulates and none-derivable axioms in ALL of physics. I do not understand why you pick on QM and ignore everything else.
Spoken like a true Canadian!?
AM
I also frequently say "oy vey". Does that make me jewish? Even better, I sometime say "oy vey" and "masha'allah" in the same sentence. Does that make me a muslim jew? Hey, I could be a quantum person with a superposition of two orthorgonal "states"!
Try and predict my "heroes", and you'll be wrong (as has been proven earlier in this thread). Try and predict my "nationality", and you'll be wrong too. Even I don't try to categorize me, so don't presume that you can.
Zz.
AM
Either that,or the QM teacher didn't say the 6 axioms are equally important...
Daniel.
Crosson said:
Special Relativity is the best example of this. Another good example is Maxwell's addition of the displacement current to Ampere's law; this term is necessary to predict EM waves.
My suggestions to read some history and get the facts apparently fall on deaf ears. Einstein himself said about SR, "I took into consideration Fizeau's experiment, and then attempted to deal with the problems on the assumption that Lorentz's equations concerning the electron should hold as well in the case of our system of coordinates being defined on the moving bodies as well as defined in vacuo." (p 139 in 'Subtle is the Lord... The Science and Life of Albert Einstein by Abraham Pais. This book is absolutely essential reading for anyone who wants to understand what Einstein did, and how he did it. It is a wonderful book, made particulalry special because Einstein and Pais were friends and colleagues at the Advanced Institute.) If you read, you will discover more about the empirical basis of SR, along with theoretical pushes from Poincare and Lorentz.
I'll also say again, that QM has remarkable explanatory power. With all due respect, to suggest that QM has no explanatory power is to demonstrate a considerable lack of knowledge about QM -- see, for example, Pauling's book on chemical bonds.
You are wrong about Einstein and wrong about QM. Again, profit from reading and the facts. If you read Einstein's great little book, Relativity, you'll find that the two primary pillars of SR are supported by some more subtle assumptions. They are there for the discovery.
Regards,
Reilly Atkinson
inha said:
To understand: I don't think reilly thinks there's anything wrong with not understanding everything under QM.
To accept: I as well find it weird that QM gets such zealous opposition. A theory is to explain and predict, QM has done both and done them well. I don't see a reason for the amount of opposition QM receives from some people. At times this forum seems to be a place for desperate attempts to disprove QM rather than a way to learn about it.
Hear, hear.
Regards,
Reilly Atkinson
ZapperZ said:
I'm not sure QM had to be "modified". Rather, it evolved!
I retract the "modified", it should have been "evolved". I never meant to imply that QM yielded incorrect results, but to imply that you make approximations in the form of perturbations etc for most problems at hand. In E&M you do not have to approximate to get an answer, maybe the solutions are not exactly tractable, but the basic equations have not been modified since Maxwell.
I spend about half my time working classical problems (Optics etc...) and the other half working in Optical Properties of Semiconductors and am truly amazed after all the years I have been doing this type of thing that QM gives reasonably correct answers that are verified experimentally. Devices I design work and the basic principles behind them are derived from the quantum mechanics of solids how do we do better?
Right - but classical E&M does not work at the atomic level. It is wrong.
There is the modern notion of "effective theory" which explains why our theories work as well as they do.
http://arxiv.org/PS_cache/cond-mat/pdf/9502/9502052.pdf
http://arxiv.org/PS_cache/gr-qc/pdf/0311/0311082.pdf
provide some background on this notion. There are other similar sorts of papers out there.
That's what I was driving at. QM may not yield exact solutions for atoms more complex than hydrogen, but the classical electrodynamics of charged particles doesn't even buy you that much.
Models don't have to be correct to be useful. The model of magnetic field consisting of little lines of force works really well. The model of electricity being a fluid passing through wires under pressure has some limited usefulness as well. Treating current flow in semiconductors as electrons and holes moving through a junction works too. Kepler's nested spheres could be used to work out orbits of the planets.
Usefulness in predicting results is important. But if one wants to understand what the 'reality' is, one needs a theory that does more than usefully predict results.
AM
AM
Whoa!
There is a difference between a "physics model" and "visualization"! You are confusing those two! Magnetic field lines are NOT a "model", it is a visualization! I challenge you to show me there there are "magnetic lines" in the Maxwell equations.
Usefully predicting result IS a part of reality! In fact, it is ALL that we have! Again, show me a "theory" that does MORE than this. Till then, what you have said is all hypothetical.
Zz.
