Why does XY|a> = <a|Y*X* in bra-ket notation?
23 replies · 10K views · last reply
indigojoker
I need to show that (XY)^(dagger)=(Y)^(dagger)(X)^(dagger) using bra-ket algebra
where X and Y are operators
say we started out with: if we dagger it (using *):
XY|a> = X(Y|a>)=(X(Y|a>))=((Y|a>)X*)=<a|Y*X*
we also know that XY|a>=<a|(XY)* by definition, so (XY)^(dagger)=(Y)^(dagger)(X)^(dagger)
My question is on how valid this statement is:
I don't understand at all X(Y|a>)=(Y|a>)X*
that's what I'm not sure about, actually, i get here and I don't know what to do:
XY|a> = X(Y|a>) = (X<a|Y*)
That's not correct. When you say X<a|Y* you are multiplying a matrix by a row vector, which is impossible.
Basically you have two properties of the adjoint which are useful in this problem:
|Xa> = X|a>
and
<Xa| = <a|X*
And also don't forget that the product of two operators can be treated as another operator.
EDIT: In fact only one property: <Xa| = <a|X*
i'm not sure what the difference between |Xa> and X|a> is
also, my books says you can go from X(Y|a>) to (<a|Y*)X*
i don't know how that is possible
If you translate |Xa> into words it is the column vector resulting from the multiplication of the matrix X by the a row vector having the components a0, a1, a2, ...
X|a> would translate as the result of multiplying the matrix X by the column vector |a>
Because |a> has the components a0, a1, a2, ... it results that |Xa> = X|a>
On the other hand <Xa| is the conjugate transpose of the column vector resulting from the multiplication of the matrix X by the a column vector having the components a0, a1, a2, ...
<a|X would translate as the result of multiplying the conjugate transpose of |a> by the matrix X. It is clear that they are not necessarily equal.
Try to use the property <Xa| = <a|X*.
Start from <XYa|. Considering that XY is also an operator, apply the property above. Then considering that Ya is a vector and X an operator, apply the property above.
so I'm trying to get from X(Y|a>) to (<a|Y*)X*
X(Y|a>)=X(<a|Y*)
the rules that has been listed does not say what to do in this situation: X(<a|Y*)
i could do X<Ya| but that still doesn't really help
X(Y|a>)=X(<a|Y*)
I already told you that X(<a|Y*) can't be calculated. Use the hints that I gave you.
Look, I'll do the second part and you do the first part.
I start from <XYa| and considering that Ya is a vector and X an operator, I apply the property <Xa| = <a|X* and get:
<XYa| = <X(Ya)| = <Ya|X* then, I apply the property for <Ya| i.e. <Ya| = <a|Y* and get:
<XYa| = <X(Ya)| = <Ya|X* = <a|Y*X*
Now all you have to do is to start from <XYa| , consider that XY is an operator, and apply the same property <Xa| = <a|X*
You will get <XYa| = <(XY)a| = ...
using your hint of <a|XY = <X*a|Y=<Y*X*a| and <a|(XY) = <(XY)*a| to prove it, but I am still not sure how my book gets from X(Y|a>) to (<a|Y*)X*
That's also a solution.
i know that is the solution, my question is trying to understand what my book did.
how it went from X(Y|a>) to (<a|Y*)X*
indigojoker said:
im still not sure how my book gets from X(Y|a>) to (<a|Y*)X*
I don't think they are sayng that X(Y|a>) = (<a|Y*)X* but rather X(Y|a>) <-> (<a|Y*)X* which means that (<a|Y*)X* is the corresponding bra of the ket X(Y|a>) which is true.
indigojoker said:
what does "the corresponding bra of the ket" mean?
<a| is the corresponding bra of the ket |a>
Check the wikipedia page on bra-ket notation.
so, the transpose conjugate of X(Y|a>) is (<a|Y*)X* ?
Exactly.
thanks!
also, i was wondering, is the kronecker delta the same thing as the dirac delta in the form delta(a-b)
that is, [tex]\delta _{a,b} = \delta(a-b)[/tex]
I'm really wondering if a and b were orthonomal sets, then:
[tex]\langle a|b \rangle = \delta _{a,b} = \delta(a-b)[/tex]
They are not the same but the Dirac delta has a similar role as the Kronecker delta, when the dimension of the space is infinite.
so if a and b were orthonormal sets, would:
[tex]\langle a|b \rangle = \delta(a-b)[/tex]
or
[tex]\langle a|b \rangle = \delta _{a,b}[/tex]
<a| and <b| are vectors. If they are orthogonal then <a|b> = 0, and indeed, in the general case [tex]<a|b> = \delta(a-b)[/tex] but only if <a| and <b| are of infinite dimension. If they are of finite dimension then [tex]<a|b> = \delta_{a,b}[/tex]
The original question can be answered trivially if you recall that the Hermitian adjoint of an operator is defined using the mapping onto a dual space of the ket space.
[itex]A ^{\dagger}[/itex] is defined as: [tex]A|a \rangle \leftrightarrow \langle a|A^{\dagger}[/tex]
So, [tex]X (Y |a \rangle ) \leftrightarrow ( \langle a | Y ^{\dagger} ) X ^{\dagger}[/tex]
why isn't it [tex]X (Y |a \rangle ) \leftrightarrow X ^{\dagger} ( \langle a | Y ^{\dagger} )[/tex]
Why would it be ? Y|a> is a ket, call it |b>. The dual of |b> is <b| which is <a|Y^{\dagger}. Now <b| stays to the left of X^{\dagger} by the duality correspondence.
