Why does Couette flow have a linear velocity profile?
167 replies · 44K views
Chestermiller said:
The main contributor to the stress is the increased local pressure in the portion of the gas immediately adjacent to the piston. The viscous stress is secondary, but important long term. As the piston advances, the extent of the compressed gas region increases, and the newly accelerated gas allows the pressure at the piston face to be maintained. All this is happening at short times.
What did you mean by long term?
Chestermiller said:
The answers to these questions depend on how we control the motion of the piston. We have total control on the external pressure Pext(t) that we apply and/or the kinematics of the piston motion. Imagine that there is a push-rod attached to the top of the piston, and we control the motion of the rod by hand. When we feel the static friction give way, we can back off on the pressure we apply, so that the piston moves at whatever slow velocity we wish. Or we can try to hold the force we apply constant at the value that existed when the static friction gave way, in which case the gas immediately adjacent to the piston will start to accelerate. We can apply any motion we desire to the piston by controlling Pext(t). When we do this, the non-uniform deformation within the gas will adjust itself in such a manner that σ(I) always satisfies the equation σ(I) + Fkin/A = Pext(t).
Let's say the system is initially at P_o + Fstat/A = Pext and some force is added such that static friction begins to give away to kinetic friction. Assuming that we can back off this force fast enough such that the gas only sees an addition of dP to the external pressure such that now P + Fkin/A = Pext + dP.
1. Can we say at this point that the process so far is quasistatic (P = ideal gas pressure) as we are adding an infinitesimal dP as opposed to an finite Fstat-Fkin which is significant enough for to local pressure increase and viscous stresses?
2. I would assume that regardless of whether the piston is massless or not, at the point in which the gas pressure is P where P + Fkin/A = Pext + dP, the piston probably still be moving. If the piston continues to move, then P + Fkin/A > Pext + dP and the piston would decelerate and push back (if not massless) or just stop (if massless) to maintain force balance. To maintain a positive forward motion without stoppage, the only way I see is to add dP continuously. At the end of the compression, would a massless piston just stop without trouble (and maintain quasistatic) but a piston with mass will now oscillate barring no changes in Pext?
Chestermiller said:
Sorry your book doesn't do a good job. I looked over the excerpt you sent, and it (at least) looks correct. What they are trying to do is calculate what the entropy of the reaction mixture would be at various conversions. The conversion that maximizes the entropy for this isolated reacting system is the one that corresponds to the equilibrium conversion.
Was the equation used for the plot the absolute entropy, since the reference entropy is on the right side of the equation?
Chestermiller said:
It's not quite correct to say that the enthalpy/entropy of formation are "independent of pressure." Both the enthalpy of formation and the entropy of formation occur at a constant pressure of one atmosphere. For an ideal gas, the enthalpy is independent of pressure, but the entropy definitely depends on a pressure. After the material is formed from the elements at 1 atm. pressure, if the pressure of the species changes, its entropy changes.
Chet
For ideal gases, both its enthalpy and enthalpy of formation is pressure independent but the entropy of formation is pressure dependent? Most examples I found conveniently had reactions at 1atm, but if a reaction is at some other pressure can I use the same enthalpy/entropy of formation?
I'm also curious of the way absolute enthalpy is defined. Given absolute enthalpy = enthalpy of formation at (Tref, Pref or 298K and 1atm) + sensible enthalpy. I noticed that enthalpy of formation at (Tf, Pref ) is much lower than the absolute enthalpy at (Tf,Pref) from using the proper equation. Is there a reason why we assume the formation occurs at some standard state (seems a bit arbitrary) and heated to the final temperature as opposed to forming directly at Tf,Pref, which gave the wrong result?
Thanks very much
Well, you remember that with a frictionless piston, there can be oscillation. We would have to solve the gas dynamics equations to figure out what is happening after the early part of the deformation, as when, for example, the piston reaches its forward extent for the first time and may want to move backward. The inertia of the gas can also contribute to this picture, since parts of the gas may still be moving when the piston reaches the end of its first stroke.
Yes. However, if the process is quasistatic like this, the viscous stresses in the gas are negligible, and the gas pressure is uniform throughout the cylinder. This is the problem we have have already analyzed.
Yes. That's what we found when we analyzed the problem with friction previously. The gas pressure within the cylinder under these quasistatic conditions will increase, and Pext will have to increase. The gas pressure will be uniform in the cylinder, and the viscous stresses will be negligible.
This question confuses me. If the process is quasistatic, there will be no oscillation. But, Pext will have to increase as the pressure of the gas increases.
