- 29,902
- 21,785
How is it helpful to a struggling student to bring up integral domains?
Isn’t that what I said. Since ##\frac {(x-1)}{(x-1)} \neq 1## but is undefined we are stuck. We can’t write the final equation ##x=0##.fresh_42 said:Sure. You set x=1. Then you wrote x(x−1)x−1 which equals x(x−1)0 which you are not allowed to do. Even if you say x(x−1)x−1=1⋅00 you will be stuck here because you cannot cancel 0 in a quotient. The zero in the denominator makes it automatically forbidden.
Yeah! Because ##0/0 \neq 1##. That’s what I think.PeroK said:This is as simple as I can make it:
$$1 \times 0 = 2 \times 0$$But, we cannot cancel the zero to give ##1 = 2##.
You can explain that to yourself however you like, but zero cannot be cancelled from both sides of an equation.
Yes, sorry.mark2142 said:Isn’t that what I said. Since ##\frac {(x-1)}{(x-1)} \neq 1## but is undefined we are stuck. We can’t write the final equation ##x=0##.
Yeah! I feel that but sometimes even a person of low experience can be right. I said this before ##0/0 =## undefined. So we cannot replace it with 1.mathwonk said:thanks for the reminder that the goal is to be helpful, not smart alecky. here is a try:
to the OP: this question is a trick, using disguised symbols to hide from you what is being said.
when x= 1, then x-1 = 0, so writing x(x-1)/(x-1) is a disguised way to write (1.0)/0. what do you think that means? if 1.0 = 0, then (1.0)/0 = 0/0, and what does that mean?
here one needs to know that a/b = a.(1/b), so 0/0 = 0.(1/0), but what does 1/0 mean? In fact, as several people have tried to say, it does not mean anything in the real number system.
I.e. although I myself did not learn this until college!, in fact 1/b means: "the number which multiplies b into 1".
Now that means that 1/0 must equal the (real) number that multiplies 0 into 1, but sadly, or actually happily, there is no such real number.
this is a little technical, but i claim 0 multiplies every real number into 0. Again I did not learn this either until college, but there is a rule for all real numbers, called associativity, that says (a+b)c = ac + bc, for all real numbers a,b,c.
Applying this to a=b = 0, using 0 = 0+0, we get 0.c = (0+0)c = 0.c + 0.c. Then subtracting 0.c from both sides, gives us 0 = 0.c, for all c.
now, since 0 multiplies every number into 0, it cannot multiply any number into 1.
Wait! For this proof I need to know that 1≠0!
So you cannot prove there is anything wrong with this proof unless you already know that 1 ≠ 0!
I.e. close analysis of this proof shows that in fact 1 = 0 if and only if 1/0 makes sense, i.e if and only if there is a multiplicative inverse of 0.
So this takes me back to my point, namely one cannot prove anything unless one says what one is assuming. Here we are apparently assuming that we are working with real numbers. But that takes for granted that we know some facts about real numbers. usually people just take for granted that real numbers are (infinite) decimals, and that two such decimals are different except basically that 1.0000... = .99999.....
hence also 3.141599999999.... = 3.141600000...., etc...
in which case we do NOT have 1.0000.... = 0.000000....
So since 1 ≠0 is an assumption about real numbers, it follows that 1/0 makes no sense within the realm of real numbers. So the original question involves trickery, by writing x(x-1)/(x-1), where x=1, and where thus the factor 1/(x-1) = 1/0, which makes no sense.
sorry to be so lengthy, but the point is, you cannot prove anything, ever, unless you agree on what you are assuming. and here we are basically assuming that 1≠0 in the real numbers. hence 1/0 makes no sense, hence the argument originally given involves some symbols that do not represent actual numbers. hence the argument is gobbledy gook.
another point of view is that the argument correctly shows that if 1/0 makes sense, then 1=0. but equivalently, this shows that if 1≠0, then 1/0 does not make sense. so the point is, to understand whether 1=0, try to understand whether 1/0 makes sense.
so apparently this problem is taking advantage of the fact that many of us know that 1≠0, but do not realize that this implies that 1/0 does not make sense. or more likely, they count on us forgetting that if x=1 then 1/(x-1) = 1/0, hence does not make sense, as pointed out several times here above.
and don't feel too naive, i am an old hand, and I just learned something by going through this in detail.
peace.
Can you again explain the less simple part but in detail in post #26?fresh_42 said:Yes, sorry.
Multiplication is defined for 0. You mean to say multiplication is not defined for ##1/0## ?fresh_42 said:The long version would mean to explain what "division" actually is. For mathematicians, division by x−1 is simply multiplying by ⋅1x−1. However, multiplication is only defined for numbers unequal zero. Therefore, the construction ⋅1x−1 is not available for multiplication.
mark2142 said:Multiplication is defined for 0.
