Why Does Rubber Create Sparks When Rubbed Against the Floor?
  • Context: High School
  • Thread starter Thread starter eRa
    Rubber Spark
The discussion revolves around the phenomenon of rubber creating sparks when rubbed against the floor, exploring the underlying mechanisms and implications. Participants consider the nature of rubber as an insulator and its practical applications in footwear, particularly in relation to static electricity and safety concerns.
  • One participant questions why rubber, an insulator, creates sparks when in friction with the floor and seeks alternatives for shoe sole materials.
  • Another participant suggests that the observed spark might originate from a rock or metal piece embedded in the shoe sole, challenging the initial observation.
  • A participant asserts that they are confident in their observation, referencing a physics question from a solution manual.
  • There is a challenge regarding the relevance of the spark issue if the participant has not witnessed it, raising questions about the significance of the problem.
  • One participant emphasizes that there is no perfect insulator and highlights the importance of understanding the magnitude of static electricity in practical scenarios, noting the common use of rubber-soled shoes.
  • Another participant explains that the sparks result from a buildup of static electricity due to friction, detailing the process of electron transfer between insulators and mentioning the potential dangers of small sparks in flammable environments.
Participants express differing views on the cause of the sparks, with some attributing it to static electricity while others question the observation itself. The discussion remains unresolved regarding the significance and implications of the phenomenon.
There are assumptions about the visibility of sparks and the conditions under which they occur, as well as a lack of consensus on the relevance of the issue to shoe design.
eRa
Rubber is an insulator, so why does it make a spark upon friction with the floor?
What would be a good material for shoe soles to avoid this problem?!
Are you sure you were not seeing the spark from a piece of rock or metal embedded in the sole of someone's shoe?
yes I am.
I did not see it. It was a part of an answer to a phy question in my solution manual!
If you have never seen it, why is it a problem with shoes?
does it really matter to you if it involves shoes!?
& believe it or not the question was about shoes!
There is no such thing as a perfect insulator. Your question doesn't have any sense of magnitude to it. This is important for determining when things matter and when they don't. People use rubber soled shoes, right? What does that tell you?
It is because of a build up of static electricity caused by friction,electrons are scraped off one insulator and dumped on another.In air an electric field strength of about three million volts per metre can cause discharge and a spark.The most dramatic demonstration of sparking is with lightning strikes but even small sparks can be dangerous eg in environments where there are flammable materials.
  • · Replies 60 ·
47K
  • · Replies 19 ·