When I hear the term "absolute entropy," I think of a reference state at absolute zero temperature. I don't think this is what you mean. The entropy on the left side of the equation is the entropy of the mixture, relative to the combined entropy of the pure components (separated) and each in its reference state of 1 atm and 25C.
The entropy of formation describes the change:
Equilibrium State 1: Pure elements in stoichiometric proportions at 25 C and 1 atm
Equilibrium State 2: Pure compound at 25C and 1 atm
As with any system, to determine the entropy change, you would have to identify a reversible path between state 1 and state 2, and then determine the Q for the path.
Yes. In the examples, the total pressure was constant, but not the partial pressures of the various species. The term involving partial pressure in your equations for the individual species partial molar entropies takes into account the difference between the total pressure and the partial pressure of the species.
I don't quite understand this question. The reason for using a reference state is so we don't have to tabulate the enthalpies of the species at every temperature. All we need to do is provide the enthalpy of formation at one temperature (the reference temperature), and provide the heat capacity of the species. I'm sure you already knew this.
Chet
In the process I was imagining, if the piston (with mass) is still moving when P + Fkin/A = Pext + dP, any additional motion by the piston would mean that P + Fkin/A > Pext + dP and the piston will decelerate and move backwards where forces are balanced which is not desirable. I thought a solution would be to add dP as soon as the forces balance continuously, which will accelerate the piston by small amounts each time. At the end of the compression, I would still end up with positive momentum for the piston when P + Fkin/A = Pext + ∫dP so if the external forces are maintained constant, I see an oscillation occurring if the piston moves further down (increasing P).
If the piston is massless at the point where P + Fkin/A = Pext + dP, would it stop instantly as the case where P + Fkin/A > Pext + dP is not physically possible?
Is the quasistatic nature/viscous stresses affected by the actual speed of the piston or simply how much we are disturbing it from equilibrium? In the scenario I mentioned above I am continuously accelerating the piston so I would get a continuously higher velocities.
With regards to the equation:
[tex]s_i = s_i^o (Tref) + ∫c_p\frac{dT}{T} - R_uln(\frac{P_i}{P^o})[/tex]
I took the latter two terms to represent entropy change from the reference state to the final state, and the first to be the formation entropy. I also assumed that the first term to be an absolute entropy (from absolute zero) such that s_i is now relative to absolute zero, is this correct?
Is it possible even theoretically for a reaction be reversible?
Chet
My book tabulates both the enthalpy of formation as a function of temperature as well as the sensible enthalpy change from reference (labelled as absolute entropy - enthapy of formation @ 298K) all at 1atm. What I had thought is that, for say CO2, the enthalpy of formation at say 1000K should be equal to enthalpy of formation @ 298K + Sensible Enthalpy (298K to 1000K). I found the two to be nowhere close to equal, so I'm confused on why we have to use formation enthalpy at a reference state always even if the reaction takes place at much higher temperatures such that species would be forming at higher temperature. I have the same question about entropy as well.
Thank you
You are increasing Pext gradually in a quasistatic process. You can do this as slowly as you wish, such that the piston momentum is negligible, even if it has mass. Also, as soon at the piston tries to reverse direction, static friction will kick in again. This whole question is not really a thermodynamics question. It is strictly a mechanics question. I'd like you to try modelling it yourself. Model the gas as a Hooke's law spring with an initial compression. Increase the force Pext a tiny incremental, and see if, with friction, the piston indeed does oscillate.
I don't understand this question. Solving the modeling exercise above will probably answer this question too.
Viscous stresses are caused by velocity gradients in the fluid. If there are no significant velocity gradients, then the viscous stresses are negligible. The absolute magnitude of the deformation is not important (as far as viscous stresses are concerned). If you want to get an idea of how viscous stresses come into play, include a damping element in parallel with the spring in the model I discussed above.
It doesn't matter, as long as everything is done consistently. You can take s_i as the entropy of the pure species relative to absolute zero, or you can take the entropy of pure elements at Tref as zero. Either way, you get the same answer for changes in entropy.
Yes. Look up van't Hoff equilibrium box in your book or google
You have to use Hess' law, and subtract the sensible heats of carbon and oxygen (weighted stoichiometrically).
Chet
Thank you
If a chemical reaction involves (theoritically) transformation of chemical energy into any form of energy other than heat (electrical energy, for example), such reaction is deemed to be reversible.
Therefore, the question we are left with is about reactions involving energy transformations involving heat.
We can consider the following situations:
1. Initial state (A) is just the reactants (or just the products) and final state (B) is a
stiochiometric mixture of reactants and products.
2. Initial state is equilibrium mixture of reactants and products in state A, and final state is
equilibrium mixture of reactants and products in state B.