Yes. I meant that any division is actually a multiplication. E.g., what does ##\dfrac{4}{2}## mean? I mean, how is it defined? Truth is, it is an abbreviation: ##\dfrac{4}{2}=4\cdot \dfrac{1}{2}.## That's its definition. But what is ##\dfrac{1}{2}## then? This is again an abbreviation defined as the solution to the equation ##x\cdot 2 =1.## See? Everything is in the end reduced to multiplication.mark2142 said:You mean to say multiplication is not defined for ##1/0## ?
Yeah! And I don’t understand very much. I am trying to learn precalulus right now. But I think it’s clear to me division by 0 is not allowed. It’s undefined.fresh_42 said:The problem with this question is how deep you want to climb into the rabbit hole of mathematics. Possible answers reach from "You cannot divide by 0" to what was called integral domain above. I tried to answer your question on the basic level and simultaneously provide a glimpse into the theory behind this prohibition.
I think I am getting what you mean. It’s called the language of maths. We have to be careful in what we say and understand.jack action said:The following is a quadratic equation: ##x^2-x=0##
It has 2 solutions: ##x= 1## and ##x= 0##. It doesn't mean ##1=0##, it just means those two values give the same result in the [arbitrary] equation you stated. Graphic solution:
Yes. Understanding that, reread the posts from @PeroK to understand what you did wrong:mark2142 said:I think I am getting what you mean. It’s called the language of maths. We have to be careful in what we say and understand.
$$x=1$$
Then after some manipulation we write
$$x=0$$
And I think it’s clear ##x=0## is not the solution of ##x=1## because ##0 \neq 1##. So ##x## does not have a value ##0## and so ##1 \neq 0##. But this last line is absurd. Even if ##x=1## and ##x=0## are solutions ,doesn’t mean ##1=0##. Yes?
We cannot multiply by or divide by ##(x-1)=0##.jack action said:
Apart from the "backwards" problem, @PeroK delivered an apt summary in #20. Let me repair that problem...mark2142 said:We cannot multiply by or divide by ##(x-1)=0##.
Well I think the way they are treating x is wrong. It’s not like there are two quantities equal to x and so both will also be equal namely 1=0. Instead if we assume it’s not a trick, x=1 is our original equation. x=1 and x=0 are solutions to the original equation. But we cannot say two numbers are equal to each other.
Let us take the original sequence of statements one at a time and explore them in [painful] detail.PeroK said:In fact, you can characterise what's happening as:
Start with x=1. It follows that x=0 or x=1. Sneakily get rid of the case x=1. You are left with x=0.
You can multiply by ##0## but that will result in ##0=0## and every bit of information is lost because we cannot retrieve anything from ##0=0.##mark2142 said:We cannot multiply by or divide by ##(x-1)=0##.
Yes and no. The step ##x=1## to ##x^2=x## adds another solution to the equation since there are two numbers that obey that equation: ##0^2=0## and ##1^2=1.## Hence, ##x=1## has a unique solution, namely ##x=1,## and ##x^2=x## has two different possible solutions. We added one.mark2142 said:Well upon close inspection I think the way they are treating x is wrong. It’s not like there are two quantities equal to x and so both will also be equal namely 1=0.
Yes. More or less.mark2142 said:Instead if we assume it’s not a trick, x=1 is our original equation not that value of x is 1 ,x=1 and x=0 are solutions to the original equation. But we cannot say two numbers are equal to each other (1=x=0).
(My last post is not so clear)
I am not saying x=1 is wrong. It’s our assumption. It’s the equation that we have taken to do the math.fresh_42 said:Yes and no. The step x=1 to x2=x adds another solution to the equation since there are two numbers that obey that equation: 02=0 and 12=1. Hence, x=1 has a unique solution, namely x=1, and x2=x has two different possible solutions. We added one.
However, our original statement was x=1. This keeps true. So whatever we derive from there, x=1 doesn't get false out of thin air. Therefore we always have x=1, then x2=x AND x=1, then x2−x=0 AND x=1, then x(x−1)=0 AND x=1, then (x=0 or x=1) AND x=1.
x=1 doesn't get lost. We started with it and there is no reason that it gets lost. And the logical formula {[x=0 OR x=1] AND x=1} has only the solution
Oh! Zero is a very dangerous quantity then. We should be afraid of 0.fresh_42 said:You can multiply by 0 but that will result in 0=0 and every bit of information is lost because we cannot retrieve anything from 0=0.
That is not the lesson to take away from this.mark2142 said:Oh! Zero is a very dangerous quantity then. We should be afraid of 0.
Joking…Let’s focus on my other post.jbriggs444 said:That is not the lesson to take away from this.
@fresh_42 already responded to this, but it's worth repeating. You can always multiply both sides of an equation by zero, but this is not a useful step, as you end up with 0 = 0, which is vacuously true.mark2142 said:We cannot multiply by or divide by (x−1)=0.
mark2142 said:Can you add something to what I said instead of pouring extra knowledge? I am a beginner.
Given the comment above by the OP, talk about quotient fields is not helpful, IMO. The expression "drinking from a firehose" comes to mind.mathwonk said:I.e. if we are working, as it appears from the notation, in the quotient field of the ring of polynomials, then in fact 1/(x-1) is the inverse of x-1, so as a "rational function",
