- 967
Well, before trying to react to your other reactions, let's discuss your points about "what a physics theory isn't" and my points about "what an interpretation is".Ken G said:I'm still not seeing any observable contradictions. You are explaining what an interpretation is. I'm explaining what a physics theory isn't.
I have no problem with that. And as you already noticed, Heisenberg defended a very similar position.Ken G said:So the main problem is, we tend to imagine that the purpose of a physics theory is to describe what is actually happening in a place we think of as "objective reality." But such a place is never part of any physics theory, since theories just manipulate abstract notions to create predictions that can be tested.
Except that again and again, interpretations did just that. But you are right that Laplace was "untrue to the scientific method" when he did that. So you seem to be talking about what "interpretations in an ideal world" should be, not about how proponents of different "interpretation" behave in our world.Ken G said:What this also means is that we are untrue to the scientific method when we hold that any interpretation of quantum mechanics is a statement about objective reality, because if the theory was never demonstrably that, then so much less is an interpretation of a theory.
But if you look at a sphere from the front, no lens will change the fact that you cannot see the back. And if somebody else looks at the back, he can see something unrelated and different from what you see. And just like in the parable of the blind men and an elephant, he might start to argue that your observations contradict his observations.Ken G said:Instead, an interpretation of a theory is a kind of lens through which to look at a theory, a way to understand or make sense of the theory, not objective reality itself (as the latter is only what we observe, and the predictions we test thereby).
When I write that you misunderstand the relation between theory and interpretation, then I have something in mind like my own surprise, when I learned that a group representation is defined as
Intuitively, I would have expected that it should say monomorphism. But it says homomorphism. But the words realization and representation suggested to me that the "entire group" should be encoded, not just some arbitrary aspect of it. But then I learned that things just work better this way. And it is the same with interpretations. It is OK that Bohmian mechanics can only interpret non-relativistic QM, and has trouble interpreting QFT. It keeps its status as an interpretation, even if it cannot overcome its troubles with QFT. And other interpretations are allowed to miss aspects of QT too. For example, I would argue that MWI is currently blind when it comes to temperature.More formally, a "representation" means a homomorphism from the group to the automorphism group of an object. If the object is a vector space we have a linear representation. Some people use realization for the general notion and reserve the term representation for the special case of linear representations.
In total, I gave four examples. The MWI example and the Euclidean geometry example were carefully selected "especially for your request", and are in principle open to experimental falsification. However, your reaction was a sort of disbelief, or at least the feeling that I somehow lost you, or didn't get your point.Ken G said:I'm still not seeing any observable contradictions. You are explaining what an interpretation is. I'm explaining what a physics theory isn't.
I initially thought about using the Eikonal equation and the inviscid Burgers' equation as examples. Here, the math stays silent about what happens in the singularities (i.e. the points where the characteristics intersect), and there are different "interpretational attitudes", from "singularities only occur in pathological artificially constructed mathematical examples," over "obviously the entropy solution is the correct one, and the math told you that from the start", and "the caustic with multivalued functions is the correct solution, because the equation comes from geometric optics", to "we are agnostic as to what happens in the singularities, because this is outside of the domain of application for which the equations have been derived".
But I was unsure whether you would accept those equations as physical or mathematical theories. They are not theories in my sense, because nobody calls them theories, they are called equations. (For me, the actual usage of the words in practice is what is most important.) The investigation of partial differential equations on the other hand is called a theory, but "today" those interpretational ambiguities are already part of that theory. But maybe it would have been clearer for you that there are different interpretations with observable consequences, which can be right or wrong, depending on context. (They can contradict each other, but not the equation.)
Why are you so sure that the prediction from MWI is correct? I just say that Copenhagen is agnostic, especially with respect to scalability, as long as the context of temperature and non-isolation is missing. Maybe MWI should stay agnostic too, but some of its proponents claim that scalable quantum computers would be one of its predictions.Ken G said:It sounds like you are saying the Copenhagen interpretation predicts something about quantum computers that other interpretations do not predict.
Maybe MWI simply tempted some of its proponents to make a stupid mistake? Maybe "stupid" was an unfortunate word from my side. What I mean is "unnecessary" or "avoidable", in the sense that making that mistake is not necessary for defending the interpretation.Ken G said:That would be impossible, because then the CT would not be an interpretation of a theory, it would be different theory that makes different predictions using different equations.
Ken G said:It could not use all the same equations, because how can you use all the same equations and make a different prediction? I think you are not talking about interpretations of QT, you are guessing at whatever the next theory might be.
Guessing at the next theory is not what I do. I admit that my writing may be hard to follow, or that I didn't get your point. But this "next theory" thing was nowhere contained in my text. You have put it in there yourself. Also for Euclidean geometry, it is not that general relativity is a better theory where it is no longer "literally" valid. It might simply not be "literally" valid in the world out there (without any next theory having anything to do with that).Ken G said:But this is exactly the point, at issue is not "how it can be modeled", but rather, the testable predictions it makes. From the perspective of a scientific theory, everything else is counting angels on a pin. From the perspective of personal philosophy, and inspirations for the next theory, that's where we have interpretations.
