B Why higher speeds need more power if backward force is the same?
  • Thread starter Thread starter gen x
  • #31
Dale said:
Yes, but sometimes there are shortcuts.
What are shortcuts in case of engine?
So engine that have more area under power curve in operating rpm interval where you shift gears will have higher acceleration even if both have same peak power, because it produce more average power in that rpm interval?
  • #32
gen x said:
...why then horse need to be more powerfull to pull at higher speed even if backward force at him(rope tension) stay the same?
Do you understand why a static force doesn't require any energy? Lean a stick against a wall, and it can stay there exerting a force forever, without consuming any energy.
So the energy / time (= power) required for exerting a force must depend on the velocity the force is applied at, not just on the force.
  • #33
But is this 100% correct? If you hold 20kg weight in one position, you consume more energy than if you dont lift anything?
  • #34
Just because you can have an inefficient system, that wastes energy on something, doesn't mean that energy is required to achieve that something.
Put the weight on the ground, and it will be supported by a force, without consuming any energy.
Likes gmax137, Motore and Dale
  • #35
This is also why talking about biomechanics in energy discussions is usually not helpful. Life is messy.
  • #36
correct
  • · Replies 95 ·
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 24 ·
