Why do waves carry energy momentum?
  • Context: Undergrad
  • Thread starter Thread starter yavuznuri
    Energy Momentum Waves
The discussion centers around the question of why waves carry energy and momentum, exploring both classical and quantum perspectives. Participants examine the implications of wave behavior in various contexts, including mathematical formulations and physical phenomena.
  • Some participants suggest that waves must carry momentum to apply a force and ensure conservation of momentum.
  • One participant introduces a metaphor involving dominoes to illustrate the concept of momentum transfer in waves.
  • A mathematical perspective is presented, referencing de Broglie's postulation and its alignment with conservation principles in quantum mechanics.
  • There is a distinction made between classical waves (such as water and sound waves) and light waves, with some participants emphasizing the relevance of both contexts.
  • Some argue that the relationship between momentum and wavelength proposed by de Broglie is a mathematical postulation that effectively describes observable phenomena, while others assert its physical reality.
  • One participant notes that the de Broglie hypothesis is foundational to Schrödinger's equation, but questions the understanding of its cause versus its empirical success.
  • Another participant emphasizes that waves carrying momentum is a classical phenomenon, asserting that classical mechanics can explain momentum transfer without invoking quantum mechanics.
  • There is a call for an intuitive explanation that connects classical and quantum expressions for momentum, indicating a desire for clarity in the discussion.
Participants express differing views on whether the discussion pertains to classical mechanics or quantum mechanics, with no consensus on the primary focus. Some argue for the sufficiency of classical explanations, while others advocate for the relevance of quantum mechanics, leading to an unresolved debate.
Participants highlight the potential confusion arising from mixing classical and quantum perspectives, indicating that the original question may not have been clearly defined. There are also mentions of the necessity of mathematical postulations in understanding physical phenomena, without resolving the implications of these postulations.
yavuznuri
Would you please tell me about why do waves carry energy momentum?
Because waves are able to apply a force. Thus they must carry momentum to ensure momentum is conserved.
Claude.
Think about dominoes for a bit, you'll get it.
Is that the matter force we should consider only or smt another..Or do anyone can explain this with maths...
In a mathematical view, it's just a postulation proposed by de Broglie. Later physical experiment had proved that wave could interact with particle and de Broglie's postulation accords with the basic conservation principles. It then became one of the cornerstones of quantum mechanics and works fairly well in predicting further phenomena.
In detail, according to the concept of wave-particle duality (mathematically this is justified by Fourier transformation), a wave should have momentum and energy which are the main properties of a particle, so that it can interact with particle like that in Compton scattering.
I thought this thread was about classical waves: water waves, sound waves, waves on a string, electromagnetic waves...
lets consider light waves my friend ..
My point is that it's just mathematical postulation. But it works well in accounting for the real-world phenomena. Like in the sun, the "light pressure", which is from the exchange of light's momentum, prevents it from collapse due to gravitation.
De Broglie hypothesised than momentum was related to the wavelength of a particle. He was by no means the first to apply the concept of momentum to waves.
Also, I don't know why you insist that it is "just mathematical postulation", the effect is quite physical and readily observable.
Claude.
If my knowledge is correct, the de Broglie hypothesis is part of the foundation of Schrödinger's equation. Logically, it is the cause of those "physical effect" via the Schrödinger's equation, but I think the original question of this thread is for the cause of this hypothesis, and that is just mathematical postulation that is necessary for its conclusions. We believe it is true not because we understand its cause but we have seen that its derivations fit well with our experience and we have been quite satisfied and not too stringent.
1) Yes- it's a consequence of conventional quantum mechanics. It doesn't require an extra postulate.
2) It's really due to the invariance of the wave-function to overall translation which can be shown to require that there exists a conserved quantity (which turns out to be the momentum) related to the FT of the wave-function.
3) It's not intuitively obvious that the quantum expression for the momentum should reduce to the classical expression (e.g. as hbar->0), but the math tells us this is so.
This isn't a complete answer. Maybe someone can come up with an intuitive (non mathematical) explanation connecting the classical and quantum expressions for momentum.
Waves carrying momentum is a classical phenomenon (in addition to a Quantum one). I can get the end of a yo-yo to jiggle around if I jiggle the string (i.e. transfer momentum via a wave) - and I can explain it all using Newtonian mechanics. In fact, this can be done for any classical wave by regarding change in momentum as the integral w.r.t time of impulse.
Long story short, if a wave applies a force over some finite length of time, it must carry momentum.
Invoking QM is therefore unnecessary in order to answer the OPs question and will only serve to confuse the issue.
Claude.
Claude: reviewing the replies it seems that it's not clear whether the OP was talking about QM or CM. I'm still not sure!
I don't think it helps much to criticize others answers for possibly missing the point.
After all, we're here to have fun!
I agree, but then again most classical phenomena have a quantum equivalent, in most cases (especially if it is posted in the classical physics section) when someone posts a question about a phenomenon that can be discussed from a classical standpoint - Introducing QM into the picture is an unnecessary complication.
I agree that undue criticism is unwarranted, but by the same token, if something is posted that is wrong or misleading - it ought to be challenged.
And learn too!
Claude.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 60 ·
  • · Replies 34 ·
  • · Replies 29 ·
  • · Replies 39 ·
