fourthindiana
- 162
- 25
The outdoor fan on heat pumps always runs when the compressor is pumping refrigerant when the heat pump is in heating mode unless the heat pump has defect(s). I don't understand why the outdoor fan on a split system heat pump needs to run when the heat pump is in heating mode.
When a split system heat pump is in heating mode, the outdoor coil is the evaporator coil. When a split system heat pump is in heating mode, the outdoor coil absorbs heat from the outdoor air. I don't see how the outdoor fan would help the outdoor coil absorb heat.
If anything, it seems to me like the outdoor fan would blow heat away from the outdoor coil. I cannot think of any reason why it would make a heat pump more efficient or otherwise help heat a house or building to have the outdoor fan running on the outdoor coil when a heat pump is in heat mode.
Why does the outdoor fan on a heat pump need to run when the heat pump is in heating mode?
