Why does releasing compressed gas cause the container to cool down?
  • Context: High School
  • Thread starter Thread starter masscal
    Compressed Gas
The discussion revolves around the phenomenon of cooling observed when compressed gas is released from a container. Participants explore the underlying mechanisms, including molecular behavior, energy transfer, and the implications of gas expansion against atmospheric pressure. The conversation touches on theoretical aspects, hypothetical scenarios, and the kinetic theory of gases.
  • One participant questions why releasing compressed gas cools the container, drawing an analogy to evaporating water cooling the skin.
  • Another participant explains that the gas does work against atmospheric pressure, resulting in a loss of internal energy and a decrease in temperature.
  • A hypothetical scenario is proposed where only one gas molecule escapes from a compressed space, questioning whether the remaining molecules would slow down.
  • Some participants argue that the release of one molecule would lower the pressure and temperature of the remaining gas, while others challenge this reasoning.
  • Discussion includes the idea that the fastest molecules are more likely to escape first, leading to a change in the velocity distribution of the remaining gas molecules.
  • There is a suggestion that if a random molecule escapes, it may not necessarily lead to a temperature change in the remaining gas.
  • Participants explore the implications of collisions among gas molecules and how they affect the likelihood of faster molecules escaping.
  • One participant asserts that if gas expands into a vacuum, it would not cool down, as no work is done in that scenario.
  • Another participant emphasizes that the gas expands into the atmosphere, doing work and resulting in cooling.
Participants express varying viewpoints on the mechanisms behind the cooling effect of released gas. Some agree on the role of work done against atmospheric pressure, while others question the implications of individual molecule behavior and temperature changes. The discussion remains unresolved with multiple competing views.
Participants acknowledge the limitations of discussing gas behavior in terms of a few molecules, emphasizing that kinetic theory typically involves a large number of molecules. The assumptions made in hypothetical scenarios may not fully capture the complexities of real gas behavior.
masscal
Preface- I am a scum noob who doesn't know much.
Why does a compressed gas cool a container down when released?
I mean in terms of imaging the actual gas molecules moving around. For instance, I can imagine why water on the skin evaporating could cool a person down. The body transfers kinetic energy to the water and then some of the really fast most energetic water molecules fly off, thus taking that energy with it.
If you open the valve on a compressed gas container shouldn't the gas just fly out and not take any extra kinetic energy with it?
Science news on Phys.org
The gas expands doing work against the external atmospheric pressure. Since it does the work, it ought to loose some internal energy resulting in lowering of its temperature.
Ok, it lost some energy when the moving gas molecule flew out. What if you compressed three gas molecules in a really really tiny space, open a tiny vale to let one molecule fly out. Would the other two some how slow down?
Yes. Since, the volume remains constant, release of one molecule will result in lowering of pressure apparently lowering its temperature and kinetic energy is a function of temperature. So speed of the other two will decrease.
I still don't see why the would slow down. I guess I am looking for a detailed description of why the individual gas molecules left behind would be moving slower. I would like to scale it up to balls bouncing in a room. say, If three balls were bouncing around a room and one flew out, I don't see how the other two would slow down, even if the net pressure on the walls and two balls went down.
In a sealed container with an ideal gas at temperature T, there exists a range of velocities from very high to very low. Should the container be opened, the fastest molecules will escape preferentially over the slow ones. As a result the velocity distribution in the container changes towards the lower values, which is equal to lower temperature.
Kinetic theory of gases uses as an assumption that there exists a large number of molecules, so it really shouldn't be thought of in terms of just three molecules in a box. But even here, you should see that with the box being opened by e.g., removing one of the sides, the fastest of the three has got the highest probability of leaving first.
So the explanation is that the gas molecules with greater velocities are a little more likely to fly out of the valve? Are there simulations of this that have been done before?
Fastest molecule is the most probable to escape.
But, if one random molecule just disappears, then we can say no temperature change happens in the tiny box.