In either case, we take the system from state B to state A by a reversible process, so that the system completes a cycle. The only changes left now, are in the surroundings.
We sum up the quantities Qi/Ti, that is, calculate ∑(Qi/Ti). If we get a positive number we say the process AB is irreversible; if we get zero, we say the process AB is reversible.
It is, therefore, possible for a chemical reaction to be reversible in principle (theoritically).
rkmurty
In the situation I was thinking, the piston wouldn't be stopping and going at every dP addition. I was trying to avoid the constant back and forth switch between kinetic and static friction, which means that the piston is constantly accelerating up to the end of the compression. The force balance I came up with was:
APext + AdP + mg - k|(x-x0)| - Fkin = ma
I am not sure if the above is correct or how I would solve this to get the velocity at the end of the compression.
Would the speed of the piston have an effect of on the velocity gradient in the fluid? I am thinking that the faster I compress, the less time the fluid further away from the piston face to "react" to the change, and the further I deviate from a quasistatic process.
The so(Tref) from the tables is different for every species, if I were to subtract so(Tref) from si such that the entropy is relative to a specie's reference state and then using that to calculate ΔS, would this be the same as ΔS calculated using absolute entropy?
Thanks very much
In this response, I will be referring to the attachment below:
https://www.physicsforums.com/attachment.php?attachmentid=70091&stc=1&d=1401192844
In the attachment, I have included two "models" of the gas behavior to help is quantify our discussion. The first model has one degree of freedom, and features a spring in parallel with a damper (the combination is commonly referred to as a Voigt element). The spring simulates the local p-v-t behavior of the gas, and the damper simulates the viscous dissipation. The parameter x1 represents the displacement of the piston.
The second model has two Voigt elements, with a mass in-between (simulating the mass of the gas). This model has two degrees of freedom. In this lumped model, x2 represents the displacement of the piston, and x1 represents the displacement half-way through the gas. The stiffness of the springs and the damper constants in this model are not the same as for the single degree of freedom model, but are appropriately adjusted to give equivalent behavior.
In my responses in this posting, we will be focusing exclusively on the first model. Later we can get to the second model, if necessary.
For the single degree of freedom model, the force balance just before static friction releases would read :
APext+ mg + kx10 - Fstat = 0
where x10 is negative to represent initial compression of the gas.
I'm going to stop here for now, and give you a chance to digest the gas models, and ask questions.
Chet
Yes.
I'm a little confused over this question. Are you referring to ΔS for a single species or ΔS for a mixture of species?
Chet
Chet
Is there a reason why we are adding a damper? If we assume that there is always a dP difference between Pext and Friction + PI (the system is able to pull back force once static gives away to kinetic friction), the process should be quasistatic so would the "damping" effect from viscous stresses would be zero and are we just doing a general case where we can set the damping to coefficient to zero for the quasistatic model?
If the piston was massless, can we just set m = 0 of the general solution or does it affect the fundamental setup in some way?
Chet
I was referring to ΔS of the mixture. For the formation of water H2 + 1/2O2 -> H2O, assuming the process goes to completion with no dissociation and initial and final equilibrium temperatures are the same at 298K (and constant pressure), the entropy of formation so(Tref) for the reactants is 130.595 + 205.043*0.5 = 232.52kJ/molK but for the product (just water) it is 188.715kJ/molK and the two doesn't cancel. In this case the absolute entropy = entropy of formation so had I used the entropy of each species as relative to its reference state entropy, I should have gotten zero for both (and ΔSmix = 0)?
Thanks very much
In recent posts, you were referring to the effects of viscous stresses, and to pistons with mass that accelerate. So to try to address these all at one time (rather than bouncing from one to the other), I thought it would be better if we got a little more general. We will be solving several cases. Is that OK with you?
These entropies are absolute entropies. The difference between the 188.715kJ/molK and the 232.52kJ/molK is the change in entropy as a result of reaction, in going from pure oxygen and pure hydrogen at 298K and 1 atm to pure water at 298K and 1 atm.
Chet
Continuing the analysis, the force balance on the piston after static friction releases is given by:
[tex]AP_{ext}(t)+mg-F_{kin}+\left(kx_1+C\frac{dx_1}{dt}\right)=-m\frac{d^2x_1}{dt^2}[/tex]
where C is the (viscous) damping constant and where the piston displacement x1 is measured upward (so, for compression, x1 is negative).
If we subtract the force balance equation just before static friction releases from this equation, we obtain:
[tex]AΔP_{ext}(t)+(F_{stat}-F_{kin})+\left(kΔx_1+C\frac{d(Δx_1)}{dt}\right)=-m\frac{d^2(Δx_1)}{dt^2}[/tex]
where [itex]ΔP_{ext}=P_{ext}-P_{ext,static}[/itex] and [itex]Δx_1=x_1-x_{10}[/itex].
