zarbanx
- 23
- 0
i wanted to ask why the electric field inside a hollow conductor zero throughout and not just at the centre.
zarbanx said:okk as u say well i have done a lot of work and research i know tht there is no electric field inside a conductor bt i am not able to prove it mathematically and moreover electrical charges in conductors move to the surface becoz no electric field is there in a conductor becoz if there is a field then charges will move to neutralizze it.when an external electrical field is present then charges rearrange tso that no electric field is there in the conductor bt still mathematically i am not able to prove it
berkeman said:(which text are you using?)
Isaac Newton used what is called "Shell Theorem" to rigorously prove some important things about spherical shells, one of which is what I mention above, and another of which is that any spherical object can be modeled as a point mass when you are located outside the object.
zarbanx said:that means in an external field there can be a net field inside the hollow conducting shell
merryjman said:I'm not sure that's true. What happens in an external field is that the conductor will become polarized, and it polarizes in such a way that the field inside is still zero.
Ulysees said:Merryjman, are you familiar with the math involved in here? I have got stuck in another similar problem:
https://www.physicsforums.com/showthread.php?t=212711
merryjman said:If the electric field inside a conductor was NOT zero, then there would be a force acting on the mobile charges, and so they would rearrange until the force WAS zero.
merryjman said:But if the force was non-zero inside, charges would still be moving
Inside a conductor, charges are free to move. If there were a non-zero field there, they'd move. (They move until the field is canceled.)Ulysees said:Why? The field inside need not be identical to the field on the surface. Might be zero inside and non-zero on the surface or vice versa when equilibrium is reached.
Doc Al said:Inside a conductor, charges are free to move. If there were a non-zero field there, they'd move. (They move until the field is canceled.)
Why do you say that there are no charges inside a conductor? There is no field inside a conductor.Ulysees said:In equilibrium there are no charges inside. So electric field inside can be non-zero in equilibrium (under the influence of an external field always).
Wrong again. On what basis do you say this? The field inside a conductor does not depend on the shape of the conductor.Even without an external field, if the object is not spherical the electric field inside will be non-zero, in equilibrium. That's for a charged object of course.
Ulysees said:In fact an electron on the surface might experience no net force (in equilibrium) but still produce a field of its own in its vicinity. So equilbrium of electrons does NOT imply zero electric field around them.
merryjman said:True, but it does imply zero NET field, in terms of vectors.
I admit (and apologize) for being a bit patronizing. But it's you who are saying incorrect things. OK, you mean no NET charge within the conductor. I'll give you that one.Ulysees said:Doc Al I am sorry, but you are saying incorrect things and in a patronizing way. It is well known that charges accumulate on the surface of a conductor when equilibrium is reached. Shall I dig up the relation between curvature and charge density, or you agree now?
In electrostatic equilibrium, the field within a conductor is zero. Regardless of shape. Don't think so? Tell us why.So in equilibrium there is no charge inside. And electric field can be non-zero, which it will be if the object is a cube say.
I'm not understanding the relevance of this to the fact that the field within a conductor is zero. (Of course if you start sticking charges inside it you've destroyed equilibrium.)If you put a charge inside any object, you'll have to hold it there, otherwise the charge will go to the surface. It will move under the influence of the non-zero field caused by the other charges redistributing on the surface.
Except if the object is a sphere and you hold it at the centre, no re-distribution of surface occurs then and the charge you put stays at the centre of the sphere itself.
