Why energy released when bonds formed
The discussion centers on the energy dynamics involved in atomic bonding, specifically in the formation of hydrogen atoms. Energy is required to break atomic bonds, while energy is released when bonds are formed, as described by the Gibbs' Free Energy equation ΔG=ΔH-TΔS. The conversation highlights the roles of entropy and enthalpy in determining the spontaneity of bonding processes. It also emphasizes the concept of Activation Energy, which is necessary to initiate reactions despite an overall negative ΔG.
  • Understanding of Gibbs' Free Energy equation (ΔG=ΔH-TΔS)
  • Basic knowledge of entropy and enthalpy in thermodynamics
  • Familiarity with atomic structure and electron configurations
  • Concept of Activation Energy in chemical reactions
  • Research the implications of Gibbs' Free Energy in chemical thermodynamics
  • Explore the concept of Activation Energy and its role in reaction kinetics
  • Study the principles of covalent bonding and electron sharing in atoms
  • Investigate the relationship between potential energy and chemical reactions
Chemistry students, educators, and professionals interested in understanding the thermodynamic principles governing atomic bonding and energy changes in chemical reactions.
bunyan
In chemistry its often said that energy must be added to system to break atomic bonds and conversely when atoms bond energy is released. I can picture why it takes energy to break a bond, for instance to ionize a hydrogen atom you have to exert a force on the electron to overcome the electrostatic attraction of the electron for the proton. I don't however see how that electron bonding to the proton to form a netral hydrogen atom would release energy.
Chemistry news on Phys.org
Classical mechanics doesn't really work to describe how/why two species bond. For instance the positive charges of 2 Hydrogen nuclei should be repelled from each other and therefore you would think that Hydrogen gas should exist as Hydrogen atoms. However, Hydrogen gas exists as 2 Hydrogen atoms sharing a pair of electrons because the configuration of the electrons around the two protons is such that it is of lower energy when the electrons are "shared" then when they are not.
In Chemistry we do not talk about electrons bonding with protons. In Chemistry, a bond is when an ion/atom/molecule "decides" to share electrons with another ion/atom/molecule. The two species will "decide" to bond if the energy of the overall system will decrease by them forming bonds.
There are two main factors involved, entropy and enthalpy, commonly thought of as disorder and heat, respectively. The relation of these factors to energy is known as the Gibbs' Free Energy equation ΔG=ΔH-TΔS (H is enthalpy and S is entropy). In order for a process to proceed spontaneously, you need the ΔG to be negative (all systems tend to the lowest energy state possible).
When two species become one, the entropy of the system (typically) is decreasing making the [-TΔS] term positive. In order to have that process be spontaneous, the ΔH term must be negative enough to overcome the positive TΔS term. Physically this is observed as heat or spark or an explosion or what have you. Now you have a system where covalent bonds were formed and the system is at its lowest energy state. In order to go the other way, you need to put energy back into the system to break those bonds.
The funny thing is, that blanket statements like that tend to be a little misleading. Even if a process is spontaneous (overall negative ΔG), there is a certain amount of energy that you need to put into the system to "get things started." This is called the Activation Energy and is the reason why the wood that is around you right now is not bursting into flames as you read this message.
Its pretty simple, you have explained it yourself already, Where does the energy used to knock off an electron from a Hydrogen atom go? into the electron, right? when another electron of similarly high energy is attracted by the proton, it must lose energy (in the form of heat, a photon etc) before it can be accepted by the 1s orbital. If you had an electron that was low in energy... You must ask... where exactly did this electron come from? because to have left an atom it must have had some energy supplied to it... right?
Another way to think of it with classical mechanics is as a body being gravitationally attracted to the earth... Up high, it has a large amount of gravitational potential energy, but when it falls it loses this energy to air resistance etc.
