Why Does an Airplane Pilot Experience Limits on Radial Acceleration?
An airplane pilot experiences limits on radial acceleration due to the need to maintain safe g-forces during maneuvers. In the discussion, a problem is presented where a pilot flying at 48.1 m/s must ensure radial acceleration does not exceed 7.39 g, leading to calculations for the minimum radius of the circular path and the net centripetal force. The minimum radius is calculated to be approximately 31.94 meters, while the centripetal force acting on the pilot is determined to be around 6824.78 N. The calculations involve using the formulas for centripetal acceleration and force, confirming the pilot's mass is a key factor. Overall, the calculations and concepts discussed highlight the importance of understanding forces acting on pilots in circular motion.
kimikims
I tried workin this problem out.. and it's not working! :frown:
An airplane is flying in a horizontal circle at a
speed of 48.1 m/s. The 94.1 kg pilot does not
want his radial acceleration to exceed 7:.39 g.
The acceleration of gravity is 9.8 m/s^2
1) What is the minimum radius of the circular
path? Answer in units of m.
7.39g (9.8m/s^2) = 72.422 m/s^2
do I need to square root 72.422??
2) At this radius, what is the net centripetal force
exerted on the pilot by the seat belts,
the friction between him and the seat, and so
forth? Answer in units of N.
N = mg + m (V^2/m)
is this the right formula?? what would m and v be??
Is this right??
Speed = 48.1 m/s
g = 9.8 m/s^2
Problem #1
7.39 g (9.8 m/s^2) = A
A = 72.422
R = V^2 / A
R = (48.1 m/s)^2 / 72.422
R = 31.94
Problem #2
F = mV^2 / R
What's m??
F = (?)m x (4.8)^2 / 31.94
Remember that A(centripital) = v^2 / R...
...so your answer to problem 1 looks correct.
On problem 2, how did you go from a velocity of 48.1 m/s to that of 4.8 m/s? The mass would just be the pilots mass...because its asking for the centripital force acting on the pilot.
Sorry I meant 48.1 m/s not 4.8 m/s...
So it would be:
Fc = m (V^2/R)
Fc = 94.1 [(48.1)^2 m/s / 31.9)
Fc = 6824.78 N?
Looks good. :-D
Looks good. :-D
Thank you! :biggrin:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
