Why does a nozzle create a reaction force in the flow direction?
51 replies · 41K views · last reply
Timtam
I have been reading many examples of control volume calculations regarding nozzles
They all end up with a reaction force on the nozzle in the direction of the flow.
I can't understand this from a Conservation of momentum perspective.
I would expect that the reaction force, by Newtons third law, would be opposite the mass that was accelerated in. This is how many people explain it but it doesn't equate with the control volume result.
Can anyone review my attempt at a solution and critique
Attempt at a solution
It appears the resultant force has nothing to do with the flow acceleration or pressure drop
Much like the flow around a bend, it is due to the change in flow direction.
More specifically, it is the x direction components of the resultant force due to the angle of the nozzle changing the flows direction.
(Y direction components being equal and opposite directions cancel out.)
Why doesn't the flow "acceleration" require a resultant force?
Even though the velocity of the fluid has increased at the nozzle, the flow has experienced no 'real' acceleration so no resultant force is required.
While the velocity at P2 has increased, the volumetric flow rate Q has not. It has only changed in area and by continuity- velocity has increased.
The x-direction flow rate Q into and out of the control volume is the same - so there is no acceleration.
The pressure gradient force?
The flow rate Q is fully accounted for by the pressure difference P1-P2 over the original area
Why do firefighters brace a hose forward ?
I don't think they do I think they actually brace it down.
This is because a hose initially runs along the ground then up the firefighter.
So again there is resultant forces from changing a fluids direction initially up (the resultant force is provided by gravity and against the ground) once it is traveling up to make it horizontal again the firefighter must provide a downward force above the hose to change its direction downward again.
How so ?
Check this one
Nobody would try to use a nozzle that isn't solidly connected to the hose, right ?
The firefighter has nothing to do with it. Unless he has to use a hose where the nozzle isn't fixed -- and that's hopeless.
If the nozzle is of smaller diameter than the hose (usual setup?) then the water will be accelerating as it goes through the taper and emerge at a higher speed than it had in the hose, which involves a forward force acting on the water as it flows through. That will require a constant reaction force on the hose to stop it moving backwards. This is the same principle as a rocket or jet engine.
It is not necessary to consider the details of the passage of the water and the details of the pipe / nozzle to get a good, near enough answer. All that's necessary is to know the entry and exit diameters and the flow rate (and density of course).
Edit: the direction of the nozzle will affect what actual force is acting on the nozzle. If it is pointed at right angles to the hose then forces on the hose will cancel and all the reaction force will be on the nozzle. If the hose and nozzle are totally aligned, the reaction force will be upstream, on the compressor only. So you could say that the fireman is needed in order to control any lateral force.
That link above explains it well.
Hi @BvU yes that link gives the same answer- it is to the right. You will have the same volumetric flow rate no matter what the size of your nozzle is or whether you have any shape in the control volume at all - in the x -direction the only thing that can change the control volume flow rate Q is the original diameter in and P1-P2
@sophiecentaur yes that is what I thought as well but the reaction force is to the right -forwards not backwards.
The answer is 'to the right' and that is 'backwards' i.e. in the opposite direction to the direction of the water jet. Let's face it, whatever the details, Newton's Third Law has to apply. What I was meaning is that there will be a backwards 'reaction force' because the water is moving forwards BUT the fireman has to resist this force with a forwards Reaction force of his own, to stope the nozzle going backwards due the the 'first' reaction force. :smile:
sophiecentaur said:
The answer is 'to the right' and that is 'backwards' i.e. in the opposite direction to the direction of the water jet. :smile:
I am so confused by this- to the right is in the direction of the flow. I had a look at @BvU example and that says the same what am I missing that this somehow becomes to the left?
@sophiecentaur the nozzle examples in my attempt at solution are all facing right- The fireman picture in the next section is to explain what I think the fireman is actually bracing against
Have a look at the link @BvU provided if you want to be as confused as I am
BvU said:
How so ?
Check this one
How can you say that ? ##\dot m## is the same and ##v## increases considerably. That's what we call acceleration.
The upstream pressure is higher than the downstream pressure (Bernoulli). If fluid pressure is acting on the wall of the nozzle (this is the only force acting on the wall), it acts perpendicular to the wall. This means that there is a resultant pressure force on the nozzle wall in the same direction that the fluid is flowing.
