Why is entanglement necessary for understanding quantum mechanics?
  • Context: Graduate
  • Thread starter Thread starter Johan0001
    Entanglement
The discussion centers around the necessity of entanglement in understanding quantum mechanics, particularly in relation to the phenomenon of non-locality and correlations observed in entangled particles. Participants explore analogies, experimental implications, and the conceptual challenges posed by quantum entanglement.
  • One participant uses an analogy of gloves to illustrate the concept of entanglement and questions the need for faster-than-light communication to explain observed correlations.
  • Another participant emphasizes that different measurement bases in quantum mechanics can lead to varying correlations, which cannot be interpreted classically.
  • A later reply references Bell's Theorem and its implications for non-separability, suggesting that while entanglement does not allow for faster-than-light communication, it reflects a deeper quantum reality.
  • Some participants express skepticism about whether entanglement is necessary for experimental measurements, proposing alternative interpretations of the data that do not rely on instantaneous communication.
  • One participant introduces a more complex analogy involving multiple boxes and choices, arguing that the rules governing the outcomes resemble quantum correlations but do not fully capture the nuances of entanglement.
  • Another participant points out that the gloves in the analogy must be in a superposition state, which is a critical aspect of quantum mechanics that is not addressed in the original analogy.
  • Disagreement arises regarding the implications of the proposed rules in the analogies, with some participants agreeing on certain aspects while contesting others.
Participants express a range of views on the necessity and interpretation of entanglement, with no consensus reached. Some agree on specific aspects of the analogies while disagreeing on others, indicating a contested understanding of the implications of entanglement in quantum mechanics.
Participants highlight limitations in the analogies used, particularly regarding the assumptions about measurement choices and the nature of quantum states. The discussion reflects ongoing uncertainties and varying interpretations of entanglement and its implications.
  • #151
Nugatory said:
It might be worth going back to the beginning of this thread, reading through it again... It started with johan0001 asking why there was anything strange going on at all, how measuring the polarization of two entangled photons and finding a correlation is any different than putting two gloves in two boxes then finding that the presence of a left-handed glove in one box is correlated with finding a right-handed glove in the other.
I've actually read quite a bit about this stuff, but the crucial thing which eluded me is that photon polarization is supposed to be random, I thought it's constant. This is very subtle difference if you don't know it's implied. But what is fascinating I was reading through those experiments and it all actually made sense, it gives the same result, only there is no any mystery. Allegedly random photon polarization is a big news to me, it changes everything, and nothing makes sense anymore.
  • #152
If you think about what "random" means you'll see there is some confusion in the way it is being used here. The only time it makes sense to talk of randomness with respect to the polarization of a single photon, has to do with inability to predict what it will be, but in that case it doesn't mean it won't be constant. For many different photons, you can say that their polarization directions are random, which simply means there is no discernible pattern from one photon to the other in the set. It does not mean each individual photon does not have a fixed constant polarization direction (although some people believe that). It is important to distinguish claims about individual photons, and claims about ensembles of photons.
  • #153
Indeed there is.
But please bear in mind the polarisation is not random - its nothing at all - ie it doesn't even have the property of polarisation until observed. Its the act of observation that gives a random outcome. The weirdness is that it's always correlated with the other photon. But the other photon doesn't have the property of polarisation until observed either.
One may think some instantaneous communication went between the two photons, but what Bell's theorem shows is you don't have to view it that way. You can keep locality if you assume it doesn't have the property until observed - which is actually what the formalism says so really there is no issue. I personally go further and think there is some kind of communication, and the polarization don't exist until observed - which the theorem also allows. But that's just me - you don't have to do it.
Thanks
Bill
  • #154
Nugatory said:
We have two photons, entangled so that if one of them passes a filter at a given angle, the other one definitely will not pass a filter at that angle.
