Mentor
- 45,589
- 2,482
What does this have to do with the field inside a conductor? In a conductor, you can redistribute as many electrons as needed to cancel any external field. (Of course, if the external field is so incredibly humongous that all available electrons within the conductor are still not enough to cancel the field--then all bets are off.Ulysees said:Imagine just 4 electrons in a circular disk. They'll form a square. Each will be in equilibrium. But in the vicinity of each electron the e-field will be non-zero. Shall I draw a diagram and calculate the e-field somewhere in the middle between electrons, on the surface?
I don't seen any point of diagramming the field of 4 electrons. I don't imagine anyone here is saying the the field from those electrons is zero everywhere.
Also: The only reason those electrons might be in equilibrium is if something is holding them in place (and thus exerting a force on them). Are they attached to the disk? Or are you picking 4 electrons on the edge of the disk? Why?