Is this formulation acceptable to you so far?
Chet
Chet
So does this mean that the absolute entropy must always be used, and we must never use entropy that is w.r.t. the reference state/entropy of formation (298K, 1atm) as the ΔS of the reaction becomes 0 in the above case?
Chet
In the first equation, at the instant the friction switches to kinetic, is the LHS = dP such that dP = -m[itex]\frac{dx^2}{dt^2}[/itex] (difference between applied pressure and sum of system forces)?
Thanks very much
No. We could have taken the entropies of formation of the elemental species to be zero at 298 and 1atm, in which case the entropy of formation of water in the reference state would have been 189-233 = -44. In this approach, the free energy of formation of the water (from the elements) in the reference state would have been -241826+(298)(44), where the -241826 is the heat of formation of the water (g) in the reference state. If we are working with the equilibrium of chemical reactions, it is important to know the free energies of formation of the species in the reference state, and the enthalpy of formation in the reference state (the latter to get the temperature dependence of the equilibrium constant). The entropy of formation is secondary to this exercise. However, if we are using the entropy of formation to calculate the free energy of formation, the reference state for entropy and for free energy of formation must be consistent.
No. A differential can not be equal to something that is not differential.
Try to think of it this way. We have numerous options regarding Pext, since we have complete control over it. So we need to decide what we want to do. Each option results in a different deformation history. Here are some options:
1. We instantly back off on the Pext, so that equilibrium is re-established, such that Pext decreases by exactly Fstat-Tkin. This re-establishes static friction, and the piston doesn't move.
2. We move the piston in whatever way necessary such that Pext does not change once friction switches to kinetic. This results in an irreversible deformation.
3. We instantly back off on Pext, so that Pext decreases by Fstat-Tkin-dP. In this case, the deformation is quasistatic. Under these circumstances, the gas deforms reversibly, but the adiabatic process for the combination of gas plus piston is irreversible (because of the friction, as we already showed). Here, we have to decide what overall pressure change we want to impose.
4. We apply an impulse force to the piston at time zero, so it starts moving with an initial velocity, and then let friction and viscous dissipation slow it down.
I think the interesting options are 2 and 4. Can you think of others? What do you want to consider?
Chet
I think I just have a logic issue. My thought is that, if I set the entropy of each species to be relative to its absolute entropy at reference state (298K, 1atm), which is essentially its entropy of formation, then in the formation of water example I had, the entropy of each species would be 0 since the entropy is measured at the reference state relative to the reference state. So if I do Δsreaction = sprod - sreactant, I'd end up with 0 = 0 - 0 when it is supposed to be -44 regardless of how I define the reference.
Chet
For option 3, how come we can say that Pext decreases by Fstat-Tkin-dP but yet cannot set an equality involving dP?
I think that option 2 is closer to practical applications and is probably similar to option 3; those two are the ones I am most interested in looking at.
Thank you very much
Only the entropies of formation of the elemental species are taken to be zero. The entropies of formation of compounds are not.
Let's do option 2. We will first consider the case where the piston mass m = 0, and then do the case where the piston has mass. Please take a shot at writing the differential equation for the case of no mass (in terms of the Δ's). If you are comfortable with your differential equation, please solve it for Δx1 as a function to time t.
Chet
I notice that all element enthalpy of formation is zero at reference state so I assume this is from the same reasoning? How come this is true? For entropy, I assumed that if everything was relative to the reference state, each specie's entropy would be defined as sabsolute - sreference state; how come this only holds for elements?
I meant, how come we can express in words that Pext is decreased by Fstat-Tkin-dP but we can't set a force balance like Pext = Pext,static - (Fstat-Tkin-dP)
Chet
[tex]\frac{d(Δx_1)}{dt}+\frac{k}{C}Δx_1= -\frac{A}{C}ΔP_{ext}(t)-\frac{1}{C}(F_{stat}-F_{kin})[/tex]
[tex]Δx_1 = -\frac{1}{e^\frac{kt}{C}}∫e^\frac{kt}{C}\frac{A}{C}ΔPext(t)dt - \frac{Fstat - Fkin}{k}+\frac{CONST}{e^\frac{kt}{C}}[/tex]
I imagine that Pext(t) is the forcing function and its properties be known. I am unsure how to evaluate the arbitrary constant without knowledge of the first integral though.
I'm also wondering, what is the difference between the equation with and without Δ?
