Why does a balanced beam stay horizontal if torque is zero?
  • Level: Undergrad
  • Thread starter D.R.U
    Balance Beam
7 replies · 3K views · last reply
D.R.U
I have already balanced beam both side two same mass at same distance and it is pivot on its center of gravity...so torque is zero so no rotation possible by gravity on earth......so why beam always be horizontal to Earth surface...after give inclination to Earth surface.....potential energy not make it...because p.e is energy not force...motion is cause by force...So Why This HAPPEN?
It is not easy to really understand your post, but from what I can tell you are wondering essentially why a balanced scale goes to horizontal.
The answer to this depends on the scale but typically boils down to that when the scale is tilted, the center of the beam is slightly offset from the support, resulting in a net torque around it. The scale should be constructed in such a way that this torque tends to be restoring or you will have problems in using it.
Ok friend... they make slightly offset...okey.Tell me...if there is no offset of center of beam,then what happen?
Can you give my other question answer...which I posted abut pascal law...
Thanks
If the point of support is the very same as the center of gravity, then the scale will stay in whatever position you put it.
Hey can you give me idea about how they are making this kind of offset?