Didn't I mention that exact fact in my original post, E&M works down to the point where QED takes over. There isn't a theory to my knowledge that takes into account everything. I took a Relativity course from a guy (Mendel Sachs) who claimed that after rewriting Einsteins equations in terms of quaterians and taking the linear limit he reproduced Quantum Mechanics and for a time had the best calculation of the Lamb shift. One of his students calculated the mass of the tau lepton to within an order of magnitude without using QM at all using Reletivity theory only.
Now Reletivity is about as close as I have ever seen a theory accounting for a the very large to the very small.
I still maintain that E&M is a very good, if not excellent field theory and QM is a close second.
But how does one judge how well a theory corresponds to "reality," if not by its ability to usefully predict results?
The problem we are discussing is written in Aristotles meditations. Essentially, the only thing I know for certain is that I exist. I may be writing this letter to nothing or something non-human or to a human or for nothing, but I do not know answer. The problem is we cannot reach out past our own experience. Some people argue that we can learn without experience(a priori), but I am trying to make a simple explanation, so I will only talk about learning from experience(a posteriori).
The complaint is that QM is taken from observation with no axioms to back it up. Newton was wrong. Einstein may be really close to the right answer or right on. QM may be right or close.
Newton based his theory off of experiences with the world. Newton could not see the whole structure of reality(If he could, would he know he was observing all reality?); therefore, he could not know if his theory was right or wrong. An old textbook will list Newtons theory as fact(a law), but we know that to be wrong. The point is, there cannot be axions about reality because we cannot go beyond our experience. Therefore, we cannot know what theories are right and what theories are wrong. We know that a theory explains our experiences with the world, and that is all. Whether the world really works that way, we can never know. Unless as I said before, learnig fully about the universe is possible a priori. I will let you guys decide whether or not that is possible.
QM, like or not, is a theory that explains much of the observable phenomenon in the universe. People may say that it is counter intuitive, and I understand. People should understand though that there will never be a truly provable TOE(theory of everything), only a TOE that explains all we observe. We can always ask the question is there something else? And we will never be able to answer it.
Even that part is debatable. Condensed matter physicists like Anderson, Laughlin, and Pines would argue that the so-called TOE that is the result of a unified theory is simply a TOE for REDUCTIONISM, not a TOE of physics. I have described this at length with appropriate references elsewhere and won't bore long-time readers with this point again.
Zz.
AM
It is very debatable that any good theory does more than provide utility, or that there is an objective reality that can be understood in any meaningful sense.
(For example, tell me ANY physical theory that explains reality in a way that folks will say, hmmm, now I completely understand that. GR gives us a nice pretty picture, for example, but how does it explain reality any more than QM does?)
The problem with QM is that it is basically two theories stuck together in an incomplete way. You have the usual unitary evolution of states, which is nice and elegant. But you also have a completely separate process of measurement, which cannot be applied in an unambiguous way. It is certainly true that for a large class of experiments, people have learned what a measurement is (i.e. how to apply the formalism in a way that matches experiments). This has obviously been extremely useful, but is also incomplete.
The measurement postulates cannot be applied uniquely in any imaginable situation. If QM is a fundamental theory of physics, it should describe everything. In principle, it should be possible to remove any external "classical experimenter." Does the whole system then evolve unitarily? How would that be reconciled with the fact that we seem to need the projection postulate experimentally? Is that just an approximation when a large number of degrees of freedom are involved?
The resolutions of these problems will (probably) not have any profound influence on "practical" physics, but that doesn't remove their importance.
I disagree. This is because the quantities we measure are classical! Position, momentum, energy, etc. are all "classical" quantites that we inherited out of classical mechanics. QM is simply telling us what they are if we insist on using these quantities. (Again, square objects being forced through round holes).
Unless we want to invent a new set of quantites and concepts, we're stuck with these classical ideas. If you have followed this thread, you'll know how DIFFICULT it is to make some people part with their beloved classical quantities.
Tony Leggett recently wrote a terrific article summarizing the so-called "measurement problem" of QM, and in particular, the Schrödinger Cat-type phenomenon (it is no longer a "paradox").[1] I strongly suggest people who insist that there is a "measurement problem" to read this, and his other paper in J. Phys. Cond. Matt. to look at the wealth of experimental observations and how they compare to what we know about what QM is saying.
Zz.
[1] A.J. Leggett, Science v.307, p.871 (2005).
Good point. A theory simply reduces a lot of little things that we didn't understand to fewer bigger things that we still don't understand: like Newton's laws which explained why things move the way they do in terms of forces and inertia.
And no doubt about it: QM does reduce a lot of little things to fewer rules and principles. The problem is that, unlike force and inertia, people lack an intuitive grasp of what these rules and principles mean physically. I long ago concluded that one should not expect to have that intuitive grasp of QM as the world at that level is quite beyond our experience.