Thanks
What we are trying to do here is determine the changes in entropy as a result of changes in pressure, temperature, and chemical reaction between two thermodynamic equilibrium states, say A and B. To do this, we need to establish a proper mathematical framework for the analysis. It doesn't matter whether we choose the absolute entropy of a pure species as the zero point for entropy (in the case of the elements), or whether we choose the entropy to be zero for the pure elemental species at some other state such as 298 and 1 atm. Either way, when you calculate the change in entropy from state A to state B, you will get the same answer. You need to convince yourself of that. I don't really know the details of how they calculate absolute entropies of species, but this doesn't really matter to me. If I know that this is the basis for the entropy values in a table, I can use them. Similarly, if I know that the entropies in the table are relative to the pure elemental species in their equilibrium state at 298 and 1 atm, I can use them. These are the two different bases that are commonly used in various tables.
I don't have any problem with this, but what does dP represent? Also, what is this "force balance" being applied to?
In the description of Case 2, what do the words "Pext does not change" mean to you with regard to ΔPext? This should give you enough information to determine CONST.
It just seems easier to me to work in terms of the equation with the Δ's; it eliminates the x0 and the mg. Mathematically, of course, there's no difference.
Chet
What I am confused by is, why are pure species treated differently than compounds when setting s = 0 in reference state? How come I can't subtract off, from the absolute entropy at some T and p, a substances' entropy at its reference state such that any substance has zero entropy at its reference state, which I am imagining as a "origin/zero point"?
I was thinking in terms of the force balance for the quasistatic case at the instant that friction switches from static to kinetic. In such a case, would Pext(t = 0+) = Pext, static - (Fstatic/A - Fkinetic/A - dP)? This would result in Pext(t = 0+)A + mg - PIA - Fkinetic = dP = ma.
Chet
If ΔPext(0) = 0 and Δx1(t) = 0
[tex]CONST = e^\frac{kt}{C}(\frac{Fstat - Fkin}{k})[/tex] and
[tex]Δx_1 = -\frac{1}{e^\frac{kt}{C}}∫e^\frac{kt}{C}\frac{A}{C}ΔPext(t)dt[/tex]
Thank you
If we take S = 0 for the pure elements in the reference state, then the entropy of the compound formed from these elements at the reference temperature and pressure can't be zero. Let's consider your specific example:
State A: 1/2 mole of pure oxygen(g) and 1 mole of pure hydrogen(g) (in separate containers) each at the reference temperature and pressure.
State B: 1 mole of pure liquid water at the reference temperature and pressure (in a third container).
The change in entropy for a process that goes from State A to State B is not equal to zero. The "entropy of formation" of liquid water at the reference temperature and pressure is defined as the change in entropy ΔS for this specific process.
Now, the real challenge is to dream up a reversible process that goes from State A to State B (so that the change in entropy can be measured). Can you think of such a process? It might help to think in terms of a vant Hoff equilibrium box, and semipermeable membranes.
Sorry. I still don't follow. Is dP supposed to be the change in pressure of the gas, or is it supposed to represent a slight incremental increase in the external pressure?
Case 2 states that "Pext does not change" means that ΔPext is not just zero at time t = 0. It means that ΔPext is held equal to zero for all times. In other words, Pext is held constant throughout the deformation at its (high) value that existed just before static friction released. So:
[tex]Δx_1 = -\frac{(F_{stat} - F_{kin})}{k}\left(1-e^{-\frac{kt}{C}}\right)[/tex]
This is how the piston has to be moved to keep Pext constant at its value that existed just before static friction released.
Chet
From my limited understanding of Van't Hoff's box, I believe there would be 3 piston cylinder assemblies (each containing one of O2, H2, H2O) each separated from a reaction chamber by a semipermeable membrane. Assuming the reaction chamber containing O2, H2, H2O is initially at equilibrium, adding infinitessimal amounts of O2 and H2 produces an infinitessimal amount of H2O that is immediately extracted at equilibrium pressure and I assume that the heat generated is also reversibly rejected. I know ΔS=0 for the reaction chamber but not sure how to prove that ΔS of the three piston-cylinder combined plus heat loss is also 0.
I was imagining the term reference like an origin and that if absolute zero was the reference, formation entropy would be zero for every species so moving this reference to another state (298K, 1atm) should mean that the entropy of every species (compound or not) starts at zero from that reference, even though I understand that thermodynamically this gives invalid results.
From what I have read, am I correct to understand reference state as some "arbitrary" T and p (conventionally taken as 298K, 1atm) where it is defined that only element formation properties (entropy, enthalpy, free energy) are equal to zero? Also, I read that elements refers to elements in their "natural state". I understand qualitatively what it means (O2 but not O, S8 but not S), but is there a formal definition on what natural state is and would it vary with T and p?