Just imagine what would happen if you cut the pipe just behind the nozzle. I think it's obvious that the nozzle would be propelled strongly in the direction of the water by the forward water pressure inside the walls of the restricted part. However, if you take the whole system of supply, pipe and firmly-attached nozzle you would expect it to be propelled the other way. I don't see any contradiction in that.
In the latter case, if the hose were perfectly straight, the nozzle would not be propelled at all.
That argument sounds convincing until you consider the momentum transfer situation. On the way out of the nozzle, the velocity has increased and the mass flow rate is the same so doesn't that mean momentum has increased on the way through the nozzle? That requires pressure / force and, if the nozzle is pointing off the axis of the hose, there would be a force away from the direction of the jet. The same thing happens with a rocket (doesn't it?) where net reaction force on the inside of the combustion chamber produces a driving force.
The pressure consideration also needs fluid velocity and/or an area in order to work out the Force
The combustion chamber is closed at one end, and the nozzle is expanding in the flow direction, not narrowing like on the hose. That's where the propulsive force acts:
In the case of the hose those pressure forces act on the upstream fluid, not the nozzle. The net pressure force on the hose-nozzle itself is with the flow.
The only force that the fluid exerts on the nozzle body is pressure. The momentum increase of the fluid affects the fluid pressure upstream within the nozzle, but, treating the nozzle as a free body, it is only the fluid pressure that determines the axial force on the nozzle (aside from the tension at the hose connection). As long as the fluid pressure within the nozzle is higher than the pressure outside the nozzle, the axial force that the fluid exerts on the nozzle will be in the positive flow direction, irrespective of what is happening with the momentum exchanges of the fluid.
Certainly the momentum increase affects the pressure of the fluid within the nozzle. But, as far as the nozzle body knows, it is only the fluid pressure that it feels.
Yes - there is a difference but isn't that because of the expanding gases in the case of a rocket? There is still acceleration of the water in the nozzle and acceleration requires a force in the direction of that acceleration. That force must have an N3 companion. Where does that act? I suggest backwards, or we have a new method of propulsion.
This video might be of interest if people think the force on the nozzle is forward. The end of the hose does just what the above link predicts.
On the upstream fluid, as already explained.
This tells you nothing about the pressure force on the nozzle, because there is also hose tension acting on the nozzle. The relevant experiment would be to separate the nozzle off the hose, as already explained.
Those two quantities are not the same so they can't be equated like that. The force is, of course, due to the water pressure but not just the static pressure. The fact is, there has to be an N3 pair somewhere, to explain the acceleration of the water exiting the nozzle. You have to agree that it is going faster at the tip than through the hose. If you can't address the N3 issue then you have no valid explanation.
You are right in your initial assumption about what happens when the end of the hose is blocked off (the static pressure will cause a force that could push the end off the hose or just burst it).
I have written a number of replies to this but they have all sampled too much. Bottom line is that there is a force acting on the hose in that video (and many more), that makes it snake from side to side. You can do the experiment with a normal garden hose, with a natural curve in it and held a metre or so from the nozzle. The nozzle moves away from the direction of the jet. A force acting only on the inside of the nozzle would simply stretch the hose and make it straight - as in blowing up a sausage balloon. The force which causes this snaking is from side to side and not forward. It has to arise from the Bernoulli effect at the nozzle exit and it is not in the direction of the hose.
You could achieve the same sort of motion as in a Hero Steam Engine, using water instead of steam. The same N3 explanation would apply.
The above link with the curved nozzle calculation is pretty straightforward and accounts for all of this, doesn't it?
BvU said:
How can you say that ? ˙mm˙\dot m is the same and vvv increases considerably. That's what we call acceleration.
Agreed I could have said that better. Ok in your control volume - As others have suggested, take away the nozzle all together (or replace it with a solid wood block)- assuming the entry fixed is and the exit parameters are fixed so keeping the pressure difference-The "acceleration" the parcel experiences is only due to P1 and P2.
but the control volume experiences the acceleration within it , we should see the Resultant force in the total force calculations but we don't
There simply isn't a resultant force to the left shooting upstream as assumed.
I think the problem with these control volume examples is thru continuity P1/u1 isn't fixed it is a direct relationship to P2/u2 and A1/A2
Some supposed further upstream pressure P initial is fixed however and so is the atmosphere. P final.
