Why doesn't Maple recognize matrix in list?
6 replies · 5K views · last reply
flyingpig
I am basically just trying to resolve this matrix in maple by using a list because for a big system, there is no way I am entering all the numbers one by one and only to find out later my size was wrong.
So for instance
A := matrix([[2,3,3,0],[3,1,4,9]])
Now for some reason, (and I already loaded the packages), once you hit enter, you cannot do anything to A
So for instance
Code:
>A^-1
>1/A
>Transpose(A)
>Transpose(A)
It returns my command.
Anyone got a clue? Also does anyone know how to set the default for 1-column matrices to MATRICES and NOT vectors? Getting tired of Maple's automatic switches
Install need the MTM package. Try this:
> restart; with(MTM);
> A := matrix([[2, 3, 3, 0], [3, 1, 4, 9]]);
> transpose(A);
> type(A, matrix);
Of course A-1 doesn't work since the matrix isn't square. And don't forget commands are case sensitive. No capital T on transpose.
So for instance
So for instance
Code:
>A^-1
>1/A
>Transpose(A)
>Transpose(A)
I haven't used Maple for a very long time, but I'll take a stab at your questions, for what it's worth.
1. I don't know why you even tried to get A-1, since A is not a square matrix.
Even if A were a square matrix, you might have problems with A^-1. I would put parentheses around the exponent to see if that made a difference.
2. For Transpose(A), I'm going to guess that Maple is doing the calculation, but since you didn't tell Maple where to store the result, you don't see anything. I would try B = Transpose(A).
> restart; with(MTM);
Wow, I have never even seen that one before. Looked it up on Maple Help, still don't know what it is, but it works! By the way, what does "restart" do? Because I tried it without restart and it still worked
No it worked when I loaded (the original) package with(LinearAlgebra) or Student Linear Algebra
I use Maple 15, they've managed to get across those problems storing factor thankfully.
And yes, I forgot that my matrix wasn't square, but even if it were square, it didn't work.
Here is the full code that I used originally
Code:
>with(LinearAlgebra):
>Transpose(A)
>Error, (in LinearAlgebra:-Transpose) invalid input: LinearAlgebra:-Transpose expects its 1st argument, A, to be of type {Matrix, Vector, scalar} but received A[/color]
Pink was the error message returned to me
EDIT: for some reason transpose (lower case t) also works, but for a square matrix, B^-1 still doesn't work
Restart re-initializes the worksheet. It is handy when you have made a bunch of changes and want Maple to start over with brand new uncorrupted variables. I always put it at the top of a worksheet so when I tell Maple to re-execute the worksheet it begins with new variables.
Use inv(A) for the inverse.
OKay I did this again today, but it's not working again.
I introduced
Code:
with(MTM):
And I listed out the matrix in
T0:= matrix([[...]])T1:=Pivot(MultiplyRow(T0,...,..)...,...)
EDIT; never mind, for some reason it worked with STUDENT Linear Algebra. I don't even know why they separate the two packages