Molecule disappears, pressure drops, temperature stays the same. (more exactly temperature raises or drops with equal probability)
So does this mean the gas that escapes should be hot?
Yes, it's a correct conclusion that in our thought experiment the escaping gas is hot.
And from this we can conclude that this is some other phenomenom, not the one we are currently interested, right?
If the three molecules, racing towards the opened valve, collide with each other many times during the race, then a random molecule wins the race, the winning molecule has random speed. The molecules escape in random order.
If the three molecules, racing towards the opened valve, do not collide with each other during the race, then a faster molecule is more likely to win the race. The fast molecules escape first.
I'm sorry I am not exactly sure what you are saying. Are you saying it is this phenomenon that is causing the compressed gas to cool when the valve is opened?, and if it that phenomenon, then why is it that you can freeze things with the compressed gas that escapes.
No. To understand this you should understand the idea of work. "Work" in physics means something very specific. When work is done, energy is transferred. If you let a lone molecule out of a container and it doesn't hit anything, it cannot transfer energy and cannot do work. If you let a gas expand into a vacuum its temperature would remain the same. It has not lost energy, it has not done work, it will not cool down.
Now consider your compressed gas. It is not being released into a vacuum. Its being released into another container of (less) compressed gas (the atmosphere). When you open the valve on your spray can the gas cannot just escape because there is another gas there blocking its way. It has to push against the atmosphere which is "doing work". The compressed gas does work on the atmosphere. The compressed gas expands and cools, the atmosphere becomes slightly more dense and heats. At a molecular level your compressed gas molecules collide with the atmospheric molecules transferring some of their momentum and energy to the atmosphere.
Note that when you see the ideal gas law explained in chemistry texts you should always see the gas pictured in a container with a piston or something like that on top. This piston behaves like the atmosphere in that is provides something for the compressed gas to do work on while it expands.
Would this mean that the faster molecules are most likely to collide with the atmosphere?
I'm saying there are many phenomena, and maybe we'd better forget that one where molecules are being sorted by making them race.Instead, how about if we consider one molecule and a nozzle.
If a molecule is released at the narrow end of the nozzle, the molecule will fly out of the nozzle, and then the molecule may cool a thing that is after the nozzle.
A picture: < =
Nozzle at the left, plates that will be cooled at the right.
Exercise for the reader: Check that this device works. Note: There are no other gas molecules except the one.
Forget everything you've read above. For most practical situations the work done by a gas as it expands can be considered negligible. The Joule–Thomson effect is the most important effect. For most gasses, at room temperature at a reasonable amount of pressure the Joule–Thomson effect leads to cooling, but there are important exceptions. Helium and Hydrogen will actually often warm up as they expand. In order to explain the Joule–Thomson effect you must realize that real gasses behave different than ideal gasses. The molecules in a gas actually attract each other and will slow down when they move apart which leads to cooling under expansion. Surprisingly, warming sometimes happens instead. That happens because as a gas expands, the molecules will collide less often. During a collision molecules will suffer repulsive forces instead of attraction. That means that during a collision the molecules move more slowly. If the collision happen less often, the molecules average speed increases leading to higher temperature. That second effect can be dominant for certain gasses.
Also note that if you're thinking of the cooling observed when using a propane tank, the propane is actually in a liquid state and changes phases to a gas before being released. That change of states requires latent heat taken from the gas which will than cool down.
So isn't that two explanations then?/ if it is a state change why would it need latent heat, surely each individual molecule has enough energy to escape.
Temperature is a measure of the average energy of the molecules. Some will have low energy, most will have a medium amount of energy, and a few will have a high amount of energy. Only the ones with the high amount of energy will have enough to change states. When they do, they take their energy with them. Then, through random collisions, some of the remaining low and medium energy molecules will be given enough energy to change states. When this energy is transferred from the other molecules, they cool down. Repeat the process a few trillion times and the liquid cools down dramatically.