You mean if they are orthogonally entangled? But if they are entangled with parallel polarization then whenever one goes through so must the other, like this:
theta_A = 0, theta_B = 0
A: 1 0 0 1 0 0 1 0 0 1 1 0 1 0 0 1 1 1 1 0
B: 1 0 0 1 0 0 1 0 0 1 1 0 1 0 0 1 1 1 1 0
Consider the first pair of photons from that sequence. Let's say they have 45 degrees polarization so they both have 50% chance to pass through their 0 degrees aligned polarizers. Photon A happens to go through, first, and informs his twin brother he must go through as well, or else! So then photon B finally meets with polarizer B, bribes it, and continues as planned. Even if the explanation is some instantaneous connection between the photons, it still doesn't explain why would second polarizer just go along with that deal.
  • #155
Jabbu said:
Ok, all together it should now look like this:
sequence length = 20
matching pairs (00 or 11) = 20
mismatching pairs (01 or 10) = 0
Correlation = (match - mismatch) / sequence length = 20/20 = 100%
theta_A = 0, theta_B = 45
B: 1 0 0 0 0 0 1 0 0 1 0 1 1 0 0 1 1 0 1 1
matching pairs (00 or 11) = 15
mismatching pairs (01 or 10) = 5
Correlation = (match - mismatch) / sequence length = 10/20 = 50%
theta_A = 0, theta_B = 90
A: 1 0 1 0 1 0 1 0 1 0 1 1 0 0 0 0 1 1 0 1
matching pairs (00 or 11) = 10
mismatching pairs (01 or 10) = 10
Correlation = (match - mismatch) / sequence length = 0/20 = 0%
I just saw this post. Unfortunately, you have mixed up the entangled match percentages and correlation somewhat such that the above is not correct.
Correct is:
Theta=0 degrees, match=100%, correlation=1
Theta=0 degrees, match=50%, correlation=0
Theta=90 degrees, match=0%, correlation=-1
So the 2nd and 3rd patterns are inaccurate.
  • #156
Here is where you are going wrong: you are assuming that the photons have some definite polarization (45 degrees or anything else) before their polarization is measured. But that would mean that both photons started out in a polarization eigenstate; and that is a very restrictive assumption. There are *lots* of states of the photons which are *not* polarization eigenstates (and in the actual experiments that are done to test this, the photons are not in polarization eigenstates). When people say the polarization is "random", or that the photon does not have a definite polarization until it's observed, what they mean is that the photon's state at the start is not a polarization eigenstate.
  • #157
There are 2 types of PDC producing entangled photon pairs: Type I and Type II. Type I produces pairs that are parallel, Type II produces pairs that are orthogonal. I prefer to discuss Type I because the examples are much easier to describe in posts. The fundamental principle is the same either way. In fact you can rotate either Type to act like the other Type.
So sometimes one poster is referring to one type when another poster is referring to the other. I do my best to label as Type I PDC and entangled so as to be clear.
  • #158
As PeterDonis indicates, you must be careful when you assume that there is a pre-existing polarization as Bell's Theorem places restrictions on such.
However, your model WILL more or less work as described above. It is called a non-local model. Under such model, there is instantaneous communication from A to B (assuming A is measured first). In this hypothetical case, B conforms to A. The statistics work out fine and Bell's Theorem is not a problem. Further, you don't need to answer "WHY" it happens that way any more than you ask "why" the speed of light is c. It just is.
The problem with this interpretation (model) is that there is no other evidence of the signalling mechanism other than in entanglement, and it is not supported by the so-called "standard model". Accordingly, it requires a new force currently undiscovered - or other significant changes to our understanding of physics. There are several non-local interpretations that explicitly solve these issues. Bohmian Mechanics is one such, you can google that.
  • #159
Jabbu said:
The premise must be wrong, surely?
Yes, but which premise? :smile:
That is what Bell helps us to understand. Usually the premises are:
1. QM is correct (this is strongly confirmed by experiment).
2. There is no action at a distance.
3. Quantum particles such as photons have well-defined properties independent of the act of observation.
4. There is causality (the future does not affect the past).
At least one of the above is incorrect, according to Bell's Theorem.
