Why don't boxers' skulls shatter from the forces of punches?
The discussion revolves around the forces exerted during boxing punches and the implications for the structural integrity of the human skull. Participants explore the relationship between force, pressure, and the mechanics of impact, considering both theoretical and practical aspects of boxing and skull anatomy.
  • Some participants note that while the skull can withstand around 2000N of force, boxers can deliver punches exceeding this force, raising questions about skull integrity.
  • There is a contention regarding the interpretation of force versus pressure, with some arguing that pressure (force per unit area) is the critical factor in determining whether a skull fractures.
  • One participant suggests that the area of impact significantly affects pressure, implying that a larger area reduces the risk of fracture despite high force.
  • Another participant discusses how the shape of the skull and the dynamics of a punch may influence the distribution of force and resultant pressure upon impact.
  • Some participants highlight the role of boxing gloves in distributing force and protecting both the puncher and the recipient, which may mitigate the risk of skull fractures.
  • There is a mention of the complexities involved in calculating pressure based on varying impact areas and the confusion between units of measurement (Mega and Giga).
  • A later reply introduces the idea that the skull's curvature and varying thickness may affect how force is distributed during an impact.
Participants express differing views on the relationship between force and pressure, with no clear consensus on how these factors interact in the context of boxing and skull integrity. The discussion remains unresolved regarding the precise mechanics of impact and the implications for skull fractures.
Participants note that the initial articles referenced discuss conditions that may not fully apply to dynamic situations in boxing, such as the skull's movement and the nature of impacts. There are also unresolved questions about the specific measurements and calculations related to pressure and force.
BioPhysics2021
Hi All,
My question is in relation to forces that can come through movement. For example, the skull is stated to take around 520 pounds of force or around 2000N:
https://www.virginialeenlaw.com/help/how-much-force-can-a-human-skull-withstand.html
However, boxers can punch well in excess of 2000N of force:
https://bjsm.bmj.com/content/39/10/710
So then, how come boxers who get punched in the head don't have their skulls shattered straight away?
BioPhysics2021 said:
Hi All,
You are obviously misreading the first article. It talks about pressure and not force.
Sorry, I don't understand. The text as taken from the article is here:
"His bottom line, primarily based on a bike-helmet study published in the Journal of Neurosurgery: Pediatrics, is that a skull crush would require 520 pounds (2,300 Newtons) of force"
Is this not talking about force? I do appreciate that it also states
"Turns out the human skull can withstand 6.5 GPa of pressure, while oak holds up under 11, concrete 30, aluminum 69 and steel 200."
But I don't see how these are linked.
That makes no sense, unless you know the area of the helmet involved.
That's better. It's ultimately pressure (force per unit area) that determines whether something breaks.
PeroK said:
That makes no sense, unless you know the area of the helmet involved.That's better. It's ultimately pressure (force per unit area) that determines whether something breaks.
Oh, so what you are saying is that whilst 2000N may be generated by a standard boxer, concentrating all of that in a small area is what leads to the fracture/break.
But why does the first statement make no sense?
If you step on a nail, there is no more force than if you step on the floor. The nail does damage because the force is concentrated at a point. You could potentially fracture a skull with very little force if you used something sharp enough.
OK. I understand your answer.So then the summary is as follows:
1) Boxers may be able to generate massive amounts of force however unless this is delivered to an appropriate small area the pressure is likely to be much smaller. For example, if we take the most conservative estimate that the boxer punches in a 1 mm square area with 2000N of force, then the pressure amounts to 2GPa. Given the size and shape of the human hand the area is much more and therefore the pressure is much lower.
Boxing gloves are quite big. I would guess that the area of impact is more like ##20cm^2##. That would give about ##1MPa##.
Sorry, this seems a bit strange.
1 square mm --> 0.000001 square meter.
So then, P = (F/A) = (2000/0.000001) --> 2 000 000 000 Pascals which amounts to 2 GPa. Where did you calculate 2000 GPa from?
Yes, I got Mega and Giga confused!
OK. Thank you.
Now, as the head is curved would this mean that the force per unit area (i.e - pressure) is smaller or larger upon impact?
OK. Thank you.
Now you are getting into specific experiments to study this. There are many factors relating to the shapes involved and the dynamics of the punch. There must be a whole science now computer modelling contact sports.
Note that the first article talks about a skull that is placed against a flat surface or fixed to a support.
In boxing, the head inmediately accelerates; therefore, some of the input energy becomes kinetic energy of the skull.
The shull has not a spherical shape and thickness of the shell possible varies according to the area, because of that there should be weakest and strongest areas.
Note as well that the gloves protect the nuckles and metacarpal bones of the puncher as much as the skin and bones of the receiver, by distributing the force of impact on a larger area (more cross-section of bone is loaded) and by increasing the time lapse of the impact (reducing peak acceleration).
Please, see:
https://en.m.wikipedia.org/wiki/Boxer's_fracture
https://www.forcenecessary.com/boxing-gloves-are-for-boxers/
10K
11K