I meant dP to mean an incremental increase in external pressure.
Chet
So in this example, the P-v curve would be a horizontal line? Since the piston is massless, the force balance at the system boundary at any instance in time, but the second derivative of Δx is equal to k2/C2e-kt/C which isn't zero at any point in time implying that the massless piston is always accelerating, what could be causing this?
Thanks very much
Very close. You have the right idea; there are only a few steps missing. Initially you have 1/2 mole of oxygen in the oxygen cylinder, 1 mole of hydrogen in the hydrogen cylinder, and 0 moles of water in the water cylinder. You first expand the oxygen and the hydrogen within their individual cylinders isothermally and reversibly from their initial pressures of 1 atm until their pressures are equal to their equilibrium partial pressures within the box. You then inject them isothermally and reversibly through their semipermeable membranes into the equilibrium box, while at the same time removing water vapor isothermally and reversibly at its equilibrium partial pressure through its semipermeable membrane (into the water cylinder which is held at a pressure equal to the water vapor partial pressure within the equilibrium box). After all the oxygen and hydrogen have been injected into the equilibrium box and the water vapor produced by the reaction has been removed into its cylinder, there will be one mole of water vapor in the water cylinder at the water partial pressure within the equilibrium box. The final step is to compress the water within its cylinder isothermally and reversibly from its equilibrium partial pressure in the box to a pressure of 1 atm., including condensing the water to liquid water at 1 atm.
You are correct in noting that, for the contents of the equilibrium box, there is no entropy change as a result of this process. However, the ΔS of the three piston-cylinder combined plus heat loss is not zero. If you had measured the reversible heat added when expanding the oxygen and hydrogen, the reversible heat removed from the equilibrium box as a result of the reaction, and the reversible heat added when the compressing the water to 1 atm, you would find that the net reversible heat would not be zero. If we divided this net heat by the temperature of the system, we would get the entropy of formation of liquid water.
I'm not quite sure what you're saying, but, even if absolute zero were the reference, formation entropy for compounds would not be zero, since the reaction to produce the compound from the elements would involve a finite entropy change, even at absolute zero.
Yes. This is the basis for one of the two different approaches. The other is that the entropies of the elements are zero at absolute zero, and, at 298 and 1 atm, the entropies of the elements are their absolute entropies at their natural state at 298 and 1 atm. With either way of doing it, you get the same result for the entropy change for any and all reactions.
The natural state is usually understood as you described it without separately specifying it for each species. The natural state also applies to compounds. It doesn't vary with T and p, because T and p for the reference state are 298 and 1 atm, period.
Sure. The Pext-v curve would be a horizontal line.
The net force on a massless piston that is accelerating is zero. So what. What is the big surprise?
Anyway, next we are going to be considering the case where the piston has mass. Then you'll be able to see what the difference is. So, for Case 2, what is the differential equation for the piston motion Δx1 in the case where the piston has mass? What do you get for the solution to this differential equation?
Here is a summary so far for the piston motion:
1. No viscous dissipation, no piston mass, no gas mass: Δx1=ΔF/k
2. With viscous dissipation, no piston mass, no gas mass: [itex]Δx_1=\frac{ΔF}{k}(1-e^{-\frac{kt}{C}})[/itex]
(Note that, in this situation, the piston does not oscillate.)
Chet
Hi. It finally dawned on me what you are asking here. For this case,
[tex]P_{ext}(t)=P_{ext,static}-\frac{(F_{static}-F_{kinetic})}{A}+δP_{ext}(t)[/tex]
This is the same as:
[tex]ΔP_{ext}(t)=-\frac{(F_{static}-F_{kinetic})}{A}+δP_{ext}(t)[/tex]
If we substitute this into our differential equation, we obtain:
[tex]AδP_{ext}(t)=-kΔx_1-C\frac{dΔx_1}{dt}-m\frac{d^2Δx_1}{dt^2}[/tex]
Now, let's suppose that we force the piston to undergo a very small constant acceleration of a. The question is, in what way would δP have to be varied as a function of time to accomplish this? With constant acceleration, we would have
[tex]Δx_1=\frac{1}{2}at^2[/tex]
and
[tex]t=\sqrt{\frac{2Δx_1}{a}}[/tex]
If we substitute these relationships into the differential equation, we obtain:
[tex]AδP_{ext}(t)=-(kΔx_1+C\sqrt{2aΔx_1}+ma)[/tex]
Now, if the acceleration is very small, but we wait a very long time for the displacement to reach a desired value of Δx1, this equation reduces to:
[tex]AδP_{ext}(t)=-kΔx_1[/tex]
Do you see that, in this quasistatic case, the acceleration term and the viscous dissipation term become negligible?