  • #160
That's why I'm asking about how actual data streams look like.
When there is always 50% ones and 50% zeroes in each individual sequence then according to Malus's law photon polarization is either random or constant at 45 degrees relative to polarizers. I thought photon polarization was constant and centered relative to polarizers, so that data stream for theta_A = 0, theta_B = 0 looks like this:
A: 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
B: 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
It turns out 100% correlation as well. Only this time it's not weird why sequence A coincides with sequence B, they simply both have 100% chance to go through. It's very subtle difference to distinguish if you don't look at some actual experimental data, which I can't find anywhere on the internet.
  • #161
Is there mathematically even any difference between "random" and "not existing - then existing"? I can conceive instantaneous interaction and stuff disappearing and reappearing in different locations, if I must. But that there is no Moon when I don't look at it, that's too much.
  • #162
I don't think that changes the conclusion. Photon A interacts with polarizer A first, and the decision whether photon B will go through polarizer B is made right there and then. Ok? But even if the explanation is some instantaneous connection between the photons, it still doesn't explain why would second polarizer just go along with that deal.
  • #163
I thought instantaneous signaling is "standard model". If not that, what's the explanation then?
  • #164
Type I entangled photons
A=0 degrees:
A: 1 0 1 0 1 0 0 0 1 0 1 1 0 1 0 0 1 1 0 1
B=120 degrees:
B: 0 1 0 1 0 0 1 1 0 1 1 0 1 0 0 1 1 1 1 0
Match rate above is 25%. If the moon is there when not observed, what is C below (had it been measured)?
C=240 degrees:
C: ? ? ? ...
  • #165
Not really. The "standard model" is actually silent on the mechanism. There are also models where there is no instantaneous signalling.
The term you will sometimes hear is: "quantum non-locality". That means it sort of appears non-local, but strictly in a "quantum" manner - such that it does not conflict with relativity. Fully non-local models violate relativity.
  • #166
PS regarding my post #164:
A-B match rate is 25%
A-C match rate should be 25%
B-C match rate should also be 25%
After all, theta is the same for all 3.
Good luck! :smile:
  • #167
But this way of looking at it is frame-dependent; there will be another frame in which photon B interacts first, and the decision whether photon A will go through is made right there and then. There is no invariant fact of the matter about which photon interacts first. That's why DrChinese said that fully non-local models violate relativity.
For what it's worth, quantum field theory has a somewhat different take on this, at least as I understand it. In QFT, "causality" does not mean that spacelike separated measurements can't be correlated, even to a degree that violates the Bell inequalities; it only means that spacelike separated measurements must commute, i.e., the results must not depend on which measurement happens first. The photon measurements satisfy this criterion, so QFT simply says "no problem".
  • #168
Correct is:
After PeterDonis' post #132 I adjusted it to match the new formula:
correlation = (match - mismatch) / sequence length
...where "match" is number of 00 + 11 pairs, and "mismatch" is number of 01 + 10 pairs.
Originally this seemed to be the formula:
correlation = (match_0 + match_1) / sequence length
...where "match_0" is number 00 pairs, and "match_1" is number of 11 pairs.
What is your "match" formula?
  • #169
...where "match" is number of 00 + 11 pairs, and "mismatch" is number of 01 + 10 pairs.Originally this seemed to be the formula:
Type I Match: cos^2(theta)
Type I Correlation: cos^2(theta)-sin^(theta)
I did warn you in post #108, it is best to discuss matches and for Type I. :smile:
  • #170
A=0 degrees:
B=120 degrees:
C=240 degrees:
C: ? ? ? ...