But I don't think it is wrong for people to find QM's explanations unsatisfying. I should think that any good physicist would always want to improve understanding of the physical world. One can't do that if one is completely happy with all the current explanations of things. So that is why I complain about people who complain about people complaining about the 'unsatisfactory' explanations that QM provides.
AM
AM
But then you miss the point of my complaint about people who complain about QM. There are ways to "complain", and just saying it based on a matter of tastes is NOT the way to complain about ANYTHING in physics, and not just QM. If you complain about E&M based simply because you dislike the idea of "fields", I would complain about your complaints too. This has nothing to do with QM. It has everything to do with how one challenges ideas in physics.
You cannot base it on "intuition", or "intuitively easy". Your intuition changes all the time as you gain more knowledge. What was intuitively difficult when you were 18 can be intuitively obvious when you're 30. So just saying QM is intuitively difficult (especially for the masses) should be completely irrelevant. Nature owes none of us any explanation on why she behaves that way. To force her to fit into our "intuition", as limited as it is, is plain arrogant. As scientists, that's the worst mistake we can ever do.
Zz.
Classical theory leaves a lot of open questions, which, typically, we don't consider often:
Whence electric charge? Why is it quantized? Why do protons and electrons have charge that is equal and opposite?
Why is the speed of light what it is?
Why is gravity, under normal human conditions, weaker than the other forces in nature?
Why does F = dP/dt?
Why are so many repeated measurements the same, relative to standard measurement error?
Why does the sun come up every day?
What is mass?
Does the elecromagnetic spectrum include arbitrarily large frequencies?
Relative to human scales, why are stars and galaxies generally so widely spread?
How, albeit under extreme circumstances, can a single person lift a car?
Why does probability work?
Why is there regression to the mean? (That is, why does statistics work?)
Why do some heavy smokers not get lung cancer?
Why is there so much nonlinearity in the world?
Why don't our children follow our superb advice?
And, on and on.
Life is full of mysteries. To suggest QM is inadequate because we do not understand the measurement process is to miss the point. Classical probability and statistics, as used in practice, suffer from the same problem, that is collapse. Prior to a coin toss the probability of a heads is 1/2. If the toss comes up tails, then the probability of tails is 1, and he probability of heads is 0. Looks like collapse of the probability to me -- not much different from measuring whether spin up or spin down.
Classical or quantum, science and physics are imperfect, but they do give us a beacon of light into the void -- and, from my own experience, that is a great gift as one gets older. Life is full of mysteries. You do the best you can with what you've got.
Regards,
Reilly Atkinson
Crosson said:
but the fact is that QM was guided more in its development by experiment than by actual physics.
What?? Physics by definition develops by experiment. Saying Einstein didn't use experiment is rediculous - he just wasn't the one doing the experiments. The first page of his paper on special relativity are the Lorentz transformation equations, which are based on maxwell's equations, which are 100% experimentally derived.
There is no part of physics that does not rely on experimentation, whether before or after, and without experimentation we'd still be in the dark ages. Assumptions and hypothesis are all well and good, but they require experiment to verify them. Einstein had the habit of guessing first and testing later (with exception maybe of his experiments in photon absorption), and this ended up making him wrong very, very often, and right very, very rarely. I guess if we remember his hits and forget his misses we are to be impressed?
Saying that zapperz is impeding physics is amusing, given his employment and the hard work he does on these forums. I would love to see who had contributed more to physics, Crosson or Zapperz.
reilly said:
As far as I can figure out, classical probability is as subject to collapse as QM. That is, measurement simply tells us at that moment what is, whether an electron in a scattering experiment, or the price of IBM stock, a sales forecast, or what you will have for dinner in two weeks.
Yes, the notion of "collapse" can be applied to classical scenarios. However, in order to put quantum "collapse" on equivalent 'footing', one must be prepared to accept as true the physical existence of "hidden variables". If "hidden variables" do not physically exist, then any 'induced' change in the quantum state-vector implies a corresponding physical change in the status of the system in question. ... I see no way around it (... except perhaps to 'deny reality', whatever that is supposed to mean).
______________
reilly said:
There's one thing I've never understood about the Schrödinger cat problem. It has nothing to do with QM, and everything to do with standard probability matters.
Again, this standpoint is consistent with a "hidden-variables" perspective. But from the alternative perspective (i.e. "hidden variables" do not physically exist), the Schrödinger-cat scenario has everything to do with Quantum Mechanics, and nothing to do with standard probability matters.
