Why Is My Calculation of the Absolute Minimum Incorrect?
  • Thread starter Thread starter DieCommie
    Absolute Max
9 replies · 5K views
DieCommie
I have been understanding these so far but this one it says is wrong, but I can't figure out why.
"Find the absolute maximum and absolute minimum of the function f(x,y) = xy - 5 y - 25 x + 125 on the region on or above y = x^2 and on or below y = 29."
I get the absolute max to be =148.15 at (-5/3,25/9), which is correct.
I get the absolute min to be =0 at (5,25), which is wrong, but I can't find any more points of interest, as far as I can see 0 at (5,25) is right
If you have any clues/suggestions, I would greatly appreciate it :smile:
You have not properly examined what happens to f on the boundary of the region.
which boundary? y=29 or y=x^2?
for y=x^2 i get the points (5,25) and (-5/3,25/9)
for y=29 i get no points
I have looked over each one a half dozen times, if you know which one the problem is in, id like to know thx.
Well, I know there's at least one point on "the y = 29 boundary" where f is negative. When you consider what happens to f restricted to y = 29, you are checking the endpoints of the interval (which x can range over) and not just the points where the derivative equals 0, right?
ahhh, because at the endpoints it may be an extrema yet the derivative is non-zero. Got it! Thx a lot!
so if my range is a circle, there are no endpoints to check right?
But the entire circle would be the boundary. Write the boundary in parametric equations, plug those parametric equations into the object function to get a function of one variable and then differentiate that.
In this example, where the boundary was the parabola y= x2 and y= 29, you would need to look for max and min of
f(x, 29)= 29x- 5(29)- 25x+ 125= 4x- 145+ 125= 4x- 20 for the y= 29 part of the boundary. That never has derivative 0 so you look for max and min at its endpoints, [itex]x= \pm \sqrt{29}[/itex].
f(x,x2= x3- 5x2- 25x+ 125 has derivative 3x2- 10x- 25 which is never 0 and so you look for max and min at its endpoints, also [itex]x= \pm \sqrt{29}[/itex].
ugg, sorry, but now I am even more confused on the next one.
"Find the absolute maximum and absolute minimum of the function f(x,y) = 2x^3 + y^4 on the region {(x,y) | x^2 + y^2 =< 16} "
When writing the boundary in parametrics, i use x=cos(theta) y=sin(theta)? THis gives me 1=<16 for my boundary...
You have the wrong parametric equations. The boundary is the circle
x2+ y2= 16 (the interior of the circle, < 16, is not the boundary!). The parametric equations are x= 4 cos([itex]\theta[/itex]), y= 4 sin([itex]\theta[/itex]).
And you don't put those into the equation for the boundary (which would give you the trivial 16= 16), you put them into the equation for f:
f(x,y)= f([itex]\theta[/itex])= 2(4)3cos3([itex]\theta[/itex])+ 44sin4([itex]\theta[/itex]).
Thx for all your help, I really do appreciate it.
I have been trying and trying this but I am simply unable to do it. I have the derivative of the boundary function in terms of theta, but I do not know how to solve it and find what values of theta give me 0. I am going to go to the library and try to find a trig. book.
