Why do we need setup and hold time?
  • Thread starter Thread starter likephysics
    Time
Setup and hold times are crucial for flip-flops to ensure accurate data sampling and state switching. When an input signal is applied, it takes time for the input capacitors to charge or discharge, which can lead to incorrect voltage levels if not accounted for. Setup time allows the input to stabilize before sampling, while hold time ensures the output remains stable long enough to reflect the new input state. Variations in setup times can occur between different flip-flop families, even with similar input capacitance. Meeting the required voltage criteria at internal nodes is essential for reliable output, preventing premature state reversion.
likephysics
Why do we need set up and hold time in Flipflops?
After you apply the input signal it takes some time to charge/discharge the input capacitors. Before that the input nodes will have wrong voltages. Thus set-up time is required to fully prepare the input for sampling.
Flip-flops are bistable devices. However to switch the state you need to drive the gate for a finite time. If your input is short, the output will revert back to the original state. Thus we need hold time to successfully switch the state.
I looked up datasheets of flipflops with same input capacitance but of different family (HC and AC).
The max clock frequency and hence the set up time are different.
74HC73 and 74AC109. Both have 10pf input capacitance for data line. But setup times are different.
The input capacitance sound good when you think of cmos gates. But it's not the same with TTL gates.
its not just capacitance at the input, but the internal capacitors of the intergrated circuit need time to work too
You need certain minimum/maximum voltages at certain internal input nodes (gate node etc.) on the chip at the moment of application of clock. Even if you don't meet that criteria your output will still try to change but before it reaches the desired value it will revert and go back to the initial value. When you have met those criteria you are sure to get the desired output no matter what happens at intermediate time.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
9K
  • · Replies 32 ·