Chet
Why does the initial state of the reactants and the end state of the products have to be at 1atm? Would the potential sources of irreversibilities for this process would include that from heating, piston work, and deviation from equilibrium of the reaction chamber?
So for compounds, the absolute entropy of say H2O wouldn't be zero at absolute zero?
In the formation of H2O at 298 and 1atm, what is the difference between the -44kJ/kmolK and the 188.7kJ/kmolK values? The table I have has formation enthalpy/free energy relative to reference state (element h_f/g_f = 0), but it seems that formation entropy isn't (element s(Tref) ≠ 0 and varies with temperature, also they didn't use a subscript _f for s like with the others which may be significant). If I were to remake this table w.r.t. reference state for H2O, would I put the -44 value under its entropy?
Is there no formal definition on what a species'/element natural state is for species' where it won't be intuitively obvious, or is it just the most common form of the species that we encounter?
I was thinking that a net force is needed to produce acceleration, now I am thinking that as m -> 0, would F -> 0 to produce some finite acceleration?
Chet
For the case with mass, the ODE becomes:
[tex]m\frac{d^2(Δx_1)}{dt^2}+C\frac{d(Δx_1)}{dt}+kΔx_1=(F_{kin}-F_{stat})[/tex]
The solution will depend on the actual values of m,C, and k
[tex]r = \frac{-C\pm\sqrt{C^2-4mk}}{2m}[/tex]
assuming that the roots are real the homogeneous solution would be
[tex]Δx_1 = c_1e^{\frac{-C+\sqrt{C^2-4mk}}{2m}t} + c_2e^{\frac{-C-\sqrt{C^2-4mk}}{2m}t}+(F_{kin}-F_{stat})/k[/tex]
if the roots are imaginary, the homogeneous solution would be
[tex]Δx_1 = e^{\frac{-C}{2m}t}(c_1sin(\frac{\sqrt{4mk-C^2}}{2m}) + c_2cos(\frac{\sqrt{4mk-C^2}}{2m})+(F_{kin}-F_{stat})/k[/tex]
which gives a decaying oscillation. I assume that the first peak would take the piston past equilibrium BDC and as t -> ∞ we converge at the actual BDC which happen to be (F_kin-F_stat)/k.
Thanks very much
and
Chet
Is there a reason why δP is used here instead of dP?
I've always thought that an infinitessimal quantity is already the smallest possible unit (and essentially a "constant"), but here we have to vary this to maintain a certain acceleration small enough for the approximation to hold. Are we allowed to vary this (and to what degree) and still call it an infintessimal disturbance as it appears that δP increases with time as Δx increases with time?
Thanks very much
That's just the convention that's used. It's assumed that 1 atm is low enough for ideal gas behavior to apply.
I don't quite get what you are driving at here. In the description we discussed, the entire transition from the initial equilibrium state to the final equilibrium state was reversible. In irreversible processes, irreversibilities result from finite heat conduction, finite viscous dissipation, and finite chemical reaction rates.
No, it wouldn't.
I'm puzzled by all this. The free energy, enthalpy, and entropy at the reference state have to be related by:
gref=href-Trefsref
If gref and href of the elements are zero at the reference state, then sref also has to be zero. The g, h, and s of formation of the elements vary with temperature, but at the reference state, they are taken as zero. The g, h, and s of formation of compounds also vary with the temperature, but at the reference state, they are not zero. I wish I could see your table so I could understand better.
Typically, the latter. But, in the case of any ambiguity, the state of the species has to be specified precisely.
Yes. That's what I've been trying to say. We'll see how this plays out in our analyses.
Yes. This is correct. Now, before we talk about the cases where the mass is large enough for the roots to be imaginary, let's talk a little more about the case of real roots. I would like to re-express the roots in a slightly different form:
[tex]r_1 = \frac{-C+\sqrt{C^2-4mk}}{2m}=\frac{-2k}{C+\sqrt{C^2-4mk}}=\frac{-2k/C}{1+\sqrt{1+\left(\frac{4mk}{C^2}\right)}}[/tex]
[tex]r_2 = \frac{-C-\sqrt{C^2-4mk}}{2m}=\frac{-2k}{C-\sqrt{C^2-4mk}}=\frac{-2k/C}{1-\sqrt{1-\left(\frac{4mk}{C^2}\right)}}[/tex]
For small values of the piston mass m, do you know how to linearize these roots with respect to ##\frac{4mk}{C^2}##? If so, please do. Also, from the initial conditions, do you know how to determine the constants of integration c1 and c2? If so, please do.
