Why Does My Calculated Integral Differ from My Calculator's Result?
  • Thread starter Thread starter Peppino
    Integral
The discussion revolves around finding the integral of the function (4-x)x^{-3}. The original poster compares their result with that of a calculator, noting discrepancies in the outcomes.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use U-Substitution but questions their approach after receiving feedback. Some participants suggest that the integral can be simplified without substitution. Others raise questions about the nature of indefinite integrals and the significance of the constant of integration.
Participants are exploring different methods to solve the integral and discussing the implications of differing constants of integration. There is recognition that two expressions can be valid solutions even if they differ by a constant.
There is mention of confusion regarding the values of C in the context of indefinite integrals, as well as the impact of using different methods on the resulting expressions.
Peppino
I have to find the integral of [tex](4-x)x^{-3}[/tex]. My TI-89 says it should be [tex]\frac{x-2}{x^{2}}+C[/tex] but I can't seem to get it myself.I rearranged it to get [tex](4x^{-1}-1)x^{-2}[/tex] and then I used U-Substitution. And set [tex]U = 4x^{-1}-1[/tex] so that [tex]dU = -4x^{-2}dx[/tex]Then I rewrote the integral as [tex]-\frac{1}{4}\int Udu[/tex] and evaluated it to get [tex]-\frac{1}{8}U^{2}+C[/tex]or [tex]-\frac{1}{8}(4x^{-1}-1)^{2}+C[/tex] which works out to [tex]-\frac{(x-4)^{2}}{8x^{2}}+C[/tex]which is not what my calculator says it should be.
What am I doing wrong?
...and if I have to make another Latex equation...
1) If you hadn't dropped the [itex]\frac{1}{8}[/itex], your answer is correct.
2) Your calculator also has a correct answer.
3) They're actually the same answer. How can that be?
4) You're making this integral WAY more difficult than it actually is. You don't need a substitution. Why did you just distribute [itex]x^{-1}[/itex] through instead of [itex]x^{-3}[/itex]?
Right... I meant to put the 1/8 in there. But when I graph the two expressions I get two completely different tables of values. Are you sure they are the same?
As for the unnecessary U-Substitution... that's just me being a moron I guess
What do you see when you look at the graphs? How are the graphs comparable?
What is an indefinite integral? Is it a function, or perhaps something ... broader? Whats that +C for?
The table of values are completely different... on my calculator's answer, x = 1 yields -1, while on mine x = 1 yields -1.125.
Is it not a function?
Because an infinite number of different values of C could lead to a function with a derivative of the original function
Doing the non-moronic way I get the same answer as my calculator. I'll stick with that for now but any comments will still be appreciated
In other words, carry out the multiplication to arrive at this integral:
$$ \int 4x^{-3} - x^{-2}~dx$$
It should be pretty simple after that.
Yes, I realized that. Any guess as to why my circuitous method didn't work?
[itex]\displaystyle -\frac{(x-4)^{2}}{8x^{2}}-\frac{x-2}{x^2}=-\frac{1}{8}[/itex]
The answers differ only by a constant, so both have the same derivative.
To add to what SammyS said, remember that that so-called "arbitrary constant" of indefinite integration is really that - completely arbitrary. Any constant added to your answer will still give a completely valid answer. So when two expressions differ only be a constant value, they are both equally valid solutions.
Even though you wrote the "expected" solution and yours with the constant having the same symbol [itex]C[/itex], remember that they're actually different in value (they differ by [itex]\frac{1}{8}[/itex] in this case). It would be more mathematically correct to write the constant in one case as [itex]C_1[/itex] and the other as [itex]C_2[/itex] so you don't get confused.
Oh, I see it. That's interesting. So when using different methods to find an integral, the value of C (or, what's included in C) would change?
C can be different.
Two correct answers can differ by a constant.
For a different example that shows how two different techniques can produce what seem to be different antiderivatives, consider
$$ \int sin(x)cos(x)dx$$
If you let u = sin(x), du = cos(x)dx, you get an antiderivative of (1/2)u2 + C = sin2(x) + C1
OTOH, if you let u = cos(x), du = -sin(x)dx, and you get an antiderivative of -(1/2)u2(x) + C2 = -(1/2)cos2(x) + C2.
Even though the two answers appear to be significantly different, they differ by a constant (1/2). The key is the identity sin2(x) + cos2(x) = 1.
  • · Replies 105 ·
13K
  • · Replies 18 ·
  • · Replies 22 ·
