Why Does the Acceleration Formula Work?
  • Context: High School
  • Thread starter Thread starter staetualex
    Acceleration
5 replies · 2K views
staetualex
Hy folks! I am new in here.Anyone can give a basic intuition about why the acceleration formula actually works? I mean, my brain is not capable to "nerd-ize" formulas, i either forgot them , i either on a test write the coulomb formula something like (q1 q2 r^2)/2pi eps0. I am shure if i remember now the (d^2 x)/(dt^2) in a couple of months it will be something like dx^2/dv or whatsoever . Is anyone who can describe this formula, how it holds in a real example, some associations with other processes, etc. what every number/letter in that formula represent? I mean change in time square, what :confused:? thanks and have a good day!
It's a matter of learning to translate from math to English (and back).
x is position, t is time.
[tex]v={{dx}\over{dt}}[/tex] or "velocity is the rate of change of the position"
[tex]a={{dv}\over{dt}}[/tex] or "acceleration is the rate of change of the velocity"
Now that we're done defining terms, let's look at what that means:
Since v is the first derivative of x, and a is the first derivative of v, then a can be written as a second derivative of x.
Since both first derivatives are taken with respect to t,
[tex]a={{dv}\over{dt}}={{d^{2}x}\over{dt^{2}}}[/tex]
I don't think I can stress enough just how much it helps to understand the math--I took a course once where I had to memorize 37 equations for the first test alone. Needless to say, it didn't go well. But on a second attempt at the course, with a better understanding of the math involved, I only had to memorize four or five equations and could derive all of the others in about a minute total.
hi, staetualex, take a little time on chain rules.
It's not dx^2/dv; it's vdv/dx.
I can't help you, but I thank you for adding a cool new word to my vocabulary. :smile:
First, look at the simplest possible case (constant acceleration).
If a is constant, then the solution for velocity looks like v=at+k.
When t=0, we know that at=0. This is pretty obvious so far, but it does tell us that k is the velocity at that time. Since it's the initial velocity of the object, I'll change the name of that variable to something that let's me remember what it represents.
[tex]v=at+v_{i}[/tex]
Now if we go back to the definition of velocity, we have [tex]{{dx}\over{dt}}=at+v_{i}[/tex]. We integrate again to solve for position, and get the following:
[tex]x={{{at^{2}}\over{2}}+v_{i}t+k[/tex]
Again we note the first two terms are zero, when t=0, so this time k must be equal to the initial position. So once again, we rename that variable to something easier to remember.
[tex]x={{{at^{2}}\over{2}}+v_{i}t+x_{i}[/tex]
well, i know, i was just predicting my future, in case i mechanically learn the formulas, not knowing the principle it works. I may forgot them, or scramble the terms involved. Others who gave a reply on post, thank you, you helped me to understand better the Schrödinger equation proof.
Phase shifter, you are great, now I'm not dependent of the formula anymore, i can derive it by myself.
to danger, i am glad i can help , sometimes i can invent new words .