To see that this is so, consider – from the "no-hidden-variables" perspective – the following:
Suppose that a quantum system is in the state
|ψ> = (1/√2) [ |φ1> + |φ2> ] ,
where the states |φ1> and |φ2> are eigenstates of an observable which we can physically measure.
(Remember, we are assuming here that there are no "hidden variables". The state vector gives a "complete" characterization of the physical state of the system.)
Now, what do we want to say about this situation? Do we want to say that the quantum system is not at all actually in the said (physical) state of superposition, but that it is, in fact, in one or the other of the (physical) states |φ1> or |φ2> with probability equal to ½ ?
... Certainly NOT![/color]
From this perspective, then, the Schrödinger-cat scenario is a challenge to the following contention:
The quantum-mechanical state-vector description can be meaningfully applied to systems of arbitrary "size" and "character".
But the challenge is raised only in the context of no "hidden variables".
______________
I recently read an essay of Leggett's written some time around the mid to late 80's in which he discussed the "Measurement Problem" with a great deal of care. In that essay, he suggested "the possibility that the complexity of a physical system may itself be a relevant variable which may introduce new physical principles." I am excited to find out what conclusions he has now reached some two decades later. Thank you for posting the above reference, ZapperZ (and also for the many others which you have posted).
... Can you be more specific about the J. Phys. Cond. Matt. paper?
The reference to the J. Phys. paper is one of the papers Leggett cited in his Science article. It is a more in-depth look at the Schrödinger Cat-type scenario, especially in light of the Delft and Stony Brook's recent experiments using SQUIDs.
Zz.
Zz.
Thanks! :smile:
Then what should be measurable? Any physical theory must describe what its variables mean in some (operational) sense. If those variables can only be described by mixing QM and classical mechanics, then this is itself a type of incompleteness. Or are there measurement types I'm not aware of?
Also, thanks for the reference. I'll take a look at it.
We can measure typical QM quantities:probabilities with which certain eigenvalues occur and (integral) cross sections...What else is there to QM...?
Daniel.
"The Schrödinger Cat-type phenomenon (it is no longer a "paradox")."
Forgive me if I am a little bit skeptical about these sorts of matters. The paradox of Schrodingers cat ultimately is the problem of resolving when a quantum state becomes a classical one, and last I checked there is still wars going on in the measurement camp about these thorny issues. Taking to the extreme you end up with one of two scenarios.
1) Everything is quantum, classical behavior is just an emergent illusion. Ergo notions like the wave function of the universe become acceptable, despite their known enormous failure in various field theories and quantum gravity.
2) Something weird happens and there is some sort of phase change between quantum to classical mechanics. Perhaps its something not accounted for, or some tiny effect that only becomes important in the huge complexity of interactions. Eg people can't, under any circumstance, walk (tunnel) through walls.. The probability isn't just 1e-50502, but identically zero.
The problem here is that ALL our measureables or observables are classical quantities. This is what I have been trying to stress all along. We have no other alternatives (so far). QM is our description of a world beyond classical physics USING classical physics concepts. When we do that, OF COURSE some things will simply make no sense based on our classical measurement. Our squares and cubes came through the round holes with the edges chopped off, and we struggle to still want to call them squares and cubes when they do not look quite like squares and cubes. They look funny to us. So we blame the round hole and forget all about the fact that we were forcing incompatible shapes through the round hole.
With this in mind, I do not worry about the "measurement problem", the Schrödinger cat, the EPR-type measurement, the "collapsing" wave function, etc.. etc. It is what it is, and that's what Nature has decided to reveal herself so far. I have accepted and am aware of my prejudice of trying to describe nature using concepts that may not be accurate. I use the formalism, but pay more attention to the experiments. As far as I'm concerned, in the end, that is the only thing that matters.
Zz.
ZapperZ, I like what you say here:
In my opinion this is the progressive approach we need to take towards QM. Take for example the particle-wave duality; what we need is a new concept, not a bunch of people saying "Sometimes its a particle and sometimes its a wave and that's just the way it is".
Energy and momentum observables are already predicted very well by QM, there is no reason to change this. We know energy and momentum are conserved quantities, and that they obey the quantized hamiltonian relationship. But unlike the state of affairs in classical mechanics, all we know in terms of experiment is that energies are proportional to the frequency of photons.
In terms of the thing we are describing, energy is not defined (without resorting to a circular definition relating momentum and energy, or the relation of "energy" to the frequency of emitted photons rather than the system we are talking about).
A separate criticism of QM which I have not brought up (because physicist seem to attack philosophers) is determinism. In my mind QM is a theory of observations, and so in cannot make claims concerning determinism. But many people embrace the idea that QM makes the universe indeterminate, and this is:
1) Not supported by experiment or quantum theory (as I read it).
