Why Graphing Tools doesn't represent hole in a graph
22990atinesh
Why Graphing Tools doesn't represent hole in a graph of a function. A Hole at a point in a graph is point where function is not defined.Suppose there is a function
##\frac{x}{\root{x-1}-1}##
Its should be like this
Graph of a curve rising from near the origin in the first quadrant, with x-axis ticks at -5 and 10 and y-axis ticks at 1, 3, 5 and 9, with a small magenta dot marked on the y-axis near 2.
But online tools and even my android graphing tool app shows graph like this
Graph of a smooth curve rising from the lower left to the upper right on x and y axes, with axis tick labels at -5, 5 and 10 on the x-axis and 2, 4, 6, 8 on the y-axis; no open circle or hole marked on the curve.
What I'm saying is that, apart from circle there must be some sort of marks representing that the function is not defined here.
What's your function? Plotting ## \frac{x}{\sqrt{x-1}-1} ## gives me a different graph.
Anyhow, point discontinuities aren't always shown on generated graphics, but you can force the tool to do it.
For example, take the function ## \frac{x^2-5x+6}{x-2} ## which has a point discontinuity at ##x=2##.
Using WolframAlpha:
>> plot (x^2-5x+6)/(x-2)gives this:
Plot of a straight line with positive slope on axes labelled x (from -1.8 to 6.5) and y, crossing the x-axis near x = 3 and the y-axis below zero.
>>plot discontinuities of (x^2-5x+6)/(x-2) gives this:
Graph of a straight line with positive slope crossing the x-axis near x = 3, with a small open circle marking a hole at x = 2, y = -1; axes labelled with ticks at 2, 4, 6 and -2, -4.
Now, as for why these graphic tools don't show where point-discontinuities are? I don't know, I guess you have to ask for it, because we usually don't need to see it shown that big. Theoretically, the exact point ##x=2## in our example is so small if it were to be shown it would be unnoticeable. Note that the function behaves at ##x=1.9999999...## exactly how it does right after ##x=2##. The circle of point-discontinuity is just a symbol showing that something is going on here; it's not a real hole because point-discontinuties are actually impossible to show.
About online graphing websites [for example Desmos]:
I think that because the program is trying to show that the function is continuous on a very close interval beside the point where the function has a discontinuity, but if you click on that point it will give you its coordinate and whether it is defined or not.
Desmos graphing screenshot of y = x/x showing a horizontal red line at y = 1 across a zoomed-in view, with a tooltip reading 0, undefined at the origin where the line has an open circle.
Graph of a curve rising from near the origin across positive x, with axes labelled at x = -5, 5 and 10 and y = 5 and 9, and a small open circle marking a point at about x = 0, y = 2.
Graph of a curve rising from the origin region toward the upper right on axes marked from -5 to 10 (x) and 0 to 9 (y), with the curve starting near y = 2 at x = 0.
Sorry mistyped the function ##\frac{x}{\root{x+1}-1}##
\root{} doesn't mean anything in LaTeX. Use \sqrt{} for a square root and \sqrt[3]{} for a cube root and similar for higher-degree roots.
Your expression should be written as # #\frac{x}{\sqrt{x+1}-1}# # (without the spaces between the # characters). This renders as ##\frac{x}{\sqrt{x+1}-1}##
Hmm Sorry little mistake
