fxdung said:
When field is excited then it create a particle. A mode of excited field can consider as a particle (a quantum of field). But in the book QFT of Zee, he say that a particle is a "packet wave" of field. So I do not understand because a "packet wave" is a set of many modes. Is it correct that only when "particle" enters the measure machine it become "packet" (point particle) so when we observe the experiment we see "point particle"? Is that Zee want to say?
Let us use a radio transmitter to send a wave packet containing just one photon of a wavelength 1 meter to space. Suppose that an observer in a rocket approaches us almost at the speed of light. He might measure the photon wavelength as 1 micrometer. He is holding a photographic plate where a very small dot appears.
Did he prove that the photon is a "point particle"? The wave function of the photon "collapsed" into a small dot on the photographic plate.
The photon is a "point particle" just in this sense, that in a measurement, the energy of the photon is found in a small patch of space.
If we point a red laser towards a slit of width 100 nanometers, some red light will pass the slit. We were able to measure the horizontal position of a 700 nanometer photon at the accuracy of 100 nanometers. If the photon arrived in a wave packet, after this measurement, the new wave packet has a new form. It will diffract strongly when it comes out of the slit. In this case, a spatially large wave packet "collapsed" into a narrow wave packet which will spread very rapidly after the slit.
I like to think that a photon is a wave, but when we do an experiment, we may force the wave to print, or output, a precise position in space.
Bell's inequality bans simple hidden variable theories. The photon did not have any precise position before the measurement. It was not a point particle.
What about the electron? We can measure the location of a high-energy electron very precisely. But since the electron has a spin and a magnetic moment, we cannot imagine it as a classical point particle. A point does not spin.
In my physics blog, I have described my efforts during this spring to find a Feynman path integral type description for the electron as a point particle or a billiard ball. I was not able to find any intuitive model. I had to settle with the fact that the electron is a wave which is described by the Dirac equation. The wave can under a measurement output a precise location in space, but it is not possible to think of it as a classical point particle. No one has found an intuitive physical model for the Dirac equation. The equation is a result of a mathematical trick which seems to lack a physical interpretation.
