Why is my keyboard inactive when installing Linux Red Hat 7?
  • Thread starter Thread starter Hbaw
    install Linux
The discussion revolves around the issue of keyboard inactivity during the installation of Linux Red Hat 7. Participants explore potential causes and solutions related to hardware compatibility, particularly with USB keyboards, as well as the age of the operating system and its support for modern peripherals.
  • Experimental/applied
  • One participant suggests that the issue may be due to the use of a USB keyboard that Linux Red Hat 7 does not recognize.
  • Another participant notes that Red Hat Linux 7 is an older distribution, using a 2.2.x series kernel, which had primitive USB support, and recommends using a more recent version like Fedora.
  • A participant mentions that they encountered the same problem and resolved it by enabling legacy USB support in the BIOS settings.
  • Several participants discuss alternative sources for downloading Red Hat or newer distributions, with links provided for Fedora downloads.
  • One participant recommends trying a newer version of Red Hat, such as FC2, which has better support for newer hardware.
Participants express multiple competing views regarding the cause of the keyboard issue and potential solutions. There is no consensus on a single resolution, as suggestions vary from BIOS settings adjustments to using different Linux distributions.
Participants reference the limitations of Red Hat 7 in terms of hardware support and the potential need for newer versions or alternative distributions to resolve the keyboard issue.
Hbaw
I have problem when installing Linux Red hat 7, my keyboard becomes inactive/dead. I tried changing to another keyboard, I've got the same problem. What is the reason ?
Thanks in advance
Howard
Computer science news on Phys.org
Thanks in advance
Howard
I'm guessing that you've got a USB keyboard, and that Linux isn't recognizing it. Regardless, you should look at the Fedora support stuff (Google for it) or at Red Hat for support, they'll be able to give you more specific help.
Red Hat Linux 7 is a *very* old distribution of Red Hat. If I recall correcty, v7 uses a 2.2.x series kernel (in fact, I believe USB support could only be added via a kernel patch while 2.3.x was maturing). In the 2.2.x days, USB support was very primitive. You'd be better using Fedora, for instance, where USB support has since matured.
Thank you NateGT and graphic7, that's the only version my friend lent me. he is so selfish, I intend to download but don't know where to do that, Red-hat asks downloaders to pay :redface:
http://www.linuxiso.org/
I checked out that site, they asked me to pay if I'd like to use redhat, do you know any other sites ?
Hbaw, where the heck are you looking?
linuxiso.org -> Fedora -> Fedora Core 3 Test(2.90)
CD 1: http://www.linuxiso.org/download.php/607/FC3-test1-i386-disc1.iso
CD 2: http://www.linuxiso.org/download.php/608/FC3-test1-i386-disc2.iso
CD 3: http://www.linuxiso.org/download.php/609/FC3-test1-i386-disc3.iso
CD 4: http://www.linuxiso.org/download.php/610/FC3-test1-i386-disc4.iso
If those links are too slow or they don't work, try the handful of mirrors associated with each cd. Just click on the cd-folder to see all the links.
i would try a newer version of redhat.. (FC2 is very good, too)
They added a lot of ps2/aux supports for newer controllers..
greets
soeren
I've seen this problem last night.
I had the same issue, and quickly resolved it by checking a couple of places.
The linux software (fedora) doesn't seem to make the USB native connections.
Try going into your CMOS/BIOS as the system is booting up, and Look for something like "integrated peripherals" or "advanced settings", and look for enable legacy USB devices. Make sure its set to enabled.
Mine resolved instantly, yours may take a reboot, or re-install.:eek:
  • · Replies 18 ·
10K