In a perfectly straight pipe two things can happen when you close/attach the nozzle - either the Pinitial works harder against the resultant force downstream to keep u1 ~P1 increases or P1 P initial stays the same and u1 drops
P1,u1 will be different whether the nozzle is there or not. The resultant force of the fluid acceleration is always accounted for by the pressure difference That is frustratingly never explained in Bernoulli's
I stand by what I said. There is a pressure difference between the inlet and outlet of the hose, with the upstream pressure higher than the downstream pressure. Part of this pressure difference is expended in balancing the backward force exerted by the nozzle body on the fluid. The remainder of the pressure difference is used to accelerate the fluid from the low upstream velocity to the higher fluid velocity at the exit jet.
The action-reaction pair you are asking about is (a) the forward pressure force that the fluid exerts on the nozzle body and (b) the backward force exerted by the nozzle body on the fluid.
If you would like, I will develop the equations that can be used to accurately quantify the forward pressure force that the fluid exerts on the nozzle body. Please let me know if you are interested in seeing the analysis.
Chet
"Bernoulli" yes, it's not straightforward. There seem to be assumptions about the flow around a bend. The speed is not the same at different radii and that will produce pressure gradients. I am looking for a greater force on the outside of the curve but it would seem to be less according to B.
I am unable to fathom what you are saying here. I make you the same offer that I made to Sophiecentaur. If you desire, I will derive the equations for a nozzle attached to a straight pipe, and interpret each of the terms for you.
Guys,
I think we should confine attention, at least temporarily, to a nozzle attached to a straight rigid pipe, rather than a hose. Why? If we can't analyze and reach agreement on that, we will never be able to properly consider the transient unstable undulations of a hose with a nozzle at its end.
Chet
@Chestermiller . Yes that I think would solve the issue, as I see it we have two different scenarios ,
1 The control volume contains a constant diameter pipe 2A
2 The control volume contains a nozzle 2A to 1A
Assumptions were that the pipe is perfectly straight (so walls cannot receive a force)
The initial pressure say a pump is working constant at some fixed rate and that final pressure is atmospheric.
I am not talking about a curving hose I'm not sure how Sophie inferred Bernoullis to mean around bends instead of continuity equation
2 the control volume contains a nozzle 2A to 1A
Assumptions were that the pipe is perfectly straight so cannot receive a force
The initial pressure say a pump is working constant at some fixed rate and that final pressure is atmosphere
OK. I'm only going to solve item 2. Let ##\dot{m}## represent the mass flow rate and ##\rho## represent the fluid density. Let 1 represent the entry to the nozzle and 2 represent the exit from the nozzle. Then the inlet and exit velocities are:
$$v_1=\frac{\dot{m}}{\rho A_1}\tag{1}$$
$$v_2=\frac{\dot{m}}{\rho A_2}\tag{2}$$
where ##A_1>A_2##.
The Bernoulli equation gives us:$$P_1+\rho \frac{v_1^2}{2}=P_2+\rho \frac{v_2^2}{2}\tag{3}$$
If we combine Eqns. 1-3, we obtain:
$$P_1-P_2=\frac{\dot{m}^2}{2\rho}\left[\frac{1}{A_2^2}-\frac{1}{A_1^2}\right]>0\tag{4}$$
The Bernoulli equation expresses the condition for conservation of mechanical energy.
Now for the control volume momentum balance on the fluid passing through the nozzle:
$$P_1A_1-P_2A_2+F=\dot{m}(v_2-v_1)\tag{5}$$where F is the forward force exerted by the nozzle body on the fluid (actually the force will be backward, so that F is negative) and the right hand side of the equation represents the rate of change of fluid momentum within the control volume. If we substitute Eqns. 1 and 2 into Eqn. 4, we obtain:$$P_1A_1-P_2A_2+F=\frac{\dot{m}^2}{\rho}\left[\frac{1}{A_2}-\frac{1}{A_1}\right]\tag{5}$$
If we combine Eqns. 4 and 5 to solve for the force F, we obtain:$$F=-\frac{(A_1-A_2)((P_1A_1+P_2A_2)}{(A_1+A_2)}\tag{6}$$
Again, this is the forward axial force exerted by the nozzle on the fluid, and it is negative, so it is acting in the direction opposite to the fluid flow. The quantity ##(P_1A_1+P_2A_2)/(A_1+A_2)## in this equation can be interpreted physically as the axial component of pressure averaged over the nozzle surface area.
