Why is B equal to RsinΦ in spring vibration equations?
3 replies · 1K views · last reply
Amadeo
TL;DR
Derivation of Equation of Vibration
For undamped free vibrations, we have the following differential equation.
mu'' + ku = 0
where m is the mass of the object hanging on the end of a spring, and u is the distance from the equilibrium position as a function of time.
This yields u = Acosωt + Bsinωt
where ω is √(k/m) (k=spring constant).
I am having trouble understanding why this can be rewritten as
u = RcosΦcosωt + RsinΦsinωt (which, in turn, = Rcos(ωt -Φ) )
If A represents the initial displacement from equilibrium (ui), I can see how we could set this equal to RcosΦ, (R being the maximum displacement) thereby defining Φ to be that value which makes ui=RcosΦ true. But, I don't see why B must, in that case, necessarily be RsinΦ.
It looks like B must be the initial velocity (vi) multiplied by m/k.
This just occurred to me:
Since the solution u = Acosωt + Bsinωt is general, A and B can be any two constants. If we choose two arbitrary constants for A and B, this will determine the initial displacement and the initial velocity.
Alternatively, if we choose two arbitrary values for the initial displacement and velocity, these will determine A and B.
In this case, we are choosing values for A and B. These values then determine the initial velocity and displacement. We could choose any values we wish, but we chose these values (A= RcosΦ and B=RsinΦ) because they enable the convenient reformulation Rcos(ωt -Φ).
Any more insights would be appreciated.
You mentioned a mass hanging from a spring and its displacement (m,k,u). The solution is Acosωt + Bsinωt where both A and B have displacement units. I understand those. The R and Φ look like polar coordinates, range and angle. Does your spring hang from a pivot? Describe exactly what is vibrating.
Another way to look at it: the set ##(A, B)## is just the set of any two numbers. You could think of this as points in a plane expressed in Cartesian coordinates. Equally, you could express this in polar coordinates ##(R\cos \phi, R \sin \phi)##, where ##R^2 = A^2 + B^2## etc.
