Why does the scalar potential transform as V → V + ∂ψ/∂t in a gauge transform?
9 replies · 3K views
yungman
I understand ##\vec A\rightarrow\vec A+\nabla \psi\;## as ##\;\nabla \times \nabla \psi=0##[tex]\Rightarrow\;\nabla\times(\vec A+\nabla \psi)=\nabla\times\vec A[/tex]
But what is the reason for
[tex]V\;\rightarrow\;V+\frac{\partial \psi}{\partial t}[/tex]
What is the condition of ##\psi## so
[tex]\nabla \left(V+\frac{\partial \psi}{\partial t}\right)=\nabla V[/tex]
Thanks
Recall Faraday's law:
$$ \nabla \times \vec{E} = - \frac{\partial \vec{B}}{\partial t} = - \frac{\partial}{\partial t}\left( \nabla \times \vec{A} \right)$$
So it's tempting to make the definition
$$ \vec{E} = - \frac{\partial \vec{A}}{\partial t} $$
but now we make your transformation
$$ \vec A\rightarrow\vec A+\nabla \psi\ $$
$$ \vec{E} \rightarrow \vec{E} - \frac{\partial \nabla \psi}{\partial t} $$
so the electric field now fails to be gauge invariant. So we introduce another gauge-dependent parameter to "fix" this:
$$ V\;\rightarrow\;V-\frac{\partial \psi}{\partial t} $$
and change our definition of E
$$ \vec{E} = - \frac{\partial \vec{A}}{\partial t} - \nabla V $$
Now the electric and magnetic fields are gauge invariant, as required.
From
How do you get to
Thanks
Given a vector potential ##A##, we can write Faraday's law as ##\nabla \times (E + \partial_{t}A) = 0##. Now it is a fundamental result of differential topology that a curl free vector field in a 'nice enough region' (I'll spare you the details of what 'nice enough region' means) can be written as the gradient of some smooth scalar field ##V## i.e. ##E + \partial_{t}A = -\nabla V##; ##V## is of course the scalar potential. Hence the electric field can be written as ##E = -\nabla V - \partial_{t}A##.
Now there is a gauge freedom in the potential fields. Notice that if we define a new vector and scalar potential by ##A' = A + \alpha, V' = V + \beta##, where ##\alpha## is a vector field and ##\beta## a scalar field, such that the new pair gives us the same physical electromagnetic field then we must have that ##\nabla \times \alpha = 0## and ##\nabla \beta + \partial_{t}\alpha = 0##. The first condition implies that ##\alpha = \nabla \lambda## for some smooth scalar field ##\lambda##. The second condition consequently says that ##\nabla(\beta + \partial_{t}\lambda) = 0## meaning that the expression in the parenthesis is only a function of time ##\beta + \partial_{t}\lambda = \gamma(t)## i.e. ##\beta =- \partial_{t}\lambda ## where we have absorbed ##\gamma(t)## into ##\lambda##.
In other words, we can make a gauge transformation of the form ##A \rightarrow A + \nabla \lambda , V\rightarrow V - \partial_{t}\lambda## and still get the same physical electromagnetic field.
Thanks
What is the meaning of Gauge? What is Gauge freedom, Gauge invariant?
Hi. In the above context, a gauge is just a particular choice of ##A,V##. The potential fields have a gauge freedom in the sense that any two gauges ##A,V## and ##A',V'## such that ##A' = A + \nabla \lambda## and ##V' = V - \partial_{t}\lambda##, will result in the same physical EM field. A gauge invariant quantity is one that does not depend on the choice of gauge.
Thanks for the detail reply
Do you mean ##\beta## is a function of time ONLY where we let ##\beta=-\frac{\partial \lambda}{\partial t}##. Since ##\beta## is a time function ONLY, ##\nabla \beta=0##?
Am I understanding this correctly?
So for ##\nabla \lambda\;\neq\;0\;and\;\beta=\frac{\partial\lambda}{\partial t}##, then ##\lambda=f(x,y,z)+g(t)## so ##\nabla \lambda=\nabla (f(x,y,z)),\; \beta=\frac{d g(t)}{d t}##
Thanks
Nono I'm saying that since ##\nabla (\beta + \partial_{t} \lambda) = 0##, all of ##\beta + \partial_{t} \lambda## is a function of time only i.e. ##\beta + \partial_t \lambda = \gamma(t)## hence ##\beta = \partial_{t}\lambda - \gamma(t)##. Then I just absorbed ##\gamma(t)## into ##\lambda## i.e. I defined a new ##\lambda'## by ##\lambda' = \lambda + \int _{0}^{t}\gamma(t')dt'## then ##-\partial_{t}\lambda = -\partial_{t}\lambda'-\gamma(t)\Rightarrow \beta = -\partial_{t}\lambda'##.
I got it, I mistakenly thinking ##\nabla \times \vec \alpha=0\;\Rightarrow\; \vec \alpha## is position independent. But actually it only means ##\vec \alpha## is irrotational, but it can still be a function of 3 space coordinates.
Thanks
The electromagnetic field in terms of the four-potential reads (using Heaviside-Lorentz units with [itex]c=1[/itex])
[tex]\vec{E}=-\vec{\nabla} \Phi-\partial_t \vec{A}, \quad \vec{B}=\vec{\nabla} \times \vec{A}.[/tex]
From the second equation we see that the magnetic components don't change, if I use
[tex]\vec{A}'=\vec{A}-\vec{\nabla} \chi[/tex]
with an arbitrary scalar field [itex]\chi[/itex] instead of [itex]\vec{A}[/itex] as vector potential. Now we look for a scalar potential [itex]\Phi'[/itex] such that
[tex]\vec{E}=-\vec{\nabla} \Phi'-\partial_t \vec{A}'=-\vec{\nabla} (\Phi' -\partial_t \chi)-\partial_t \vec{A}.[/tex]
The expression in the parentheses must be [itex]\Phi[/itex], and thus
[tex]\Phi'=\Phi+\partial_t \chi.[/tex]
Thus the gauge transformation of the potentials must be
[tex]\Phi'=\Phi+\partial_t \chi, \quad \vec{A}'=\vec{A}-\vec{\nabla} \chi.[/tex]
