Why does shuttling ball travel faster if plates are closer together?
  • Thread starter Thread starter obviousbicycle
    Ball Plates Travel
As conductive plates are brought closer together, the strength of the electric field increases, leading to greater acceleration of the shuttling ball. Despite this increased acceleration, the ball does not achieve a higher final speed when it reaches the opposite plate compared to when the plates are further apart. The mean speed of the ball as it travels between the plates remains constant if the potential difference is unchanged. The uniformity of the electric field across the gap does not negate the impact of the reduced distance on acceleration. Thus, while the ball accelerates more quickly, its overall speed remains the same at the point of impact with the plate.
obviousbicycle
Shuttling ball.
I was told that as the two conductive plates are brought closer together the speed the shuttling ball travels between them is increased. I don't understand this as i thought because the electric field is uniform between plates the distance they are apart wouldn't affect the attraction of the ball towards them. Could anyone explain this, thanks.
The field IS uniform as we go across the gap from plate to plate and as we go across the gap parallel to the plates (except near the edge of the plates). But the STRENGTH of the field increases as the gap is diminished. This means that the ball's acceleration is greater. The ball has constant acceleration until it hits the opposite plate. But because the plates are closer together, it doesn't acquire any larger a final speed than when the plates were further apart. So its mean speed as it traverses the gap is the same whether the gap is smaller or larger, provided that the p.d. between the plates is the same.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
9K
20K
