Why Is Theta Used as 120.7 Instead of 59.3 in This Hurricane Tracking Problem?
  • Thread starter Thread starter yang09
    Magnitude
The discussion revolves around a hurricane tracking problem involving the direction and speed of a hurricane relative to Grand Bahama Island. The original poster is confused about the use of an angle of 120.7 degrees instead of 59.3 degrees in the calculations for displacement.
  • The original poster attempts to understand the reasoning behind using 120.7 degrees as the angle for calculations instead of 59.3 degrees, questioning how this affects the x and y components of the displacement.
Participants are exploring the implications of using different angles in the calculations. Some suggest comparing results using both angles, while others confirm that the magnitude of displacement should remain consistent regardless of the angle chosen. There is an acknowledgment of potential errors in calculations.
The original poster mentions that the problem has already been solved and that they are specifically seeking clarification on the angle used in the solution. There is an implication that the problem may involve different coordinate systems or conventions for angle measurement.
yang09
The eye of a hurricane passes over Grand Bahama Island. It is moving in a direction 59.3◦ north of west with a speed of 38.9 km/h. Exactly 2.89 hours later, the course of the hurricane shifts due north, and its speed slows to 27.8 km/h, as shown.
How far from Grand Bahama is the hurricane 4.42 h after it passes over the island?
The problem is already solved and has the solutions to the problem. It is #3. But what I am not understanding is why they used 120.7 as their theta rather than 59.3
Magnitude (D) = square root ( Dx^2 + Dy^2)
I understand how they did the problem, but can you just explain to me why they used 120.7 as their theta and not 59.3. If they use 120.7 as their theta, wouldn't sin120.7 give you your x-component, not your y-component. And when using cos120.7, wouldn't that give you your y-component, not your x-component.
try with theta = 59.3 and compare your answer with the one in the book. Angle simply depends on coordinates you use, magnitude of displacement is independent of this choice, at least it should be ;]
i did try it with theta = 59.3. i got a displacement of 139.4, which is wrong
check it again. If you put theta = 59.3 in equations for delta x and delta y in paper which you gave, then the answer for total displacement is the same as with theta = 120.7
Ya, you're right. I just used the wrong numbers. But thanks for the help
In a compass plot, the 0 degree point is the rightmost part of the plot. See attached:
http://people.rit.edu/pnveme/pigf/TwoDGraphics/twod_dir_compass.gif
  • · Replies 16 ·
