Why does moving a couple around seem to change the object's behavior?
  • Level: Undergrad
  • Thread starter Thread starter Trying2Learn
    Couple Vector
10 replies · 3K views
Trying2Learn
TL;DR
If couple is a free vector, then I can move it. However, I think the response is different
Hello
(Everyone here has been so helpful -- thank you. Things I thought I knew, I now doubt; and this is so helpful to have this group.)
There is an current discussion on Yaw. I am enjoying that. And that raised an issue for me.
However, I do NOT want to hijack that thread, so I am posting my question here.
I know that a couple is a free vector -- that means it can be moved. However, as I move the couple around, I see (in my mind) the object behaving differently, depending on where I "situate" the couple.
Could someone explain this to me?
See the attached PDF
BTW: I do understand how it is only the distance between the application points that matters. However, I cannot reconcile what I know to be true, with what I "imagine" happens.
https://www.quora.com/Why-is-couple-moment-a-free-vector
wrobel said:
Couple/sliding vector/free vector etc are just outdated and archaic terms. Find a good textbook
Well, this is the most fascinating comment (and I am NOT being facetious). PLEASE take a few minutes to explain this. You have hit a nerve and i want to understand.
Leads to inconsistency ##\Rightarrow## must be incorrect.
How do you 'know' that ?
Even a regular force is not a free vector. It has a line along which it acts. Moving the force along the line of action has no consequences.
Moving a force perpendicular to the line of action means adding a torque :
You have some misconceptions. The torque of a couple is indeed coordinate independent, i.e. $$\bar{\boldsymbol{\tau}} = \sum_{i=1}^2 \bar{\mathbf{x}}_i \times (-1)^i \mathbf{F} = \sum_{i=1}^2 (\mathbf{x}_i - \mathbf{X}) \times (-1)^i \mathbf{F} = \sum_{i=1}^2 \mathbf{x}_i \times (-1)^i \mathbf{F} = \boldsymbol{\tau}$$That means, the torque of the two forces ##\mathbf{F}## and ##-\mathbf{F}## on a body ##\mathcal{B}## is the same with respect to any frame ##\mathcal{O}xyz##, i.e. whether you choose ##\mathcal{O}## to be at the centre of the rod, the end of the rod, whatever. But if you want to analyse the dynamics, note that the centre of mass (##\mathcal{S}##) acceleration is zero,$$\ddot{\mathbf{x}}_{\mathcal{S}} = m^{-1} \sum_{i=1}^2 (-1)^i \mathbf{F} = \mathbf{0}$$i.e. the centre of mass moves at constant velocity with respect to an inertial frame. Meanwhile, angular velocity at time ##t## is determined fully by ##\boldsymbol{\tau}##, i.e. it's easiest to just pick ##\mathcal{O} = \mathcal{S}## and write ##\boldsymbol{\tau} = \dot{\mathbf{L}}##.
What the motion looks like depends on which frame you choose. In lab frame, for setup in your picture it just rotates about its mass centre ##\mathcal{S}##, whilst for [non-inertial] frame with ##\mathcal{O}## at end of rod it rotates about the end of rod.
To write equations of mechanics and to solve any problem it is sufficient to know only standard geometric vectors. See for example Classical Dynamics by Donald Greenwood.
Trying2Learn said:
Summary:: If couple is a free vector, then I can move it. However, I think the response is different
We are not mind readers, just text readers. To answer your question directly, one needs to understand what you see in your mind. So please explain in your own words what that is and, specifically, what kind of "different" behavior you think the object exhibits "depending on where you 'situate' the couple."
Found it (via: quora ##\rightarrow## PF ##\rightarrow## Wiki (add a right bracket) ) .
Ah, no need...
etotheipi nailed it when he mentioned which frame one views it in. I see now.
Sorry to bother everyone.
But thank you!
@Trying2Learn just to make sure, do you understand that the moment vector itself is an object that can be "moved around" however you like, but in no way does "where you choose to visualise it" affect the evolution of the system? Or in other words, that it has no relation to the axis about which the system is rotating, or anything like that?
YES! Thank you so much for that. It is obvious, right? And I am aware of how to visualize it.
I just never... visualized it. :-)
Thank you!
