Why is the magnetic field inside an ideal solenoid uniform
The magnetic field inside an ideal solenoid is uniform due to the contributions from an infinite number of loops, as established by Ampere's Law. The integral form of Ampere's Law shows that the magnetic field strength, denoted as ##|\vec{H}|##, is independent of the position within the solenoid, given by the equation ##|\vec{H}|=\frac{\lambda}{c}##, where ##\lambda## is the windings per unit length and ##I## is the current. The symmetry of the solenoid allows for this uniformity, as the magnetic field does not vary with location inside the coil.
  • Understanding of Ampere's Law in both integral and differential forms
  • Familiarity with magnetic field concepts, specifically in solenoids
  • Knowledge of cylindrical coordinates and their application in physics
  • Basic grasp of vector calculus, particularly curl operations
  • Study the applications of Ampere's Law in various electromagnetic systems
  • Explore the derivation of magnetic fields in different geometries, such as toroids
  • Learn about the implications of magnetic field uniformity in practical solenoid applications
  • Investigate the relationship between current density and magnetic fields in different materials
Students of physics, electrical engineers, and anyone interested in the principles of electromagnetism and the behavior of magnetic fields in solenoids.
jayman16
I understand that the magnetic field at points inside the solenoid is the vector sum of the B field due to each ring. How can the field inside be uniform then since if you consider just one loop in the solenoid the value of the B field is different at different points in that circle or loop.
But a solenoid is not one loop right? Ideally its an infinitely long line of loops. At each point your B field is the sum of the contribution from each of the infinite number of loops.
ya but at different points in each of the loops let it be the center or a point that is off center, the B is different is it not?
Just use Ampere's Law in integral form. Due to symmetry of a very long coil, ##\vec{H}## must be along the coil's axis, and you can assume it's 0 outside.
For the closed line in the integral take a rectangle with one side (length ##l##) along the axis, somewhere well inside the coil and the parallel side outside. Let there be ##\lambda## windings per unit length. Then you have, according to Ampere's Law (I neglect the signs here; you easily find the direction of the field, using the right-hand rule):
$$\int_{\partial A} \mathrm{d} \vec{r} \cdot \vec{H}=\frac{\lambda l}{c} I,$$
where ##I## is the current through the coil. This gives
$$|\vec{H}|=\frac{\lambda}{c},$$
independent of where you locate the rectangle's side within the coil. That's why ##\vec{H}## is uniform.
You can also argue with the differential form of Ampere's Law,
$$\vec{\nabla} \times \vec{H}=\frac{1}{c} \vec{j}.$$
In cylindrical coordinates, with the z axis along the solenoid's axis and with the ansatz due to the symmetry of the problem \vec{H}=\vec{e}_z H(r) you find, using the formulas for the curl in cylindrical coordinates ##\vec{\nabla} \times \vec{H}=-H'(r)##. Since inside the coil there is no current density you get ##H(r)=\text{const}##.
  • · Replies 16 ·