Chet
Compressing a gas quasistatically by, say, a factor of 2 requires more than just a single differential change in the compressive pressure on the piston. It requires a sequence of differential pressure changes applied gradually over time so that they sum to a finite pressure change δP. The more the gas is compressed, the higher the cumulative pressure increase δP has to be.
Chet
I didn't word that question very well. I was really wondering how adding the reactants too quickly or not removing the products fast enough from the reaction chamber will lead to irreversibilities?
gref=href-Trefsref
I have attached part of the table for H2. I am probably missing/mis-interpreting something. I believe that the entropy give is absolute while the free energy and enthalpy of formation are relative to the reference state; however it seems the book on purposely chose not to term the entropy as "formation" (with subscript f). I believe that the so(T) in the table is the same as that in the equation in the second attachment.
Chet
From assuming Δx = 0 and d(Δx)/dt = 0 at t = 0, for the constants I got:
[tex]c_1 = \frac{(F_{kin} - F_{stat})(1-\sqrt{1-\frac{4mk}{C^2}})}{2k\sqrt{1+\frac{4mk}{C^2}}}[/tex]
[tex]c_2 = \frac{(F_{stat} - F_{kin})(1+\sqrt{1+\frac{4mk}{C^2}})}{2k\sqrt{1+\frac{4mk}{C^2}}}[/tex]
I'm not sure if I'm doing this correctly, but the square root would be linearized, for [itex]f(x) = \sqrt{1\pm x}[/itex] :
[itex]L_1(x) = \sqrt{1-\frac{4mk}{C^2}} - 1/2(x-\frac{4mk}{C^2})(1-\frac{4mk}{C^2})^{-0.5} for \sqrt{1-\frac{4mk}{C^2}}[/itex]
and
[itex]L_2(x) = \sqrt{1+\frac{4mk}{C^2}} + 1/2(x-\frac{4mk}{C^2})(1+\frac{4mk}{C^2})^{-0.5} for \sqrt{1+\frac{4mk}{C^2}}[/itex]
Chet
To maintain a small but constant acceleration, are we basically applying δP (via series of dP) to let the piston accelerate initially and wait for the piston to decelerate by a certain extent before applying δP again?
Thanks very much
The attachments didn't attach for some reason.
The irreversibility really comes in in allowing the reaction to proceed at a finite rate. If you allow the reaction to proceed at a finite rate, then you can't return the system to the initial state (temperature, pressure, composition) without causing a significant change in the surroundings.
I'm not familiar with what they are doing in these tables, and need more context. What they're doing seems very confusing to me, and apparently it has confused you also. Here's what several texts that I have access to do:
Smith and Van Ness, Introduction to Chemical Engineering thermodynamics:
The standard heat of formation of a species is equal to the change in enthalpy in going from the elements to the species at 1 atm and temperature T.
The standard heat of formation of a species in the reference state is the standard heat of formation at 298.
The standard heat of formation of the elements is equal to zero in the reference state.
The standard free energy of formation of a species is equal to the change in free energy in going from the elements to the species at 1 atm and temperature T.
The standard free energy of formation of a species in the reference state is the standard free energy of formation at 298.
The standard free energy of formation of the elements is equal to zero in the reference state.
Perry and Chilton, Chemical Engineers' Handbook
Same as for Smith and Van Ness
Hougan, Watson, and Ragatz, Chemical Process Principles
Heats of formation handled the same as previous two references.
Standard Molar Absolute Entropies used to get entropy change for a reaction in the reference state (298, 1 atm).
Standard Molar Enthalpies and Entropies used to get change in free energy for a reaction in the reference state.
Standard free energy changes (1atm) for reactions at other temperatures calculated from [tex]\frac{d(ΔG^o/RT)}{d(1/T)}=\frac{ΔH^o}{R}[/tex]
and
I'm going to come back to this problem tomorrow.
No. δP is a function of time. It is the time-dependent pressure variation we need to apply over the entire deformation to hold the acceleration constant at a very small value. When we reach the desired final deformation, we stop increasing δP and, since it then only results in a negligible net load on the piston, the deformation ceases.
[tex]AδP=\left(\frac{1}{2}at^2\right)k+(at)C+ma[/tex]
where a is the downward acceleration.
Chet
For the H2O example what kind of effect would a finite rate have on the properties inside reaction chamber?
I'm not sure if they help but I have attached the cover sheet of the appendix which outlines the source and calculation method that is slightly different than the above. It appears that the entropy value is absolute and at least close to some other ones on the internet; however I am not sure why it is varying with temperature while the enthalpy/free energies do not.
Chet
How do we maintain a constant acceleration while adding different increments of δP, as it is essentially a net force that will always add to the acceleration?
Thanks very much