"Maxwells Demon" may have some relevance to this discussion.
That's the definition of latent heat.
[Edit: Perhaps you are thinking the kinetic energy of an individual molecule is always constant. It isn't: it changes due to collisions.]
I think the latent heat of evaporated liquid is probably most of this issue. Cooling of a gas in an actual compressed air tank is small because it decompresses very slowly, but cooling due to evaporation is substantial and when you buy a can of "compressed air" for dusting it isn't actually compressed air. But the OP didn't specify the situation.
Maybe we should calculate an example?
A picture: < =
Maybe I shoud try to do this exercise myself.
First the molecule has a random velocity, which is also known as thermal motion. When the molecule flies off the nozzle, the velocity becomes less random, which we might call cooling. Now the molecule can be used to dampen random vibrations of the molecules of a steel plate.
The non-random motion of the molecule may cause some frictional heating though. So to make sure the device works, we do this:
On the left the nozzle, on the righ the edge of a spinning disk. The disk surfase moves to the right where the molecule that is moving to the right collides with the disk, so no frictional heating, so the disk cools.
No, a molecule always has a specific velocity that changes after collisions with other molecules. Looking at this scenario with only one molecule is not going to help. You need to look at it as a collection of a large amount of molecules otherwise the laws don't make any sense.
Now the molecule can be used to dampen random vibrations of the molecules of a steel plate. The non-random motion of the molecule may cause some frictional heating though. So to make sure the device works, we do this:
As a whole, the expanding gas has a large number of molecules. A few molecules may add energy to the plate, but most of the gas will be taking energy away from the plate and cooling it.
Single molecules and atoms are generally moving at extremely fast speeds and the bulk rotation of the disk as a whole is extremely slow compared with this velocity. Some of the gas will actually be going the opposite direction of the disk when they collide since gas molecules bounce all over the place. The interactions that lead to the transfer of energy to or from the disk have more to do with how each gas molecule interacts with the atoms and molecules in the disk (which also have thermal energy).
Consider a turbine in a dam. Water flows down and turns the turbine, but the speed of the turbine depends on the flow of the water as a whole, not of the velocity of each individual water molecule, which tends to be much faster than that of the stream as a whole. The stream of water moves much slower because many of the water molecules will be moving a direction opposite to that of the flow. It's simply that when you add up all the velocities of the molecules there is a small net amount in the direction of the flow.
Okay, many water gas molecules escape from a tank that is in vacuum. Using an infrared camera we can measure the temperature of the gas, and we will observe that the escaped gas has cooled.
Note that gas expanding into a vacuum is a different situation from what we were talking about. In this case, the gas does no work on the surrounding environment so the only loss in kinetic energy is due to attractive intermolecular forces, which convert part of the kinetic energy to potential energy, and radiation losses, both of which decrease the temperature.
Note that an "ideal" gas expanding into a vacuum does not experience a drop in temperature due to there being no forces between the molecules and no radiation.
See here for more info: http://www.etomica.org/app/modules/sites/JouleThomson/Background2.html
Consider simply a cylinder and piston. The speed of gas molecules relative to cylinder is v and the piston is moving out of the cylinder at u, which is much smaller than v. Assume that the gas is so tenuous that the molecules do not collide with each other, but only with cylinder and piston.
Then a gas molecule colliding with piston has speed v relative to cylinder, but its speed relative to the piston moving out of the cylinder is v-u. After colliding with piston its speed relative to piston is still v-u, but now in the other direction - so the speed relative to cylinder is now v-2u
The molecule then travels back to cylinder head, and collides with cylinder head. Its speed relative to cylinder head remains unchanged at v-2u, but its speed relative to piston is now v-3u. Now it collides with piston again, and again loses speed. This process goes on until u is no longer small relative to v, but actually bigger, and the molecules will never again catch up with the piston or cylinder head.
  • · Replies 32 ·
  • · Replies 42 ·
12K
15K
