Why Does a Mercury Droplet Split Under Electric Field?
The discussion revolves around the phenomenon of a mercury droplet splitting under the influence of an electric field, exploring the underlying mechanisms and contributing factors. Participants examine various theories, including the roles of electromigration, electrowetting, surface tension, and joule heating, while considering experimental conditions and setups.
  • Some participants suggest that heat might play a role in the splitting of the droplet, similar to how a wire can melt under sufficient voltage.
  • There is a proposal that the phenomenon could be explained by a competition between electromigration and surface tension, where conducting electrons impart momentum to the molecules in the droplet.
  • One participant raises the question of whether continuous electrowetting could influence the behavior of the droplet, noting its similarity to electromigration.
  • Another participant clarifies that electrowetting and electromigration are distinct processes, with electrowetting involving changes in surface tension due to an electric field.
  • Discussion includes the potential impact of the droplet being in an electrolyte bath, which may affect heat transfer and the overall behavior of the droplet.
  • Participants inquire about the geometry of the electrodes and the applied potential, suggesting these factors could influence the outcome of the experiment.
  • One viewpoint posits that the interactions between electrical current and its magnetic field may dominate over surface tension effects, leading to the droplet's splitting behavior.
Participants express multiple competing views regarding the mechanisms behind the droplet's splitting, with no consensus reached on a singular explanation. The discussion remains unresolved as participants explore various hypotheses and conditions.
Participants note limitations in their understanding, including the need for specific experimental parameters such as the total current, applied potential, and the geometry of the electrodes, which may influence the results.
yasha
I recently saw a phenomenon wherein a metal droplet was stretched and stuck between two electrodes that it wet to. Upon applying electric field, the droplet split into two. ANy idea why?
could it be heat? If you pass sufficient voltage through a wire it will heat, melt and drop; could the same apply to the viscosity of a mercury droplet?
Repeat the experiment 20 times. Does the same thing happen every time?
Is your question: Why did the droplet split in two rather than conducting the current?
One wild explanation: a competition between electromigration (the electron wind) and surface tension.
Conducting electrons impart momentum to the molecules in the droplet whenver the electrons scatter. If the droplet cross-sectional area is not uniform, you have a mechanical force on the molecules in the droplet. I would suspect electromigration in a liquid would be much faster than in a solid.
Surface tension would still keep one portion of the droplet attached to the initial electrode after the droplet split (After the fuse blew).
It seems like a plausible explanation. I was wondering if Continuous electrowetting would play a role here. (which sounds a lot like electromigration).
Electrowetting and electromigration are different. Electromigration is imparting momentum to atoms from current-carrying electrons. Electrowetting is changing surface tension due to an electric field. The wiki says electrowetting is usually with Fluoropolymers - which are quite different than Mercury.
Maybe simple joule heating and Fuse-like behavior could explain it. What was the total current in the circuit?
Electrowetting seems like an established phenomenon in liquid metals in an electrolyte bath . (I forgot to mention that the setup was in an electrolyte bath). Are you saying that the current being carried through the circuit causes the droplet to split?
Seems like there is quite a bit of literature out there about electrowetting.
The Hg being in a electrolyte bath would allow faster heat transfer to the solution than the air, an indication against the hot-fuse idea.
What is the geometry of the electrodes: are they planar surfaces much larger than the droplet? or are they small wires much smaller than the droplet?
Surface roughness of the electrodes could also play a role.
What is the applied potential (V)? field strength (V/cm)? Initial current (A) vs steady state current (A)?
The forces responsible for surface tension and similar phenomenon are small compared to the interactions between the electrical current and it's own magnetic field, if the current between the electrodes is non-trivial.
if you have two parallel wires and you run current through both in the same direction then they will be attracted by their magnetic fields. A drop of liquid metal bridging the gap between two electrodes can be thought of as a collection of many many very tiny wires in parallel. So when the current flows they are effectively all trying to squeeze together tighter. If the drop were to somehow become slightly hourglass shaped than the current will be more dense in the narrower part. Thus, the squeezing-ness will be stronger in the narrower part. You can see how this would lead to the drop of mercury pinching itself into two smaller parts.
Obligatory YouTube link:
Read the video description.
