- 1,443
1)The interference pattern is peaked, not sinusoidal, so the area above 0dB is less than half the total.PSuran said:Thanks for the input. I fail to see how this can be the case. If we take into account the fact that we can never get more than +6 dB if two speakers are combinted, consider these scenarios:
Situation 1: Two subs one next to the other. Play a 30 Hz sine wave. You pretty much have +6 dB in all directions, everywhere (low enough wavelength, sources close enough).
Situation 2: Now place them 2.8m apart. You have +6 dB at equal distance from both, but huge dips at other locations.
If, as you say, the balance of dead spots to brighter spots was the only important thing, we would need spots "brighter" than 6 dB in situation 2. That just doesn't happen.
2)If you place two speakers close together, they are pushing the same piece of air. So each one has an easier time and absorbs less power from the generator. For this reason, no increase in sound field is obtained. Another way of looking at it is to say that each speaker is receiving power from the other, and when you measure the speaker impedance it is altered so that each speaker takes less power.
