B Why is displacement the integral of acceleration with respect to time? [corrected in thread]
  • B
  • Thread starter Thread starter spaceman0x2a
The equation s = ut + 1/2(at^2) describes displacement under constant acceleration, where the first term represents the area of a rectangle (constant velocity) and the second term represents the area of a triangle (additional displacement due to acceleration). The confusion arose from mistaking the integral of acceleration for that of velocity. Understanding that the displacement is the area under the velocity-time graph clarifies the relationship. Ultimately, the equation combines the effects of constant velocity and additional displacement from acceleration. This illustrates the concept of motion under constant acceleration effectively.
spaceman0x2a
TL;DR Summary
Question about s = ut + 1/2(at^2)
Looking at s = ut + 1/2(at^2), the first part makes sense to me, but I am confused about the 1/2(at^2). I can see that this is the integral of acceleration with respect to time, but I don't understand why. Is this simply a coincidence? I know that this is considering a linearly rising acceleration, but it feels like it means something.
And yes, I know this is similar to my previous post here.
spaceman0x2a said:
TL;DR Summary: Question about s = ut + 1/2(at^2)
This is only for constant acceleration. The displacement is the (signed) area under a velocity-time graph. For constant acceleration, the graph has two geometric components:
1) The ##ut## represents the area of a rectangle, of height ##u## and length ##t##.
2) The ##\frac 1 2 at^2## represents the area of a triangle of length ##t## and height ##at##. The area of a triangle being ##\frac 1 2## times base time height.
Thanks.
I just went and looked at this further and realized the mistake I was making - I thought it was the integral of acceleration with respect to time, when it was actually velocity (##at##) with respect to time. I feel really stupid now, but I guess this is how you learn.
A simple way to look at this is to consider the displacement as the "area under the velocity vs. time curve" which is really the integral. The velocity under constant acceleration is a straight line ##v=u+at##. The plot on the right shows this and the colored area under the curve.
You can see that the total area under the curve is the area of the blue rectangle plus the area of the red triangle. Then in words, the equation $$s=ut+\frac{1}{2}at^2$$ says that the displacement under constant acceleration in time ##t## is the sum of two displacements: (a) the displacement as if the object moved at constant velocity and (b) the additional displacement due to the constant acceleration.
Likes bob012345 and TSny
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
