Why does electric field strength increase as potential gradient decreases?
6 replies · 10K views · last reply
Arshad_Physic
What is the relationship between electric field strength and the potential gradient?
This is my Calc based Physcis lab question but I am at a total loss. I do not understand what potential gradient is in the first place. From google I figured out that it is rate of change.
My understanding is as the gradient decreases the electric field strength increases. But I know that by looking at graph I have made. I do not understand why is it so theoritically.
Please help!
Thanks,
Arshad
http://en.wikipedia.org/wiki/Potential_gradient
Check that out, thinking about it more mathematically;
You agree that the electric potential is given by [tex]v = \frac{kq1q2}{r^2}[/tex] , right?
Now when looking for the potential gradient, you're looking for the change of potential per distance moved away, so if for instance you plotted a graph of electric potential against distance away, the potential gradient is basically the gradient of that graph, so [tex]\frac{dV}{dr}[/tex] .
Now find [tex]\frac{dV}{dr}[/tex] where [tex]V = \frac{kq1q2}{r^2}[/tex]
you might see a similarity with E.
THanks! :) This makes much more sense to me now! :)
So basically, the more steeper the gradient (or equipotential lines) is, the mroe stronger the electric field gets, right?
Actually that's not quite right.
[tex]V = - \int _P E \cdot dl,[/tex]
Where P is an arbitrary path (i.e. V is the "voltage" between the two endpoints of the path),
Not that it matters much for this problem, but the potential of a point charge, with respect to infinity, is:
[tex] V = -\int _{\infty} ^{r} \frac{1}{4 \pi \epsilon _{0}} \frac{q}{r' ^{2}} dr'[/tex]
[tex]= \frac{1}{4 \pi \epsilon _{0}} \frac{q}{r}[/tex]
Note that it is a function of 1/r, not 1/r2.
But none of that really matters for this problem.
I think the question is asking you to look up a formula in your book, and compare it to the gradient of the potential.
The gradient of a scalar field is specified by the [tex]\nabla[/tex] operator (called the "del" operator). So the gradient of the potential is specified by [tex]\nabla V[/tex].
So look in your textbook for something that relates [tex]\nabla V[/tex] to [tex]E[/tex]. Although I haven't seen your textbook, I'm confident this relationship is in there.
Well, there is one:
E = -dV/dl
OR
V = - integral [ E dl]
Thanks soo much to both of you for yours' help! :)
Yeah >.< sorry Arshad, replace the 1/r^2 with a 1/r in my post, foolish on my part.
Is anyone here to explain the Result of electric field as potential gradient
E= -dV/dr
Please Explain this result
what is affect on electric intenity as Electric potential difference increase or Decrease
And aslo what is affect on electric intenity distance r increase or Decrease
Please Help me?
