Why is gravity, on earth, approximatley 9.81 m/s[SUP]2[/SUP].What
  • Context: High School
  • Thread starter Thread starter jsmith613
    Earth Gravity
The acceleration due to gravity on Earth is approximately 9.81 m/s², derived from Newton's law of universal gravitation, represented by the equation F_G = G(m_1 m_2)/r². This acceleration is independent of the mass of the falling object, as it cancels out in the equations, meaning all objects experience the same gravitational acceleration regardless of their mass. The Earth's mass and the distance from its center are the primary factors influencing this value, with variations being negligible at different altitudes.
  • Understanding of Newton's law of universal gravitation
  • Familiarity with Newton's second law of motion (F = ma)
  • Basic knowledge of gravitational constant (G)
  • Concept of gravitational mass versus inertial mass
  • Explore the implications of Einstein's equivalence principle in general relativity
  • Investigate how gravitational acceleration varies with altitude and location on Earth
  • Learn about the mathematical derivation of gravitational force and acceleration
  • Examine the effects of other forces acting on objects in a gravitational field
Students of physics, educators, and anyone interested in understanding gravitational forces and their implications in classical mechanics and general relativity.
jsmith613
why is gravity, on earth, approximatley 9.81 m/s2.
What causes it to be so?
thanks
Well, its an observational property of all matter in the universe that it attracts other matter by an equation which Newton found (http://en.wikipedia.org/wiki/Newton's_law_of_universal_gravitation)
<br /> F_G = G \frac{m_1 m_2}{r^2}<br />
For two masses (m1 and m2), separated by a distance (r); given 'Newton's gravitational constant' (G).
Now, according to one of Newton's other laws
<br /> F = ma<br />
If you combine these equations you find out that the acceleration due to gravity only depends on the mass of the Earth and your distance away from its center... if you plug in the values you get ~9.81 m/s^2
thanks
Mass of the Earth and the Newton law that F=m a=-G m M/R^2. In classical physics the acceleration does depend only on the distance to the center of the earth. (This means that the acceleration is on a mountain smaller.)
That m does cancel out in this equation is very important, it is unique in physics and let Einstein think about the General Theory of Relativity.
Jens
<br /> F = ma<br />
So essetisally, because the Earth's mass is so large, the mass of the other objects is next to insignificant. Because the value of r is also large, changing the value by an amount will make little differernce.
Therefore will the value of gravity be in the range 9 - 10
(M1 = earth, M2 = object)
correct?
Not quite; it doesn't matter how large one body's mass is---because it cancels out in the equations, it has no influence on the acceleration.
That's exactly right. The Earth's radius is something like 6000km, while the highest mountain is only about 10km... so the change in gravity will be about 0.3% (or something like that, so very small).
Yeah, if you plug in the usual values, that's what you get.
I don't quite understand what you mean. Please explain
Question 2: Using the equation G = M1 * M2 / r^2 does that mean I cause the Earth to accelerate upwards at a rate of 9.81 m/s^2. If this is the case, why does the Earth not move upwards dramatically due to the upward accealration of every landmass on earth.
Please explain. Thanks
No. That equation gives you the force. Acceleration is a=f/m so the larger the mass, the smaller the acceleration for the same force.
Does that not mean, therefore that Gravity should change based on force and mass for each object, if we assume a = f/m
Simply put, the only variables in the calculation are the masses of the 2 objects and the distance between them. (Of course, this assumes an isolated system or one in which other objects are too distant to influence it.)
Other forces may act to overcome some or all of the influence of gravity, say a velocity of one object greater than the escape velocity of the larger object, but otherwise, that's really and truly all there is to it.
Note that Russ said 'for the same force'. The force of gravity does change based on the mass. In fact the force is proportional to the mass, which makes the acceleration of a free falling object due to gravity the same for all masses, since the mass drops out of the equation.
The acceleration gravitational field depends only on the mass of the "source".
Given Earth with mass M and body on its surface with mass m, the force between them is:
F = G\frac{Mm}{r^2}
Now to calculate the acceleration of Earth you divide the force by Earth's mass
a = \frac{F}{M}
which is
a = G\frac{m}{r^2}
The body feels acceleration
a = \frac{F}{m}
a = G\frac{M}{r^2}
Now you see that acceleration of bodies on surface of Earth is in fact the same because it does not depends on body's mass.
Gravity is really nice force!
gravitational force, yes: that's what you measure with a bathroom scale.
a = \frac{F}{M}
which is
a = G\frac{m}{r^2}
Why is this so,
Does all this mean that no matter the mass of the smaller object, it will always have the same acceleration?
jsmith613 said:
Why is this so,
I understand it know
THanks everyone
Yes it does.
zhermes said:
Yes it does.
Is this because as the mass increases, the attraction due to gravity increases as well, but so does the amount of force required to move it? I think that's right, just wanting to make sure.
Yes! That's exactly it.
And as someone said above, this is a very interesting feature of the laws of physics, in Newton's force equation there is an inertial mass
<br /> F_{net} = m_{inertial} a<br />
and in his gravitational equation, there is a gravitational mass
<br /> F_g = G\frac{M m_{grav}}{r^2}<br />
And it turns out, they seem to be the same.
m_{inertial} = m_{grav}
That's what einstein called the "Equivalence principle," which led to his formulation of 'general relativity.' These days we take it for granted that those two masses are equal, but there is no fundamental physical law that says it has to be so, its an observational fact.
Awesome.
  • · Replies 51 ·
22K
  • · Replies 46 ·
  • · Replies 24 ·
