Red_CCF
- Messages
- 530
- Reaction score
- 0
Chestermiller said:The main contributor to the stress is the increased local pressure in the portion of the gas immediately adjacent to the piston. The viscous stress is secondary, but important long term. As the piston advances, the extent of the compressed gas region increases, and the newly accelerated gas allows the pressure at the piston face to be maintained. All this is happening at short times.
What did you mean by long term?
Chestermiller said:The answers to these questions depend on how we control the motion of the piston. We have total control on the external pressure Pext(t) that we apply and/or the kinematics of the piston motion. Imagine that there is a push-rod attached to the top of the piston, and we control the motion of the rod by hand. When we feel the static friction give way, we can back off on the pressure we apply, so that the piston moves at whatever slow velocity we wish. Or we can try to hold the force we apply constant at the value that existed when the static friction gave way, in which case the gas immediately adjacent to the piston will start to accelerate. We can apply any motion we desire to the piston by controlling Pext(t). When we do this, the non-uniform deformation within the gas will adjust itself in such a manner that σ(I) always satisfies the equation σ(I) + Fkin/A = Pext(t).
Let's say the system is initially at P_o + Fstat/A = Pext and some force is added such that static friction begins to give away to kinetic friction. Assuming that we can back off this force fast enough such that the gas only sees an addition of dP to the external pressure such that now P + Fkin/A = Pext + dP.
1. Can we say at this point that the process so far is quasistatic (P = ideal gas pressure) as we are adding an infinitesimal dP as opposed to an finite Fstat-Fkin which is significant enough for to local pressure increase and viscous stresses?
2. I would assume that regardless of whether the piston is massless or not, at the point in which the gas pressure is P where P + Fkin/A = Pext + dP, the piston probably still be moving. If the piston continues to move, then P + Fkin/A > Pext + dP and the piston would decelerate and push back (if not massless) or just stop (if massless) to maintain force balance. To maintain a positive forward motion without stoppage, the only way I see is to add dP continuously. At the end of the compression, would a massless piston just stop without trouble (and maintain quasistatic) but a piston with mass will now oscillate barring no changes in Pext?
Chestermiller said:Sorry your book doesn't do a good job. I looked over the excerpt you sent, and it (at least) looks correct. What they are trying to do is calculate what the entropy of the reaction mixture would be at various conversions. The conversion that maximizes the entropy for this isolated reacting system is the one that corresponds to the equilibrium conversion.
Was the equation used for the plot the absolute entropy, since the reference entropy is on the right side of the equation?
Chestermiller said:It's not quite correct to say that the enthalpy/entropy of formation are "independent of pressure." Both the enthalpy of formation and the entropy of formation occur at a constant pressure of one atmosphere. For an ideal gas, the enthalpy is independent of pressure, but the entropy definitely depends on a pressure. After the material is formed from the elements at 1 atm. pressure, if the pressure of the species changes, its entropy changes.
Chet
For ideal gases, both its enthalpy and enthalpy of formation is pressure independent but the entropy of formation is pressure dependent? Most examples I found conveniently had reactions at 1atm, but if a reaction is at some other pressure can I use the same enthalpy/entropy of formation?
I'm also curious of the way absolute enthalpy is defined. Given absolute enthalpy = enthalpy of formation at (Tref, Pref or 298K and 1atm) + sensible enthalpy. I noticed that enthalpy of formation at (Tf, Pref ) is much lower than the absolute enthalpy at (Tf,Pref) from using the proper equation. Is there a reason why we assume the formation occurs at some standard state (seems a bit arbitrary) and heated to the final temperature as opposed to forming directly at Tf,Pref, which gave the wrong result?
Thanks very much
