The discussion revolves around the phenomenon of humps appearing in the spectrum of distorted sine waves after performing a Fast Fourier Transform (FFT). Participants explore the implications of wave distortion, particularly through clipping, and its effects on the resulting frequency spectrum.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant notes that the spectrum of a clipped sine wave resembles a combination of a sine wave and a square wave, depending on the extent of clipping.
- Another suggests that clipping introduces a DC component and that the finite duration of the flat top created by clipping may contribute to spectral dips.
- A later reply emphasizes that the spectral graph can be misleading due to the dB scale, indicating that the energy outside the fundamental frequency is relatively low.
- One participant posits that the asymmetrical clipping raises even harmonics and the DC component, while questioning the role of duty cycle in the observed humps.
- Questions are raised regarding the anti-aliasing filter, window function, and whether the A-D sample contains an integer number of cycles, suggesting these factors may influence the spectral characteristics.
Participants express various viewpoints on the causes of the spectral humps, with no consensus reached on a singular explanation. Multiple competing theories regarding the effects of clipping and sampling are presented.
Participants acknowledge that the relationship between clipping, sampling, and spectral output is complex, with assumptions about symmetry and duty cycle affecting interpretations. The discussion highlights the need for careful consideration of signal processing principles.
This discussion may be of interest to those studying signal processing, physics, or engineering, particularly in the context of waveform analysis and Fourier transforms.
