Why is the speed of light constant?
The discussion revolves around the question of why the speed of light is constant, exploring concepts related to special relativity, observations of light, and the implications of light's behavior in various scenarios. Participants engage in a mix of theoretical and conceptual reasoning, with references to hypothetical situations involving observers and particles traveling at or near the speed of light.
  • Some participants visualize a scenario involving a photon traveling from the sun to Earth, questioning the implications of light's travel time and the role of observers, such as satellites.
  • Others introduce analogies, such as an ant walking towards a picnic, to illustrate concepts of observation and measurement in relation to light's travel.
  • There are claims that the speed of light is a constant but also discussions about its variability depending on the medium, with some arguing that "c" represents a maximum attainable velocity rather than the speed of light itself.
  • Participants discuss the implications of light's masslessness and its relationship to the invariant speed, as well as the effects of gravity on light's path, including its curvature near massive objects.
  • Some express uncertainty about the original question posed in the thread, leading to confusion and requests for clarification.
There is no consensus on the original question or its implications. Multiple competing views exist regarding the nature of light's speed, the role of observers, and the effects of gravity on light, leading to an unresolved discussion.
Participants express varying interpretations of the speed of light and its constancy, with some relying on analogies and others focusing on theoretical implications. The discussion includes references to relativity and the geometry of spacetime, but lacks a clear, unified question or conclusion.
r731
Visualize the following scenario. A star such as the sun, and a planet such as Earth are located in a solar system. A photon travels from sun (x0) to Earth (x1), and a satellite is in the midway observing the photon. This is relates to Einstein's special relativity.
I ask this since it take light about 8 minutes to reach earth.
Say 8 minutes to Earth, it takes less minutes for sunlight to reach satellite.
What is the question here?
An ant walks 5 cm/sec (3m/min) directly towards my picnic, 24m away. It will take 8 minutes for it to reach my picnic. There is a bread crumb halfway, so it will pass that breadcrumb after only 4 of those minutes.
If the ant sees the bread crumb and decides it is enough, perhaps she will take the offering and go no further. Similarly, if your satellite actually observes the photon, the photon isn't going to get to Earth at all. It can't be measured in two different places.
I did not need to invoke relativity theory to work any of that out.
I thought of the satellite as an observer (as in special relativity).
I spy with my little eye something beginning with "p" ...?
What about small particles that travel near the speed of light?
Fine. It being an observer or not has no bearing on when the light gets there.
Einstein did not invent the concept of the observer.
Same as the ant. So long as it is not accelerating, a small particle traveling at near c gets to the halfway point in half the time it takes to go the whole distance.
Relativity is still not relevant here.
r731 said:
I ask this
Ask what? There is no question in your OP, as several people have already pointed out. You do ask a question in post #8, but that question doesn't make sense by itself since it appears to be a follow up to some question you thought you were asking in the OP of this thread, but there isn't one.
If you cannot tell us what question you are asking about the scenario described in the OP of this thread, this thread will be closed, since we can't answer a question that isn't asked.
We don't know, we would need a deeper theory.
  • Sad
  • Skeptical
We observe that the speed of light is constant. No theory can answer why Nature behaves as we observe her to behave, but it can describe how she does behave.
"C" is a constant in many physics equations and IS NOT the "speed of light" but represents(!) Maximum attainable velocity in this universe. The actual speed of light is variable depending on the optical density of a material.
I'd not phrase it that way, since ##c## is not really attainable. Things either always travel at ##c## (light, for example) or cannot attain it ever. You are correct, though, that ##c## is better thought of as a fundamental constant, the invariant speed, that light just happens to travel at. That's a consequence of its masslessness - if we found that the photon had a mass then that would imply that light does not travel at ##c## in vacuum, but would not change relativity.
Well, in this sense ##c## is even less: It's a conversion factor from our arbitrary human definitions of units for time and length. From a relativistic point of view it doesn't really make sense to measure time and spatial distances in different units (as from a physical point of view it doesn't make sense to measure distances and heights in different units...).
We say that light does not have mass but what makes it then to change its direction when from a distant star as it reaches the sun?Why does it curve due to the effect of gravity and does not move straight?What about the fact that light cannot escape from the gravitational pull of a black hole?
The geometry of spacetime, a.k.a. gravity.
Sorry perhaps the question was not needed it was quite obvious I just was not sure.
Since the OP has not actually asked any question, this thread is closed.
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 57 ·
  • · Replies 33 ·
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 42 ·