True range is only from 0 to 90 degrees relative, from parallel to orthogonal. So both 120 and 240 are really just the same 60 degrees relative angle. Anyway, what I thought is that photon polarization is actually constant and deliberately centred between the two polarizers, so in the case of master_theta = 60 or 120 or 240:
theta_A = -30, theta_B = +30
A: 1 1 0 1 1 0 0 1 1 0 1 0 1 1 1 1 1 1 1 1
B: 1 1 1 1 0 1 0 1 1 1 1 1 0 1 1 0 0 1 1 1
Both photons now according to Malus have cos^2(30) = 75% chance to pass through, and therefore there is 75% ones and 25% zeros in each stream. So what is the chance of getting 11 or 00 matching pairs vs chance of getting 10 or 01 mismatching pairs?
chance of match: (0.75 * 0.75) + (0.25 * 0.25) = 0.625
chance of mismatch: (0.25 * 0.75) + (0.75 * 0.25) = 0.375
correlation: 0.625 - 0.375 = 25%
  • #171
I'm not talking about any other experiment but what you call "Type I". cos^2(theta) is theoretical prediction equation. Correlation is calculated differently from experimental data, in terms of matching and mismatching pairs, along these lines:
The formula defines how actual data streams are supposed to look like, it makes all the difference, but the difference is very subtle, so it is important to get this formula straight.
  • #172
And I keep telling you that the formula for matches and the formula for correlation are completely different. Forget correlation, you will simply make things more complicated than needed.
Matches at 60 degrees = matches at 120 degrees = 25%.
Before you start modeling things, you would find it beneficial to understand fully what happens experimentally. And many of your ideas about that are incorrect, especially most everything in post 170. For example, 1's are not more likely than 0's for entangled streams. They are equally likely. The correlation for 60 degrees is not 25%, it is -.5.
  • #173
You are viewing it incorrectly.
When we say something exists we usually have the view of what's called naive reality - you can look up exactly what it is. I will not get into a philosophical discussion about what existing means except to say most assume some kind of naive reality.
Now QM is a theory about observations. It is silent on what's going on when not observed. Naive reality may apply - or it may not - the theory says nothing one way or the other - on the surface that is.
We can't say anything about the photons polarisation when it's not being observed. That is the key difference between your analogy, Bertlmanns socks vs QM. Both, being classical objects, obey naive reality.
What Bells theorem shows is QM is not only silent on the issue, but in fact rules out naive reality. That's the striking and interesting thing about it. The Bertlmann socks analogy is not correct.
Thanks
Bill
  • #174
That's the definition of correlated.
What Bell shows is classical correlations like Bertlmann's socks are different to quantum ones.
Why are they correlated?
Apply the Born Rule to 1/root 2 (|a>|b> + |b>|a>).
Its basic QM.
Thanks
Bill
  • #175
Can you point any document on the internet where we can see samples of actual experimental data?
  • #176
I'm talking about photons after they have been observed. If 50% photons pass through regardless of polarizer rotation, does that not mean those photons had random polarization?
  • #177
Hello
Perhaps look at Kochen–Specker theorem, which shows that the result of any individual measurement of spin was not fixed independently of the choice of measurements. An outcome is "not determined" by prior conditions.
Patrick
  • #178
microsansfil said:
Hello
Patrick
All the equation needs is two polarizer angles. I don't see how can that be anything but "prior condition".
  • #179
The result cannot be determined before make the measurements.
http://arxiv.org/abs/quant-ph/0604079
Conway and Kochen do not prove that free will does exist. The definition of "free will" used in the proof of this theorem is simply that an outcome is "not determined" by prior conditions.
Patrick
PS
http://www.researchgate.net/post/How_do_you_define_unpolarized_light_What_is_the_difference_between_polarized_light_and_unpolarized_light
  • #180
The error with your analogy is that, after they are entangled, if you replace one glove with its opposite without actually measuring it (for example, we have an automatic mold machine within each box that creates the opposite of the glove inside of one box and the original was destroyed), the other glove would have to change automatically. In this case, we can assume that the "entangled" gloves right and left can be considered the particles' spin. When we change one, the other MUST change as a result. There's just fundamental differences between classical and quantum mechanics.
  • · Replies 50 ·
  • · Replies 51 ·
9K