The force that the fluid exerts on the nozzle body is equal and opposite to the force that the nozzle body exerts on the fluid, and is given by:$$F_F=-F=+\frac{(A_1-A_2)((P_1A_1+P_2A_2)}{(A_1+A_2)}\tag{7}$$This force acts on the nozzle in the positive flow direction.
There is also another force acting on the nozzle body from the outside. This is the effect of the gas pressure ##P_2## outside the nozzle. This force is in the negative axial direction, and is equal to ##P_2(A_1-A_2)##. So the net force acting on the nozzle is given by:$$F_{net}=F_F-P_2(A_1-A_2)=\frac{(A_1-A_2)((P_1A_1+P_2A_2)}{(A_1+A_2)}-P_2(A_1-A_2)$$or
$$F_{net}=\frac{(P_1-P_2)(A_1-A_2)A_1}{(A_1+A_2)}>0\tag{8}$$
So the net force acting on the nozzle is in the positive axial direction (i.e., the direction of flow), and it is proportional to the difference between the upstream pressure and the exit pressure.
@Chestermiller The assumption you are making is that, if exit is fixed at atmospheric, then you can change the initial pressure Px→ but the scenario I gave is a fixed inlet pressure.
Sot that's fine but you must also recognise what happens in the preceding control volume
You have a fixed inlet pressure from the pump so if you've increased the exit pressure for this preceding control volume - the flow rate must slow (against the new adverse gradient Ux -ve to that point)
This is why the comparing the two scenarios comes important as while it appears the fluid has accelerated all we have really done by adding a nozzle is slowed it and sped it back up.
In each scenario (with or without the nozzle) the flow only travels at the rate commensurate with the initial and final pressure difference . The 'real net' acceleration is fully provided by the pressure differential - This is why there is no resultant force backwards
The analysis I presented makes no such assumption. In fact, my analysis shows is that the only important pressure parameter in this system is the inlet gauge pressure, which is equal to the difference between the inlet absolute pressure and the exit absolute pressure. You are familiar with the concept of gauge pressure, correct?
Yes but you have used continuity to relate them. So your assuming they are related to as you have done, from the areas and velocities change by continuity . but they are fixed from the pump and the exit. The presence of the nozzle doesn't change either of these.
This is what I believe confuses many people about this scenario. It appears from the math, that there is no resultant force resulting from fluid acceleration because the analysis doesn't show the impact upstream outside the control volume.
This is why I thought it best to show derivations for both scenarios. I thought it would quite clearly show that you couldn't have the same inlet pressures and velocities between the two examples.
I have no idea what you are talking about. I stand by what I said. I guess we are just going to have to agree to disagree.
I continue to maintain that, if the inlet and outlet pressures are both fixed, the mass flow rate will have to adjust accordingly to changes in the cross sectional areas, and, as long as the inlet area is greater than the outlet area and the inlet pressure is greater than the outlet pressure, there will be a hydrodynamic resultant force on the nozzle body in the same direction as the fluid flow. This hydrodynamic resultant force will be balanced by tension in the upstream pipe.
OK I can buy your analysis of the straight situation and I accept that there is no 'backward force' on the nozzle. (I have a problem with the mechanics of how Equations 4 and 5 give you 6 but I guess you have been into that and that it's OK)
The OP is about a fire hose, though and the situation is always different because there is always some curvature just behind the hose; the picture of a fireman holding a hose, is pretty typical. Hoses do snake around and they need a firm hold to prevent it. That means there really is a force, even though it may not be 'backwards'. What could be causing it? Could it be the due to the centripetal force which constrains the water to move in a curve? The argument that pressure doesn't cause any backwards force would seem to transfer to a curved supply hose, which will have a straight axis, after the hose connection.
There's just one thing (a la Columbo): you can see film of people flying around on water hose jet packs. How does that work? Does the jet use air, drawn into the pack? Would the mass of air and the low velocity be enough to support a passenger (1kN force)? Is it all to do with those curved blue pipes on the pack?
