Why does f(x-vt) represent a wave along +x?
  • Context: Undergrad
  • Thread starter Thread starter binrdow
    Wave
The function f(x-vt) represents a wave propagating in the positive x-direction, where v is the wave's velocity, t is time, and x is position. This formulation indicates that the wave's pattern moves along the x-axis at speed v, with the center of the wave located at x=vt. The confusion arises from the assumption that f(x+vt) would represent a wave in the positive direction, but the correct interpretation shows that f(x-vt) describes the wave's propagation from the origin to any point x at time t. This concept applies to various types of waves, including transverse, longitudinal, and water waves.
  • Understanding of wave mechanics and propagation
  • Familiarity with mathematical functions and their transformations
  • Basic knowledge of coordinate systems in physics
  • Experience with graphing functions, preferably using tools like Mathematica
  • Explore the mathematical properties of wave functions, specifically f(x-vt) and f(x+vt)
  • Learn about different types of waves, including transverse and longitudinal waves
  • Utilize Mathematica to visualize wave functions and their propagation over time
  • Study the concept of wave speed and its relationship with frequency and wavelength
Students and educators in physics, mathematicians interested in wave theory, and anyone seeking to understand wave propagation concepts in various contexts.
binrdow
I just can't understand how this makes sense. Why does f(x-vt) represent a transverse wave along +x? Where v is the velocity, t is time, and x is position along the x axis. It seems to be exactly the opposite to what I would think makes sense, with f(x+vt) representing a wave along +x and f(x-vt) representing a wave along -x. But this isn't the case! I've been trying to wrap my head around it, not matter how I look at it.
Can anyone explain this concept in a way that makes sense?
Thanks! :smile:
Let's for simplicity set our coordinates so that x= 0 when t= 0. If the object is moving at speed v, then at any future time, t, x= vt. So x-vt= 0. That is, f(0) "moves" along the x-axis at speed v.
Think of the function f(x-vt) as being a pattern of some kind. The pattern will propagate in the +x direction at speed v, because at x=0 and t=0, the pattern is f(0) (think of this as the center of the feature that is propagating), but at any other time t and x=vt, the pattern will still be f(0). So the center of the feature is always found at some x=vt, so is moving at speed v in the +x direction, because that's just what x=vt means.
Oh! Okay, so you just have to look at the equation for the position x first as x=vt. Thanks much! :biggrin:
Just remember that this statement does not apply to every f(x-vt) only suitable ones, although there are a great many such.
Which would be those restrictions? continuity?
The simplest example would be
f(x-vt) = k
Thanks! :smile:
I had this problem too and eventually came to this conclusion (a nice arm waving one).
f(x-vt) tells you what the function will be at x in terms of what it was, at the origin, t seconds ago (i.e. t is the time it took to propagate to x from the origin) - hence the negative t sign.
Confused more? - Sorry if you are but it helped me, once.
I believe the issue was the idea that the wave is "transverse", which is not a requirement of the f(x-vt) form. Anything that propagates at v has the form f(x-vt), including longitudinal and water waves.
Actually, this helps allot! Thanks! :)
If you have mathematica or a scientific calculator, you can plot the functions f(x) = cos(x - vt), let v equal some random number, and plot it as you vary t between different graphs. You'll actually SEE the graph moving to the right as you increase t.
I think it's a fantastically convincing argument for seeing how this works.
  • · Replies 17 ·
13K
  • · Replies 18 ·