2) Physically appaling, in that an indeterminate event is necessarily uncaused.
Because it is a theory of observations, QM involves indeterminate events and fails in not describing explicit causes.
Keep in mind that I know QM proves that the universe is indeterminate for an observer, but that does not rule out determinism. (indeed, it was clear from classical chaos that it would never be possible to actually predict the future this way)
I define determinism as: The present corresponds to only one future.
You have mentioned two separate aspects of the so-called Schrödinger Cat paradox. Again, most of the stuff that I have mention (and will mention here) are contained in Tony Leggett's paper, including the full treatment in his J. Phys paper.[1] I said that the Schrödinger Cat scenario is no longer a paradox because (i) it does truly occur at the QM scale.[2,3] These have been unambiguously verified.
The issue that's left, which is the 2nd part of your point, is why don't we see it at the macroscopic scale. I do not see this as another "paradox" because while it is still an active research area, we have plenty of indications of possible explanations for such dichotomy. We have seen how classical system emerges into the classical observation via careful and controlled decoherence.[4,5] Not only that, there are every indications that the emergence of "objective" properties come out of a "selective" destruction of quantum coherence, resulting in what is known as preferred pointer states.[6] This is what eventually results in what we perceive macroscopically as an "objective" and deterministic universe.
I am far from claiming this is a done issue. I just do not see this as being a "paradox" anymore as if these things simply have no explanation whatsoever. In fact, there exists many plausible explanations that connects the evolution from quantum states into classical observations. We just need more experiments to verify them convincingly.
Zz.
[1] A.J. Leggett, J. Phys. Cond. Matt. v.14, p.415 (2002).
[2] J.R. Friedman et al. Nature v.43, p.406 (2000).
[3] C.H. van der Wal et al. Science v.290, p.773 (2000).
[4] K. Hornberger et al. PRL v.90, p.160401 (2003).
[5]C.J. Myatt et al. Nature v.403, p.269 (2000).
[6] H. Ollivier et al. PRL v.93, p.220401 (2004).
______________Again, this standpoint is consistent with a "hidden-variables" perspective. But from the alternative perspective (i.e. "hidden variables" do not physically exist), the Schrödinger-cat scenario has everything to do with Quantum Mechanics, and nothing to do with standard probability matters.
I have no clue why I would need hidden variables to suggest a correspondence between classical and quantum notions of probability. So, I would be most grateful to find out what I'm missing.
Because I've worked in the consulting business for years with probability and statistics, and in my younger years for some time as a particle theorist and teacher of QM, I've concluded from practical experience that the two probabilities are, generically the same. In fact, what made and makes sense to me is that the probabilities are statements about our knowledge, as, more or less, suggested by von Neuman and Wigner. The troubling collapse is a reflection of changes in our knowledge.
Subsequent to the long time it took me to come to this conlusion, I discovered that the great physicist, Sir Rudolph Peierls, agrees -- or, really I agree with Sir Rudolph -- with the knowledge interpretation. In Andrew Whitaker's book, Einstein, Bohr and the Quantum Dilemma(1996), Peierls " a theoretical physicist of massive achievements" In response to Bell's "Against Measurement" (1990), Peierls writes:
In my view the most fundamental statement of quantum mechanics is that the wavefunction, or more generally the density matrix, represents our knowledge of the system we are trying to describe.
Whitaker quotes more, but I shan't bore you, Whitaker's book is a review of the history of QM, particularly of QM interpretation -- Bohr to Bohm to Everett and more. The book is a very impressive piece of work.
Peierl's ideas make great sense to me. Again, quantum or classical, you don't know until you measure. Why, if we, say, see a boat sail out to sea, to vanish over the horizon, do we say we know the boat, in all probability, continues to sail after we lose sight? After all, we cannot see it. (Not a bad question for a PhD candidate's oral exam.)
With a spin doublet, superposition, according to Peierls, just says there are two possibilities. To work backwards seems to me to be an exercise in futility. Why should nature follow our conceits? I always thought science and physics were about nature, not about man's preconceived notions, whether ego driven or not.
If you don't like QM as it is, find a better way. Explain the electron microscope, or semiconductors some other way. So far, nobody has come close, and I find that very telling -- even though I'm not so foolish as to maintain there can't be a better way.
I posed a set of questions a post or two above. Why has no one dealt with them? I find that rather odd, given the lofty thoughts about the inadequacies of QM. QM ain't the only problem.
I remain a servant of Nature.
Reilly Atkinson
